Question about Kenmore Washing Machines
Code ce flashing - Kenmore Washing Machines
  • 15,935 Answers
CE Communications ErrorIf there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Some common causes of CE errors include:
· Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the resistance values between the serial communications pins with the connectors in place. Make sure the harness does not have a bad connection.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a CE error will occur.
· Drive motor thermal protector has opened.
·Motor controller is not powered or fuse has opened. Replace motor controller.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Flashing CE CODE
try to clear error code
Aug 20, 2017 | Hayward Pool & Spa
Ce code and leaking water after repair of the ld code. Ld code was present and the washer was full of water. Took washer out and turned over removed the drain motor and took it apart and cleaned out all...
May 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CE code and leaking water after repair of the LD code. LD code was present and the washer was full of water. took washer out and turned over, removed the drain motor and took it apart and cleaned out all...
Mar 19, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Flashing ce
Most all error codes on a Calypso end up being a pump problem. If all the water can't be pumped out, the tub gets too heavy for the motor to handle and it will cause a CE error code. Something like lint or wire or screw may be caught in pump impellar. If your not familiar with repair you need to call for service.
Feb 02, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Error code CE When I turn the washer on it start then turn back off, then error code CE flashes on the display.
Jan 10, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
CF code--It starts to spin and then stops. That's when the CF code flashes. What is the problem?
There is not a CE Error - I suspect it is CF.
Jun 12, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
CE code flashing and have hit the stop-cancel and everytime i go to start it goes right to CE flashing,,, which i hear is a communication problem do you know how to stop it or fix it
CE Communications Error If there is any breakdown in communication between the machine controller and the motor controller, CE flashes and the unit beeps once.
Press STOP/CANCEL to clear the display.
Feb 05, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Top Loader "CE" error code.
CE means communications error
If there is any breakdown in communication between the machine controller and the motor controller, "CE" flashes and the unit beeps once.
Some common causes of "CE" errors include:
·Conformal coating on serial communications pins between the machine controller and motor controller. After disconnecting power to the unit, try scraping this coating off the pins.
· Check the quick disconnect at the motor terminal. The drive motor must be hooked up properly or a "CE" error will occur.
Dec 27, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
49 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
