Question about Chatterbox GMRS-X1 (15 Channels) 2-Way Radio
Every time i push the ptt button the unit turns off. the bluetooth light stays dimly lit but i cannot talk or hear my music.
Sounds like you need to try replacing your batt.
Posted on Jun 30, 2009
Oven lights but then flame goes out as soon as I release the knob
The flame sensor seems to be bad.
When I light my pilot light, it stays on till I release the button ...
askville.amazon.com > Home > Home Improvement
Mar 18, 2008 - Similar Questions: light pilot stays till release button suggestions ... If you have held it for a long time and it still won't stay lit, then your thermocouple is bad.... the gas valve doesn't think a flame is burning the gas coming out of the pilot ... less likely but somewhat common is the gasvalve... if the knob you are ...
Troubleshooting Gas Range and Oven Problems ' Back ...
blog.etundra.com > Tundra's Tech Talk
Dec 15, 2015 | Fisher Paykel Fisher & Paykel 24-in...
Shuts off immediatley after pushing PTT button
sounds like your batteries are shot and not able to supply enough power for transmit
Jan 10, 2014 | Motorola Walkie Talkie 2-Way Radio
My tx light is staying on ? so my base station is allowing everybody to hear whats being said in the office to the cars
Check your PTT (push to talk) button on your mic, and also double check the plug where it is connected to the radio. It sounds like your PTT is stuck.
Best regards.
Aug 22, 2011 | Radio Communications
Model: Motorola Talkabout 2-way radios
Typically you should be able to communicate by pressing the Push-to-Talk button (PTT). If it is necessary for you to press the musical note, you are using the Call Tone feature, which makes the other unit have a sound. This method is acceptable, but not necessary unless you want sound.
Here is a copy of the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T56XX_57XX_User_Manual_E.pdf
Read the section on Call Tones and decide if this is the method you prefer. Otherwise, shut off the call tones and then you can simply use the PTT button to communicate.
You are correct, the radios must be set to the same Frequency. Plus, they must be on the same Code (interference eliminator code) and the Qt filter must be set the same on both units. Following setting everything to match one another your radios are ready to communicate.
Best regards.
Nov 12, 2009 | Motorola Talkabout T5720 (7 Channels)...
When I turn on the radio the indicator light on the top of the unit just flashes. I cannot set the frequency or code. When I push the monitor button I hear static but otherwise the radio is dead.
The flashing light can be an indication there is activity on the frequency the radio is set to. Pressing the monitor button should give you the white noise (static) sound, so this function is working correctly. This also tells us your speaker is working fine, as well as your volume. The typical reason you cannot go into programming mode (when you hold the PTT in while turning on the radio and hear the female voice announce your frequency) is a bad or moved internal PTT switch. This typically happens over time as a user presses ever harder on the PTT to communicate. However, this does not explain why you are not receiving. This could simply be a result of an incorrect PL code in conjunction with the bad PTT. If you have a frame removal tool, you can extract the component board and physically look at the internal PTT. You can then hold in the very small button and program the radio to the frequency/PL you desire. If you are needing the radio repaired, you can get this style unit repaired for around $69 flat rate
Jul 16, 2009 | Motorola MU24CVS UHF (4 Channels) 2-Way...
Hang up
Button on side is not for answering calls.
PTT or Push To Talk allows you to use your mobile like a walkie talkie. It is dependant on your network operator running the service.
Quote from Pocket lint:
To use the function you must first create a group or individual in your phone menu and send an SMS invitation to those you wish to join. Once your contacts are set up, your phone shows which members have their handsets switched on with push-to-talk enabled, in the same way that instant messaging works online. By pushing a single button on the handset, you are connected with one person or with your group. There is no need to dial numbers, nor do the recipients need to answer calls. You simply push a button and talk. As with a walkie-talkie, anyone in the group hears you almost instantaneously. The talking is one way with only one person able to speak at a time. Unlike walkie-talkies, which are infuriatingly dependent on distance, push-to-talk has no such limitations.
