The only color i have is green and purple. both the tv and dvd
  • mikebernasco Jun 27, 2009
    unplugging and plugging in again after 3 hours didnt help.
    this is a fairly new tv
    i am not familiar with this convergence thing you talk about
    on the menu on the image>picture=adjust brightness,contrast,color,sharpness thats all and have minimal effect
    tv is mitsai 14CBN07DX
  • 297 Answers
Solution:
Try this:
turn off your TV at the mains and unplug it for at least two three hours after that time power up your TV it should degauss the tube at power up
If not:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
Everything you need to fix it yourself. Its a fairly easy fix.
Posted on Jun 27, 2009
  • sabharish
    sabharish Jun 27, 2009
    I was talking generally for projection TVs. Tell your model and make please?
  • sabharish
    The color has gone crazy on you because your
    convergence IC's have gone bad.
    These operate at a very high
    temp, and usually only last 4-5 years.
    If you remove the
    back of the set, you will want to look for the BIGGEST heatsink in there, on
    that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-150's
    you can go on ebay to order the new ones, but MAKE SURE they are Genuine IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
    You will also need some "Heat transfer paste" - you can pick
    this up at radio shack.
    Once you remove the old IC's, test
    all the large resistors near them.. pull one side of the resistor out of the
    board so you can check it out of circuit. they will usually have the value in
    Ohms, printed directly on the resistor, but you may have to use the resistor
    color code to find out what value they are....However, usually if there is any
    damage, the resistor will look like it has been HOT or fried. replace the IC's
    and any bad resistors, and you should be good to go.
    If
    after replacing the IC's and any defective resistors, the convergence is still
    bad, make sure to use a multimeter to check ALL fuses on the boards, ---
    sometimes when the IC's go, they will take out a fuse to the convergence power
    supply. If you find any bad fuses, replace them accordingly!
    Hope that helps!
How do I repair the color on my Samsung LCD TV. I can still see the picture but 3/4 of the TV goes green/purple/pink and the bottom 1/4 has normal color.
The T con Board or the LCD panel is faulty. Can confirm by replacing the TCON board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
May 28, 2016 | Samsung Televison & Video
SAMSUNG LCD 550 SERIES TV COLOR GREEN AND PURPLE
Sounds like t'Con board fault. Contact any service technician to make it confirm.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, screen faults & possible causes to LCD screen are given with illustrations.
Jul 29, 2014 | Samsung Televison & Video
We've had the Sony DAV DX150 for a few years and now all of a sudden when we play a DVD the color is all messed up. It displays in mostly greens and purples. If we adjust our TV settings, by putting the...
Hello ,im curious as to whether your using component cables from the dvd to the tv (red,green,blue) if so than i suggest you check those because it sounds like your missing a color,check the red cable specifically.
Jan 18, 2011 | Sony DAV-DX150 System
My Sony DVD player is only showing colors in green and purple hues. Could it be a connection problem?
Yes. Could be the color signal jacks in the back. Make sure you have them plugged in properly, green for green, blue for blue, and red for red.
Jan 06, 2011 | Sony Televison & Video
The color seems to be off. No red, and lots of purple. This is a Toshiba 57H81 wide screen big box tv. It was purchased in 2002.
Could be a bad board within the tv but it is sometimes the source input meaning it could be dvd player, cable/satellite box, etc causing the loss of color but it is unlikely. I have one of these tvs and they use red green and blue projectors to reproduce the colors so when the red projector fails then you get purple which is green and blue colors combined without the red. I have found it to be sometimes a bad connection inside the tv and I found insects such as roaches inside others. Using extreme caution when opening the rear cover of any tv due to dangerous and fatal high voltage. You might find that simply cleaning out the inside of tv and reseating all the connectors might resolve your issue otherwise you would have haul this tv to a repair shop where you pay half the price of a new flat screen lcd for just repairing this tv which will probaly have another color go out next month.
Aug 15, 2009 | Toshiba 57H81 57" Rear Projection...
No green color in Sony Wega 55inch TV
the green tube is out on the tv call a repairman in and get it fixed or youll miss the superbowl unless you want to see it all in purple...call a tech...
Jan 28, 2009 | Televison & Video
I am trying to connect my portable DVD player to the TV in my hote; room. On the back of the TV there are red and white connection for the audio but not a yellow for the video. I have audio and i have...
You're connecting to an HD connection that's why you are seeing the purple and green.
You should have 3 composite inputs, ie. yellow, white, and green on the back, and on the side in addition to the HD ones you are currently plugged into.
Jan 25, 2009 | Philips Magnavox 51MP392H Rear Projection...
Color has degraded, not much white, or green
Since yo're getting a good picture from DVD then TV is OK. Replace (reset it first) the box.
Jan 25, 2018 | Panasonic CT-36D30 TV
Toshiba 24"TV VCR/DVD Combo
Hello firstly switch the tv off at the wall socket and leave overnight, If the fauld still there in the morning then the degauss thermistor inside the tv has failed and requires replacement.
Jan 16, 2008 | Toshiba MW24F51 24 in. TV/VCR/DVD Combo
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
