Question about Logitech QuickCam Messenger Web Camera
Installation Why is it necessary to disable anit virus software before installation, and how do I do it?
  • 170 Answers
Hello jonesyb,i am nichu .i, have a solution for your problem.is it necessary to disable anit virus software before installation because your antivirus software blocks the installation thinking it as a virus.though the software gets installed it might get corrupt.
to disable a antivirus software go to the system tray which is at the bottom right of your screen,right click on the antivirus software icon,then click quit or exit .............problem solved
take care
bye.
Posted on Nov 06, 2007
I tried installing Age Of Empires 3 on my macbook pro OSX. When the installation was almost done it came up with an Error Code 36 and then quit the installation.
Make sure you don't have the hardware hooked up or have any programs or windows open, until you know that the software has installed correctly!
Insert your disk, Restart your computer! If upon restarting your computer does not detect the new software, than...
Go to Start, Control Panel, Install New Software! Restart again!
You may need to update your driver? If so...first I would create a back up on a disk or flash drive (cruzer) just to be safe!
To update the driver, you will need the software disk inserted, so you know which disk drive you need to update,.. Go to Start, Computer, Right click on the drive that shows the disk, select properties, select up-date driver.
Also,. FYI...Some Software programs require you to disable your virus protection, firewall, defender, to be able to install, whether or not, but especially if they are password proptected!
Try disabling your virus protection and select untill you restart, Go to Start, Control Panel, Firewall, or type in the search box...disable virus protection.
Try this and let me know if you need further assistance?
Kind regards!
Sep 15, 2011 | Computers & Internet
Tip
How to Recover Your Computer from Virus Attack {XP ,VISTA ,WINDOWS 7 ,Etc }
Software 1:DiskHeal
download
this software is used to Restore the
A:folder Option (Hidden files option restore)
B:C:, D:, E, F,_ _ Etc Drive not opening when double clicked from "MY Computer" Pendrive not opening etc.
C:Task man not openning (ie to recover Task Man is disabled by your ADMINISTRATOR error")
and more............
D:Restore Registry Editor
Software 2:Autorun virus removal (can remove autorun virus form your computer)
download
A:restore Exe file error's
B:anti-virus not installing {some viruses block installation of Anti-virus software } provide solution for these problem
C:can repair Safe Mode Option{if you are unable to access Safe mode .some viruses block's the safe mode}
and more........
software 3:similar software (file size is 22MB)
download
software 4:Antivicrypt
To recover files infected by .viCrypt” extension. virus
download
4:Install antivirs software
update and do full system scan
download
5:Go to Run type Cmd and Type SFC/SCANNOW and press enter key
if your windows files are missing this command will restore the missing
files from windows CD"
make sure that you have the windows installation CD to try command
6:Install Registry cleaner
download
Registry cleaner software -delete invalid entry in the registry thus speed up your system
(please rate me)
on Jan 12, 2010 | Computers & Internet
Can not install avg anti virus
AVG anti-virus is very finicky when it comes to installation. If you do have other anti-virus software running while trying to install AVG, I would suggest that you disable or uninstalled the software.
Sep 03, 2011 | PC Chips M825LU Motherboard
Error in scanner. Turn off scanner and follow instructions in manual.Scanner driver will be closed. (code:201) Unable to open TWATN source Please check connection Then re-start Toolbox.
This error can be caused by many different issues. Try the following resolutions in order until your issue is fixed-
1. You should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists.
2. unistall and re-install drivers-
1. Place the CanoScan Setup CD-ROM into the CD-ROM drive.
2. When the CanoScan Setup Utility menu appears, click the option to 'Uninstall the Software' and then follow the prompts.
3. Disable Third-party Software
Software applications that are active during installation can cause errors, installation difficulties and even abort the installation.*1 Close all running applications, including anti-virus programs, before installing Canon Software. You can also prevent these applications from starting through 'System Configuration Utility' (also referred to as 'msconfig') in Windows 98/Me, Windows XP and Windows Vista.
If your computer is part of an office network: Network permissions, security software, etc. may be interfering with proper communication. Please contact your System or Network Administrator before attempting to disable software on your system.
a. See your applications' documentation for instructions on how to close it.
b. If you are unable to locate the documentation or the application appears to be running after it is closed, disable the startup items in the Windows 'System Configuration Utility'.
c. If disabling startup items in 'msconfig' does not correct the issue, disable non-Microsoft related services in 'Services' tab of 'System Configuration Utility' window.
d. Attempt to install the Canon software (drivers). If the drivers were already installed, uninstall them (keep the third-party software disabled) and then reinstall the drivers.
e. After installation is complete, set 'msconfig' back to 'Normal Startup'.
//javaftper
Jul 31, 2010 | Canon CanoScan 3000ex Flatbed Scanner
I am trying to install an Java 6 update 20
If you are using any form of Anti Virus software, it could be stopping the installation process. Go to the SUN Java website, and download the latest version. Save it to your desktop. Take a moment to reboot your machine completely. DO NOT start any other programs after rebooting. Stop or disable your ANTI VIRUS software. Install the JAVA update and reboot. The update should work, and upon rebooting after the install, your AV software should start again. If it is still disabled, enable it.
May 03, 2010 | Sun Java Programming Language (cdj-275)
When i try to format my computer it is ok but i try to install a software it doesn't continue but if i try to the other computer the software will continue installing maybe what it is cause
disable any programs that are resources hungry and disable any anti virus and try;otherwise try installing the software just after installing the new os
Nov 26, 2009 | Computers & Internet
Why do i have to turn off my anti virus software?
Unfortunately, some anti-virus can interfere with the driver installation. However, you can enable the anti-virus back once you are done with the driver installation.
Please contact your anti-virus software manufacturer for further assistance in disabling your anti-virus.
Apr 28, 2009 | Epson Stylus NX105 All-In-One Printer
I can't install my norton antivirus...
Try running a free program like malware bytes first before you try to install norton. Sometimes viruses will disable the anti-virus installation when they see them running. For really really bad viruses that wont let you remove them a reformat or restore may be necessary.
www.malwarebytes.org
Mar 04, 2009 | Computers & Internet
Major error
your pc is infected by viruses plz scan your pc with a anit-viruse. then from the folder option ( in control panel) you enable show hidden files and delete the autorun.inf from all drives and restart.
Aug 18, 2008 | Microsoft Windows XP Professional
We have not CD for software
Try to disable the antivirus and run the setup again
May 13, 2008 | HP ScanJet 2400 Flatbed Scanner
Logitech QuickCam Messenger Web Camera Logo
81 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
