Question about Hyundai HPT-4250 Television
Code to enter service mode
What is the service code to enter '' service mode '' on Phillips and Panasonic televisions? My Hyundai HCT 435 PF television is in factory mode,please give me the code to get it out of factory mode
Hud-21b9b
Posted on Feb 15, 2008
How do i eras factory off a phillips tv 2008, model 21PT9457/85?
Your TV has entered into service mode [Factory] mode by somway, due to improper buttons press on remote control. You have to get out from this mode, and to select the normal mode. It will be best to contact any service technician in this case, as this is a semi-skilled work, and should have knowledge to enter service mode and to exit out from it. If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given.Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin.Be very careful.Note how to "EXIT" the service mode; after entering and adjusting data.This is very important.
Sep 30, 2014 | Televison & Video
Tip
Service menu codes phillips magnavox
I provide this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes
# Press {0} {6} {2} {5} {9} {7} {INFO+} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {STATUS} on the remote.
or
# Press {0} {6} {2} {5} {9} {7} {MENU} on the remote.
# Turn the TV off to exit the Service Menu
* Press {0} {6} {2} {5} {9} {6} {INFO+} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {STATUS} on the remote.
or
* Press {0} {6} {2} {5} {9} {6} {MENU} on the remote.
* Turn the TV off to exit the Service Menu.
* Press {0} {6} {1} {5} {9} {6} {MENU} on the remote.
or
* Press {0} {6} {1} {5} {9} {7} {MENU} on the remote.
* Turn the TV Off to exit the Service Menu.
* Press {1} {6} {2} {5} {9} {6} {MENU} on the remote.
or
* Press {1} {6} {2} {5} {9} {6} {STATUS} on the remote.
* With the TV off:
Models 15MF605T/17, 20MF605T/17, 15MF500T/37:
To Factory Mode:
Step 1 : Select the source "PC" and then turn off LCD-TV.
Step 2 : [Push "power " button and then push the "VOL- " and "VOL+" buttons at the same time immediately and hold it] about five seconds then release all buttons.
Press "menu"button and bring up factory mode indication
on Apr 29, 2015 | Magnavox Televison & Video
Phillips magnavox
Just do a factory reset to this set. To do this, you have to enter its service mode option. Just understand, this is most likely a semi-skilled work. If you're not confident about it, contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 12, 2014 | Daewoo DTQ-13P2FC 13" TV
Factory reset
To do a factory reset, you have to enter its service mode option. For more information go to http://electronicshelponline.blogspot.com/ Service mode entry, adjust & exit procedure to many popular brand TVs, including many models of Panasonic brand are given. Pull up older posts.
Nov 29, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
Panasonic th32lru30
To make it a factory reset, you have to enter its service mode option. If you wish to get details about how to enter service mode, and adjust parameters there, check this link. http://electronicshelponline.blogspot.com/ It has details.
Jul 04, 2013 | Panasonic TH32LRU30 32 LCD TV
Pt 53x54t reset to factory settings
To make it to factory settings, you have to enter its service mode option. Service mode window will be entirely different to that of normal window. Entering and exiting service mode to many brand televisions can be noted by this link. http://electronicshelponline.blogspot.com/ Pull up older posts there. Beware. Do not make any other adjustments there, other than factory reset. Changing data values, without knowing more about what will happen after that, is not recommended. It might even make the set inoperative to any more external commands, either by its front panel control or remote control, In fact, a dead waste set will be the result. Make sure to exit the service mode, after make a factory reset. For more details, check the link sited above. Read all instruction well before start.
May 31, 2013 | Panasonic Viera TH-42PX80U Plasma TV
I need to do a factory reset on my panasonic tv
You Have to Know How To Enter sevice Mode and if you do not know what you are doing you can really mess TV up BADLY Its a Page Long with alot to do before you can even get into service Mode and if you change the wrong values you can shut set down and reallly have a nightmare on your Hands I hate these TVs panasonic did not keep things simple when it came to setting convergence on these sets.you really do need service Manual for this TV.
Sep 21, 2009 | Panasonic PT-47WX42 47" Rear Projection...
Forget the service mode. The tv power supply regulator has probably failed.
Oct 07, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Exiting service mode
All different brand of PTV has there way of excisting out of the service mode, panasonic don't list it, very hard to do, turn tv off then you see.
What about Bob
Mar 01, 2008 | Panasonic PT-47WX42 47" Rear Projection...
Hyundai HPT-4250 Television Logo
986 people viewed this question
Top Hyundai Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jay Seifried
Level 1 Expert
Are you a Hyundai Televison and Video Expert? Answer questions, earn points and help others
