Question about Duracell Crank Light 3 In 1, 3 Led Flashlight, Radio, Charger. 2 Pack
My duracell crank light 3 in 1 is not working properly. I rotated crank handle for about a minute or 2 long,thinking that charging would be enough and led torch will light for few minutes during power cut but my light not even worked for 5mins it started blinking and led light decreased and after some time the total led light disappeared. what i need to do to retain its charging capacity and to get its initial efficiency as given during the time of purchase.
I found with my Duracell crank lights they periodically need a good charge to function well. On the side there is a 5v charger socket - suggest and 8-10 hr charge. There is also a USB with a switch between IN and OUT. With a suitable USB cable in the IN position, the light can be connected to a computer to recharge. Hope this helps.
Posted on Jan 09, 2010
  • michel526 Mar 20, 2011
    I had the same problem and I tried to find a replacement battery pack. Never found one, nowhere... I built a replacement pack with a Li-ion battery, but it didn't work. Maybe I don't have the right type of battery.
Model: KP028 It doesn't work no matter how long I tried to charge it. I haven't used it for a few months though. Is there anyway that I can make it work again?
the batteries are gone . it carries 3 small 1.2volts battery 1 1/8" long and 3/8" in diameter soldered together making it 3.6 volts why couldnt duracel used aaa instead .couldnt find these batteries online. batteries are nickel metal hydride type 300mah.
Dec 30, 2010 | Duracell Crank Light 3 In 1, 3 Led...
My 15 min. Duracell charger keeps blinking-won't work...
When the duracell lights blink during charging, AT YOUR OWN RISK, try a reverse charge. Instead charging positive to positive and negative to negative, try positive to negative and negative to positive. I did this for 2 minutes. This solved the problem. After the 2 minutes, I gave the batteries a normal charge. You will have to force the battery and charger contacts to touch.
Jul 08, 2009 | Duracell AAA NiMH Battery Charger with 4...
Quick battery drain
No sorry to say this is normal for this camera! you may want to look for rechargable lithium batterys (they will last longer in a high drain device such as your camera!
Please rate my answer!
THANK YOU!
Jan 12, 2009 | Fuji FinePix S7000 Digital Camera
Need owner's manual
e548fa9.jpgafae0af.jpg3e075ea.jpg4392de5.jpg Max is 150K so sorry for bad quality.
Dec 16, 2008 | Duracell Crank Light 3 In 1, 3 Led...
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
Flashing lights
I had the same problem. 1 of four way's can fix it. #1 Put a batt. that has a little charge in that flashing spot 1st. and see if that works. #2 put the batt. in that flashing slot first and then in the 1st slot, If that did'nt work, #3 Put Batt. in backwards for 1 sec. in and out fast. and I do say very fast, In that flashing spot. #4 buy a new one. The one that fixed mine was #1 and it stoppppped flashing, The order I put them in was - 3-1-2-4 I put in #3 batt. first, it was the one flashing And it worked, You may have a bad batt. or it's on it's way out, but try It. worked for me!
Mar 30, 2008 | Duracell AAA NiMH Battery Charger with 4...
Duracell Crank Light 3 In 1, 3 Led Flashlight, Radio, Charger. 2 Pack Logo
1,320 people viewed this question
Top Duracell Camping, Backpacking & Hiking Experts
Sandy Troupe
Sandy Troupe
Level 1 Expert
Andrew Taylor
Andrew Taylor
Bill Wilson
Bill Wilson
Are you a Duracell Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