You should be able to disable PTT in the Nokia menu, which is best if your network doesn't support it. Plus you won't keep cutting off calls.
Apr 23, 2009 | Cell Phones
Charging plantronics 520/521
The red light will stay ON while charging and will go OFF when charged. Charging does not take long. Since you have no manual, you turn the headset on by pressing down or toward your head and holding the button down. If it's in your ear already, you'll hear a four-note upward pitch sequence to indicate it's powered on. If it's out of your ear, you'll see a red light, followed by a blue flashing light.
Set your phone into Bluetooth mode and make sure in the menus that Bluetooth is "discoverable" or some such lingo to search for the headset. The pairing code for this headset is 0000 (zeros not O's), so when you set your phone up to pair with the headset and the phone wants a pairing code, enter 0000. After the pairing is completed and Bluetooth is activated on your phone, you should hear a high pitched single tone to indicate the headset is in range and communicating with your phone. If you separate from your phone over about 30 feet or if communication is interrupted with your phone for some reason, there will be a lower pitch single tone, indicating loss of communication. After pairing, you should not have to go through the code sequences or setup again unless your phone is completely reset. You should be able to set your phone to Bluetooth, turn your headset on and hear the four-note sequence, followed by a single high note.
Push the switch up or away from your mouth to step the volume up. Likewise, push the switch down or toward your mouth to lower the volume. I've never turned it down, it's always a little low in volume to me even at max.
Push down or toward your head BRIEFLY to answer or hang up the call. Depending on your phone, you can also activate dialing or voice command by using this same brief push. There is a brief delay between pushing the button and being able to talk on most phones, so you might listen for a volume or noise change before talking.
To turn the headset off, push down or toward your head and hold the button down. You will hear a four-note downward pitch sequence to indicate power-down. If you're looking at the headset, you will see a steady red LED, then it will go off. By the way, a flashing red LED indicates need to recharge. A flashing blue LED indicates the unit is operating correctly.
Remember, battery consumption on your phone is greater with Bluetooth turned on, whether you use the headset or not. Bluetooth units constantly stay in touch with their partners, much like your phone stays in touch with the cell towers. So watch your phone's battery indicator a little more closely until you get used to your talk patterns and general use. Depending on your situation, your phone may not use much more battery than before.
Standby (inactive but ON) time on the headset is very good, and battery shelf life (power OFF) has been good also. These headsets are extremely useful in a car or if you are busy with your hands during calls. Just remember to use your head (pardon the pun) and not take or make calls while doing something dangerous. You wouldn't do that with your corded home phone, would you? The vote is still out, but they do tend to look a little nerdy when worn constantly in public. I hope you get as much benefit from your Bluetooth headset as I have from mine. I thought they were completely Nerdsville before, but I'm a convert now. Good luck.
Mark in Oklahoma
Aug 25, 2008 | Plantronics Hama Voyager 520 Bluetooth...
One way comm only
swap batteries if does not work this unit should need repair or replace, display blinking can be produced for power failure ( battery, contacts, circuits) or can be a controller issue.
Feb 07, 2008 | Motorola Talkabout T5500 (7 Channels)...
Transmission problem
A couple of things you can try:
1. Use electronic contact cleaner (spray type) on the PTT switch;
2. Use an external speaker/microphone and/or handsfree VOX headset
3. Replace the PTT switch. 4 solder points. Might not be easy but doable.
The last would require that you remove the defective PTT switch and use that as per sample when looking for replacement. Some printers uses the same type of switch. Familiarity with electronic components/circuitry, use of a DVM and a soldering iron would also be required.
Hope this be of some idea/help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Dec 17, 2007 | Motorola Talkabout T5800 (22 Channels)...
Chatterbox GMRS-X1 (15 Channels) 2-Way Radio Logo
227 people viewed this question
Top Chatterbox Radio Communications Experts
eradiostore
eradiostore
Shaun Baxter
Shaun Baxter
Level 1 Expert
John L radiodude365
Are you a Chatterbox Radio Communication Expert? Answer questions, earn points and help others
