Question about Creative Labs ZEN Vision:M Digital Media Player
I accidently formatted a creative zen vision m hard drive to ntfs format and now zen will not reformat it
SOURCE:
SOURCE: Creative Zen Vision M: Placing Old hard Drive in New Player??
I Dropped My Zen Vision M And Cracked The Screen And Bought A New One But Replaced The New ZVM's Hard Drive With My Old One And All I Had to Do Was Restart It For It To Recognize The New Hard Drive And If It Doesnt Recognize It All You Gotta Do Is Put A New One In And Download More Songs xD And If You Need A Disassembly Tutorial Heres A Good Site
http://www.anythingbutipod.com/archives/2006/02/how-to-disassemble-the-creative-zen-vision-m.php
Posted on Mar 07, 2008
  • 3 Answers
SOURCE: zen vision m not recognized....
here, this is what I did to fix this problem. copy and paste from my original post on anythingbutipod.com
"My player is completely charged, I have XP w/SP2 - I can turn it on and listen to the default audio tracks and videos...I just can't get my computer to recognize it AT ALL!"
and then:
also, when I try to allow "everyone" to the USB....I found that in the advanced section I have TWO "everyones".
The one that says "full control" says "not inherited" in the inherited from column...the other says "read" and "machine\system\currentcontrolset......."
Should there be two of them in there??? Because when I try and switch the read to full control, it reverts back as soon as I select apply or ok....I tried deleting it but it re-creates itself soon as I go out of the window.
so I was told to do this:
Sounds like an NT problem. I don't know the exact steps to do this, but you'll need to remove inheritable permissions from that, which will remove the "inherited" attribute, leaving the locally-controllable one.
So open "run" command in the start menu and type "regedit"
From there follow this path...
"hkey_current_config" -> system -> current control set -> Enum -> USB
Do what I copy and pasted above and then plug your Zen V:M in and it should recognize it.
Posted on Jun 21, 2008
SOURCE: CREATIVE ZEN VISION MZEN VISION M TECHNICAL SUPPORT
If it is new, install the software on the two cds that come with the Zen.
Posted on Dec 09, 2008
SOURCE: Creative Zen Xtra hard disk problem
THIS WORKED FOR ME:
32. I bought one of these and used it on and of for 4 months. One day I got a "harddisk problem" and tried everything. Because I purchased in the US, Creative said that it was out of warranty but they would fix for £100. I looked around the web and found a thread that shows how to fix it. The solution, and this is a bit technical, is - seriously - to hit it on the right hand side very firmly on the right hand side with your hand whilst switching it on. It re-indexed and I've never had a problem since.
report_dis_text_3885 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Posted on Feb 08, 2009
  • 5 Answers
SOURCE: Creative Firmware Upgrade Does Not Recognize Zen Micro
I had this same problem and almost threw out the Zen.
The trick to getting the Zen recognized by the firmware update software is to make sure you uninstall BOTH WMP11 as well as the WMP11 Runtime. Those two things are listed separately in Add/Remove programs.
BOTH must be uninstalled before the firmware updater will recognize your Zen.
Now I'm back to using my Zen. It's all good.
Posted on Apr 13, 2009
Reformatting HCS725032VLA380
Is it your primary hard drive ?
Reformat hard drive to NTFS Windows XP allows you to easily format the hard drives with its inbuilt utility. Formatting the hard drive would forever delete all the files stored on it. There are two ways in which you can format the hard disk partition - from My Computer and from DOS. You cannot have a NTFS partition with allocation unit s above 4096.
Click on "Start," and then click on "My Computer." Right-click on the disk partition to format and then click on "Format." Click on the "File System" drop down box and select "NTFS." Click on the "Allocation unit " drop down box and select an allocation . It is recommended that you select the "Default allocation " option. Click on the "Start" button. b> Format the Partition from DOS b> Click on "Start," and then click on "Run." Type "cmd" in the 'Run' dialog box and then press "Enter." Type "format drive_letter: /FS:NTFS" at the command prompt and then press "Enter." Replace the 'drive_letter' here with the letter of the drive that you want to format (for example, format e: /FS:NTFS). For help on advanced formatting options, type "format/?'more" at the command prompt and then press "Enter." Keep pressing "Enter" as you read on. Hope it helps
Jan 24, 2013 | Hitachi CinemaStar 7K500 HCS725032VLA380...
