Question about Epson Office Equipment & Supplies
I have an Epson stylus CX5400 ink jet scanner. I ran the cyano ink cartridge all the way out, then replaced it. I'm now getting an error and it says scanner error - check documentation what should I do -I've tried turning it off and on again - same result
  • 297 Answers
Go and try this software to reset your printer:
http://www.ssclg.com/epsone.shtml
Posted on Jun 27, 2009
How do i install my new ink cartridges in my printer epsom
Be sure you have a new ink cartridge before you begin. Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
  1. Make sure the EPSON Stylus CX5400 is turned on and not printing. The LCD screen tells you which ink cartridge is low or empty.
  2. If your EPSON Stylus CX5400 is low on ink, press the left Menu button until you see Change Cartridge, then press the Color Copy button.
    If your EPSON Stylus CX5400 is out of ink, press the Color Copy button.
    The ink cartridges move to the replacement position.
  4. Lift up the scanner.
  6. Pinch the tabs on the front and back of the cartridge, lift it out of the printer, and dispose of it carefully.
  8. Before you remove the new cartridge from its package, shake it four or five times.
  10. Unwrap the new ink cartridge and lower it into its holder, then press down on the top of the cartridge until it clicks in place.
  11. Caution: Don't touch the green circuit board on the back of the cartridge; you may inhibit normal operation and printing.
    If you need to replace other ink cartridges, repeat steps 4 through 6 before continuing with step 7.
  12. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
  13. The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on.
    Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX hasn't moved or made noise for more than 5 minutes.
Oct 27, 2009 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus Photo R800 driver ran out of ink weeks ago. Today new ink cartridges arrived. Replaced all cartridges (even the ones that were ok) because the printer's low ink light would not go out until I...
His could be because epson print jets plug up. and usualy cost more to repair than to purchase new printer. i had epson and now buy HP because hp when you replace the ink cartridge the spray jets are incorporated into the cartridge the only thing you have to be carefull of is that somel manufactures now put a chip on the cartridges to expire the units so they can sell you another even if you dont use the ink HP included so look for exp. date on new units. look into food warehouses like sams. costco, Bjs etc. they usualy have good prices on printers. sunday paper is also a good place to look.
Sep 22, 2009 | Epson Stylus Photo R800 InkJet Printer
Error inkcartridge
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200
Nov 28, 2008 | Epson Stylus CX3200 All-In-One InkJet...
My Epson Stylus CX5400 won't print.
hii,
u printhead block..that why cannot ink cant not get trough from the print head..or try clean the print head using printer properties under maintenain .for informations epson print head are sensetif..
Oct 25, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400 - use as scanner only?
imy cx5400 prints only part of the page.it also prints so light i can barley read it.When Iprint pictures there are lines all down the picture.
Aug 30, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson stylus cx5400
Please help....My scanner only shows a large corner portion of the copy. The menu reads ERROR
...no color CYAN etc etc I have contacted many technitions....None have helped The last person Claimed it had to do with low ink....It doesn't make scence. Isn't the scanner separate from the printing components?The printer is in excellant condition...but I was told to dump it and get another I do hope you can HELP....I am 83 yrs young and I have a budget problem....Many Thanks Phyllis
Jul 27, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Printer only prints blank pages epson sylus cx5400
Sorry to say, but you may want to read this thread......
http://www.fixyourownprinter.com/forums/inkjet/29681
Jul 12, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Epson CX5400
Nothing wrong with the printer. The rubbish cartridge you bought and replace it with one that works. Approx 30% of most compatible/refilled cartridges DO NOT WORK.
Not only that but they WILL block your print head nozzles eventually. Ever wonder why Epson do NOT make any flushing cartridges but almost every compatible "maker" does??
99% sure the cart is at fault. return it to where you bought it and get a swap.
Jan 04, 2008 | Epson Stylus 680 InkJet Color Printer
Epson stylus cx5400 reset???
try doing this :
Reclamping the Ink Cartridges
Once you start the ink cartridge reclamp procedure, you must complete all the steps in one session.
2. Press a MENU button until you see CHANGE CARTRIDGE, then press the COLOR COPY BUTTON. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Lower the cartridge back into its holder, then press down on the top of the cartridge until it clicks in place.
Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
6. Carefully lower the scanner and press it down until it clicks into place. The EPSON Stylus CX5400 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus CX5400 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus CX5400 while the On light is flashing, unless the Stylus CX5400 hasn't moved or made noise for more than 5 minutes.
if the issue still persists - you need to call the vendor - it´s a hardware issue
Dec 30, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson cx5400 problems
Sound like print head is you problem, are you using epson gen inks? ussally heads clog due to dodgy inks running  threw machine, If it isn't under warranty replace with new
Oct 18, 2007 | Epson Stylus CX5400 All-In-One InkJet...
222 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
