I have a HiSense TV and need RCA remote control code to operate the TV
CompuGuy44
  • 432 Answers
SOURCE: lost my manuel "codes" to my rca universal remote control crk74ba3
This website should help.
http://www.thompsontv.com/rcarc.html
Posted on Nov 07, 2007
robotek
  • 1512 Answers
SOURCE: need code for direct tv for my rca remot universal control rcu600d
The product you are trying to access may be called DirecTV(different spelling). You will need to find the make of your set top box used to decode the DirecTV and then look up satelite codes in the user manual for the remote to select the correct code.
the manual for the remote can be found at
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=philipsmagnavox&dv=universalremote&md=pm435&kw=pm435s&st=&ar=&dt=&so=&pg=1&file=others/philips/pm435-manual.zip
In case you dont have the book still. Good luck.
Any drama, get back to me here.
regards
Graeme
Posted on Jan 28, 2008
IrishDruid
  • 2712 Answers
SOURCE: hisense remote does not work with hisense tv
You can find the remote control codes for different brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
freetek
  • 5568 Answers
SOURCE: need codes for rca universal remote rcr312w. for apex tv
With your model number at hand, check the RCA website for a later code list. If you are the exception, you might find one.
Most all remotes have a 'search' function that lets you scan through all of the available code sets but this feature will, in most cases, provide only minimal functionality such as Power, Volume and Channel.
In truth, there isn't any such thing as a 'universal' remote, including the 'learning' remotes; I have one of those and it is unable to 'learn' from either of my later sets' remotes. At best, these should be called (honestly) 'multi-brand.'
Posted on May 17, 2009
SOURCE: Broksonic TV code for RcA RCU704 remote control
I had a similar problem with a 1994 vintage Broksonic TV. I called the company (Hatzlachh Supply Inc. @ 800-333-9099). Broksonic TVs are not compatable with any universal remotes! You need an original factory remote. Remote for my set cost $20.00 plus shipping for a total of $24.95.
James Benson
Posted on May 27, 2009
Hisense tv
so whats the remote you have there?
Oct 23, 2008 | Hisense TA42P40M 42 in. Plasma Television
Need sansui 076k0ut011 led tv remote codes to program an rca tv
reset sansui tv remote control 076k0ut011 Questions ... - Fixya
www.fixya.com > Forum > Tags
...your help in advance. need code for a one for all URC-2060B06 sansui tv try these ... ...sansui tv with a RCA 704 remote control I have sansui tv and a RCA 704 remote ... URC-3021 Remote Control: How do i program this remote to a sansui tv? ... TV Remote Controls Sansui Remote eBay NEW Orion Sansui JVC LED TV ...
reset sansui tv remote control 076k0ut011 Flat Panel ... - Fixya
www.fixya.com > ... > Tags > reset sansui tv remote control 076k0ut011
Flat Panel Televisions reset sansui tv remote control 076k0ut011 questions and answers. ... ...sansui tv to program rca remote to it model # HDLCD1955C need tv code for this model ... Question about Contex 39-inch 1080p LED TV LE39D3.
Original Sansui - Orion TV Remote Control 076K0UT011 ...
? 1:00
https://www.youtube.com/watch?v=mPbRsUI0xnk
Dec 21, 2012 - Uploaded by ElectronicAdventure
Original Sansui - Orion TV Remote Control 076K0UT011 - Save $5 with ... have the New Original Remote ...
[PDF]Operating Instructions For 4-Function Cable
Dec 16, 2015 | RCA Televison & Video
Tengo un control Rca Universal y necesito los codigos oara una tv Hisense.
If you have a universal remote, you can use its code search feature to seek a suitable code for your Hisense TV. If you search through all codes stored in the remote without success, you may have to try another programmable remote.
Oct 07, 2014 | RCA Universal Remote Control
Hisense remote control manual
Try doing a google or other search, download a manual, code are far to extensive to post here
Jul 29, 2014 | Sony Hisense En-31201a Lcd Tv Remote...
I need a remote control code for a hisense tv
Hello
Four digit universal remote codes for Hisense TV are:
0073 0182 0216
Five digit universal remote code for Hisense tV with RCA RCR312W remote control is:
10748
Sep 14, 2012 | Hisense LHDN32V66AUS 32 in. LCD TV
Need a universal remote control code for Hisense tv
Hello
0073 0182 0216
10748
Dec 12, 2011 | Hisense LHDN32V66AUS 32 in. LCD TV
I need the code to program a rca systemlink3 remote for a hisense tv
0748...but if its like mine it wont work. these HiSense remotes are JUNK!!!
Aug 17, 2009 | Televison & Video
Rcr451 rmote
My list only shows one code for that TV, 190. I'll keep digging though.
Mike
Mar 29, 2009 | RCA RCR450 Remote Control
I bought a rca universal remote that the code rca supplied for my
do a code scan read the manual it will show you how to do this
Mar 29, 2009 | RCA Universal Remote Control
Televison & Video Logo
360 people viewed this question
Top Televison & Video Experts
