Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
What does the purple button light flashing on 1/2 horsepower craftsman garage door opener
    New Friend:
    Problem Solver:
  • 5 Answers
I think the adjustment mode is on.
For example, that's from Craftsman manual:
Setting the Force
The force setting button is located on the left panel of the motor unit. The force setting measures the amount of force required to open and close the door.
1. Locate the purple button on the left panel of the motor unit (Figure 1).
2. Push the purple button twice to enter the opener into Force Adjustment Mode (Figure 2). The LED (Indicator Light) will flash quickly.
3. Push the remote control or control console (Figure 3). The door will travel to the DOWN (close) position.
Actually, you should just read carefully your garage door opener unit's manual.
Craftsman Garage Door Opener Remote
Posted on Jun 22, 2014
SOURCE: Remotes don't work
I recently had Verizon FIOS equipment installed in my garage (for phone, internet and TV), which is plugged into a 110 volt electrical outlet. Thinking this equipment might be causing some RF interference, I unplugged the FIOS equipment, and both garage door openers immediately worked perfectly again!
After reconnecting the FIOS equipment, I then plugged the garage door opener into a different electrical outlet approximately 15 ft. away via an extension cord, and the openers continue to work fine. Fingers crossed, I hope the issue is permanently resolved.
Posted on Aug 08, 2008
SOURCE: Garage Door Openenr Motor Buzz
Look at your manuel find the page that shows the limit access switch. (Unplug your opener.) It isn't really a switch, but the three white plastic screw like parts. The center has a brown wire connected to it, which has a metal piece that is as wide as all three white screws. The outside screws are your limit access stop guides, one for the up control stop guide and the other for the down control stop guide. If the center screw with the metal part gets caught behind on of the stop guides the motor will not engage. Gently move metal piece from behind the stop guide.
Posted on Nov 10, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: My Craftsman 53684 keyless won't work with my Craftsman 53930DM.
I've never seen the first set of steps you mention. You always need to press the "learn" button first so the opener will be in the mode to capture the new code. As far as I know it is not necessary to hold the Enter button on the keypad (at least I never have). While the "learn" LED is lit on the opener, just key in the new code and press Enter.
Maybe you should try clearing the receiver first by pressing the "learn" button and holding it until the LED either goes out or starts flashing (depends on model). Then try reprogramming. Maybe the little computer is confused.
Posted on Dec 01, 2008
moeshere
  • 33 Answers
SOURCE: craftsman garage door opener (1/2 hp) - light flashing
most of the time when the lights start flashing on them and they won't work it's something in the way of the eyes that cross the garage at the bottom are something bummed them and there not lining up no more check that first.
Posted on Apr 05, 2009
  • 3197 Answers
SOURCE: How do we reset our Craftsman 1/2 HP Part# 41A4315
If the lights in the door sensors do not light you have either a bad logic board or bad wiring to the sensors. Replacing the logic board is usually the cure.
Posted on Jun 05, 2009
I have a Craftsman Keyless entry model 132B2386-6 with flashing lights, wont open. Already put in new battery still doesn't work
Why would my Keyless Entry close but not open the garage ...
www.shopyourway.com > Manage My Life > Questions
Mar 27, 2008 - I have a Craftsman Security+ Keyless Entry, P/N 139.53684 purchased with my ... However, the door will not open, but the keypad flashes as before. ... Check if there is a flashing green light on your wall control in the garage. ... The 2 remotegarage door openers won't open or close the garage door; but the ...
Craftsman garage door opener won't open or close, why ...
Hi, I have a Craftsman 1/2 HP garage door with keyless entry (P/N ... When I click theremote or the wired button, the main lights come on, the motor moves ... Five flashes means that the RPM sensors has most likely stop communicating.
LiftMaster - Support - Videos ' LiftMaster
https://www.liftmaster.com/Customer-Support/Videos
Chamberlain GroupHow to program a wireless keyless entry using your garage door opener's LEARN button. How to ... Why the LED or light on the door control is blinking and my remotecontrol is not working? Why isn't ... Why won't my door fully open? How to ...
Feb 08, 2016 | Building Materials
I have a 3/4 horsepower liftmaster garage door opener, both the remote and the wall button won't close the garage door but both will open the garage door. however, the garage door will close if I hold...
If when closing the door it reverses to the open position and the main light flashes 10 times it is a door sensor problem. Make sure the small light on each sensor is on and not flickering ever so slightly. (check closely) Tweak them a little even though they may seem to be okay. Check for 5vdc between terminals 2 and 3 on the rear of the motor unit. If there is no voltage or if it is greater than 6vdc the logic board is bad.
Sep 26, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a craftsman 1/2 horsepower garage door opener, recently it started freezing, the light would blink,, it would work intermittenly but now theres no power, the electric plug has power, neither the...
You are going to have to find where you are losing power. The most likely place is the logic board especially if you have had any electrical storms or power surges. Remove the board and check for loose or missing traces on the printed circuit.
Nov 21, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears 1/2 horsepower chain drive garage door opener (circa 1993) would not open with remote and light on back of opener is flashing quickly. Tried reprogramming the remote, but had no success and the green...
It sounds like you have a remote with the button pressed or broken so that it is on all the time. Remove the batteries from your remotes and check that light. The rapid flashing is an indication that it is receiving a signal. Make sure you don't have an old remote in a drawer somewhere.
Sep 26, 2009 | Sears Craftsman LiftMaster Chamberlain...
Put a new battery into the wireless key pad attached to the garage door jamb. How do I code things so it will raise the garage door. The remote opener in the car and the wired button inside the gargage...
Simple ,find the smart button on your machine ,it will be where all the bell and infrared wires are connected ,which is also the logic board of the machine , this smart button is usually brightly colored /orange /red /purple / green/ when pushing this button in for a second or two makes a small led light lightup next to it and it will be a solid light ,at this time you want to go to your keypad and put your 4 digit code in and then press And Hold the Enter button until the lights flash on your garage door opener , those flashing lights on the opener are telling you the machine has recieved the code from the keypad , See told you it was simple ,you,ll have no problems ,just follow my instructions to the letter and it will work , GUARANTEED ! Thank you for letting me help you and if i was a help ,please help me and leave a nice rating Sincerely Glenn Mayer
Mar 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2 horsepower not working
Five flashes indicates possible RPM sensor failure. First try unplugging opener for five minutes and plug back in. If it still does not work replace RPM sensor.
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears craftsman 1/2 hp garage door troubleshooting
My garage door opener will start to close then stop and go back to the open position. If I put pressure on the door as it is closing sometimes it will close all the way and sometimes it will return to the open position. Can you help me. Thanks pbstation771@verizon.net
Aug 18, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
262 people viewed this question
Top Sears Building Materials Experts
Mike
Steve Allison
Steve Allison
Are you a Sears Building Material Expert? Answer questions, earn points and help others
