Question about Kenmore 96012 / 96014 / 96019 Electric Kitchen Range
We have a Kenmore model #790.96011407 range with smooth top. It was working fine until recently one, then the other, front burner started operating on their own. They will not turn off when you turn the knob to the off position, and sometimes stay on High regardless of what number they are set to. Today we had to flip the breaker in order to get the burners to turn off. The first thing that happened was that the indicator light for "hot surface" stayed on continuously, even when the stove had been off for hours. Seems there is some sensor problem.
  • Amanda Bird Jun 13, 2013
    Our stove is doing the exact same thing. Can you tell me what you did to fix the problem. Trying to troubleshoot. Don't want to buy a wrong part that cannot be returned.Thank you.
    Master:
  • 969 Answers
If this is happening on more than one burner the command module may be bad, small cicuit board inside control panel. With power disconnected easy replacement. check wiring to each burner control 1st by removing control panel cover. Be careful to remove small screws on either side of panel between panel & burner.
Posted on Jun 27, 2009
4 Suggested Answers
  • 68 Answers
SOURCE: My smooth cook top is cracked, can I still use the burners?
using a cracked cooktop is highly dangerous. i have seen these cooktops shatter because of people using them with a crack. One shattered so bad that the glass was found all over the kitchen and the ajoining living room.
Please dont use it, for your safety, repair or replaced the unit
Posted on May 01, 2009
barkencoa
  • 3463 Answers
SOURCE: My large burner will not shut off on my frigidaire stove.
You need to have the temp regulator replaced.
Posted on Dec 14, 2008
SOURCE: Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Posted on Sep 13, 2010
How do I change a burner on a smooth top stove?
usually the top will tilt back so you can get to the elements .
Apr 09, 2016 | Kenmore Kitchen Ranges
Where are the fuses for the Sears Kenmore stove to elements located on Model C880 675080L0
Most likely no fuses. Either the element or the switch that turns it on is bad. If lighat comes on when you turn on burner the switch is probably ok and the burner went bad.
Jan 02, 2015 | Kenmore Sears Electric Range Surface...
Kenmore Gas Oven doesn't heat
Here is a tip that I wrote that will help you with that problem...
The ignitor for your burner has faied...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
heatman101
Apr 07, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore Range/oven Burners won't lite
Ours did the same, I unplugged the stove for 1 minute and afterwards the burners worked fine.
May 19, 2009 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore glass top range left front large burner out
check the burner socket, it is likely that contact is being lost where the burner connects to the hardwired portion of the system (the socket). It is not unusual for the socket to "burn up" when there is a poor connection to the burner resulting in the burner being replaced and the new burner not working or working intermittently.
Please take the time to rate this solution
Jan 29, 2009 | Kenmore 95002 / 95004 Electric Kitchen...
JBP84TOHWW GE Electric Range Large Dual Element Not Working
similar problem after a power outage. Display would be blank until I turned ON an element (after which display would light, but no power to the respective element. No elements would heat even thought the dial shows power). Turning OFF the element would blank the display. I reseated the power cord and cycled the 50a basement breaker for 5 mins. Everything now works, but not sure for how long.
Dec 23, 2007 | GE Spectra JBP84 Electric Kitchen Range
Kenmore Gas Range/Freestanding/ Electronic Ignition
I have an electronic ignition Kenmore Gas Range. The Model Number is 790.78573407.
Am getting the error code F93 in the oven control panel. The manual says the likely cause is "Maximum oven door lock time exceeded". When I plug the oven the "door lock light" flashes and then the "F93" error code flashes. Am not able to use the bake or broil.
Aug 31, 2007 | Kenmore 78812 / 78814 / 78819 Gas Kitchen...
Kenmore 96012 / 96014 / 96019 Electric Kitchen Range Logo
575 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