Zen vision:m 30g Stuck in recovery mode When I try to format harddrive 'harddisc problem' shows in window. Can you help. Thanks.
to fix this problem you need to format the hard drive. to format it you need to, with the power off, put the battery onto the player while holding the on button this will take you to the recovery mode and then you just select format hard drive it is automatic and should fix your problem. If not try to reinstall the firmware
Aug 11, 2008 | Audio Players & Recorders
My creative zen micophoto will not boot up what do
Hi.
You tried these yet?
Reset, Format or Clean Up a Zen Vision:M
If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
To reset Zen Vision:M to factory default settings:
  1. Press on the Menu/Back button on your player, and select System, and then Reset.To Format or Clean Up Zen Vision:M Detach the Zen Vision:M player from your PC , and ensure that the unit is off.If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon and hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove.
  4. Release the Power switch when the Creative logo appears. The Recovery Mode appears: * Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)* Format All (Formats the players hard disk - Note: all contents will be lost)* Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)* Reboot (Reboots the device)
  5. Select Clean Up or Format from the Recovery Mode, and then select Reboot
Good Luck^^
Nov 02, 2009 | Audio Players & Recorders
I am a reporter. My zen visin's hard disk report a error. what can I do now?
Try to format it, if it shows a hardware error, replace the hard drive or the zen.
Oct 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen m vision won't start up,
1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off.
* Reboot (Reboots the device).
5. Select Clean Up or Format from the Recovery Mode, and then select Reboot.
http://dmzweb4.europe.creative.com/...com:80,Case=obj(14048),Kb=ww_english_add
pls rate it, thanks
Nov 12, 2008 | Creative Labs ZEN Vision:M Digital Media...
Adding songs
DB is corrupted - reformatting will partially erase the native formatting of the player, so you may have to get the latest firmware upgrade to resolve the issue - restore key formatting elements.
-Tha Mp3 Doctor
http://us.creative.com/products/product.asp?category=213&subcategory=214&product=14331
May 28, 2008 | Creative Labs ZEN Vision:M Digital Media...
My zen is freezeing
1. I'd try a system clean up first (instructions below)
2. definitely upgrade your firmware (http://us.creative.com/support/downloads/)
3. If all else fails, back up all your music on your PC and format it (instructions below)
.... from Creative's site
Reset, Format or Clean Up a Zen Vision:M If your player stops responding, you can reset it. To reset the player, push the end of a pin-like object (for example, a pin or straightened paperclip) into the Reset hole. This should not cause you to lose any data or audio tracks, unless you were in the middle of transferring an audio track.
  1. Detach the Zen Vision:M player from your PC , and ensure that the unit is off. If the battery is too low, charge the battery fully before continuing
  2. Slide the Power switch towards the Power icon vision_m_reset.jpgand hold the switch in the Power On position.
  3. Push the end of a pin-like object (for example, a straightened paper clip) into the reset hole, press gently and remove. vision_m_reset1.jpg
    • Clean Up (Performs a disk scan on the player's hard disk, it will not affect music files)
    • Format All (Formats the players hard disk - Note: all contents will be lost)
    • Reload Firmware (Reloads the Operating System on the Zen. Select this option ONLY if there is a firmware available to reload.)
    • Reboot (Reboots the device).
Jan 05, 2008 | Creative Labs ZEN Vision:M Digital Media...
Zen not working
You might just have to completely reformat and reset the OS/Firmware your player. Note: THIS WILL REMOVE ALL SONGS/VIDEOS/PICTURES FROM THE DEVICE! To reformat: 1. Hold the power switch in the ON position 2. Insert a paper clip into the RESET hole. 3. Continue holding the power switch ON until the Creative logo appears. 4. Select Format All from the Recovery Mode menu. 5. Select Reboot To reset the OS/Firmware: 1. Go to http://us.creative.com/support/downloads/ 2. Under Select Your Product select MP3 Players > ZEN > Zen Vision: M (either 30GB or 60GB model depending on what you have) 3. Select your operating system and Firmware from the File Type drop down box 4. Download the file from the next page to your Desktop 5. Agree to the stupid EULA and download the file 6. Connect the player to the computer 7. Once the player is recognized, run the .exe file 7. Follow the on-screen instructions If you are still having problems, or any of the above does not work as planned, let me know.
Feb 21, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
62 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Marvin
Marvin
Peter Dragonetti
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
