Question about HP Compaq Presario F730US Notebook
Presario F700 ... Wont boot up, Turns on & then off ... That's it ... Anybody got any ideas on why it does it ...
  • 7 more comments
  • Josh Scott
    Josh Scott Jun 27, 2009
    Right away, As soon as the power light shows it shuts down. Every now & then it will boot up. But once you power it down or have to reboot it starts doing it again.
  • Josh Scott
    The fan always kicks on. I have tried replacing the ram too. Dont have anything to check the CPU itself. But it wont even boot up to bios, so i can not get into safe mode. I am running out of ideas here ... :( ...
  • Josh Scott
    I can not even get it to boot up now ... I tore it back down to the mother board again. It has the power supply & the cpu, fan & ram ... It should load up to at least bios & it still does not load up. Since it will not load, how would i check the power or the temp ? ... The fan is working. I have IM if anybody would like to chat with me that way also, Just let me know & i will log in & post my ID ... Thank you for your help ...
  • Josh Scott
    That is what i was doing, I got the Fan, CPU, Power, Mother Board & External Screen hooked up & still not able to power up. I unhooked everything else already.
  • Josh Scott
    i know alot about computer & all but i not sure how to check the bus or cmos. Could you please tell me how to do that since i can not boot up at all to check anything ??
  • Josh Scott
    Ok, I tried it ... Still doing the same thing. It looks like i might be out of luck on this one ... Never had a computer / laptop that i could not fix. Guess there is a 1st time for everything ...
    Thank you for your help.
  • Josh Scott
    Thank you again
  • Tharinda
    Tharinda May 11, 2010
    It might be due to a RAM or processor/fan failure or due to a OS failure caused by recent software or a driver or a Virus. Check your OS first. Go to bios and check the Temperature. Before the machine start windows, when u just started, press F8 and go to safe mode. If u can access windows , means if u are able to boot from the safemode, that means you have a service or a driver failure. Right Click on My Computer Icon and get manage. From there, go to device manager first. And check whether there are any issues with those devices. If there is any failure, that will be indicated in a yellow question mark or a red X. Then click on Event Viewer Check for System and Application events (and security events if u have set policies to shut down the PC if security checks fail or logs are full. Remove any newly installed software and updates. If this is helpful to you please kindly rate the answer. Have a goo day. Thanks :) Hope this would help
  • Jorge Majano May 11, 2010
    how long till it turns off?
Had the same problem. In my situation it was related to the Graphics processor. Remove the memory access cover and apply firm pressure on the corner of the simm socket and see if it starts / boots. Also try downward pressure from the top side left of the touchpad. If it works then you need to put a shim on top of the GPU chip (between the plastic base and the GPU). I used an old rubber foot from an old case. Reassembled... so far so good. Note: if you look at the GPU you'll see that it's glued in addition to being soldered. A manufacturing "fix"... obviously a known problem.
Posted on Sep 07, 2009
  • chrisper67 Oct 01, 2010
    I agree... had the same issue with my f700. The GPU had to be soldered. Seems to be working fine now. Only time will tell. Checked with the guy I had fix it and he said it is a common problem with Compaq laptops. Don't know if it is from the heat from the battery, but it gets extremely hot when used continuously.
My daughters F700 was working OK and the next time she went to wake it up it wouldn't boot!
The HD light would flash once and I'd hear it grunt twice. The fan would start and almost immediately stop. The screen was absolutely BLACK.
I tried all of the remove the battery and power adapter hold down the power button tricks to no avail. Including taking out the RAM and also disco the BIOS battery.
Nothing worked. What saved me was a comment by one responder, that he just left it on. The trick is to get it to stay on. I did by putting a restore disk in and it seemd to stay powered up.
I went away for about 20 minutes or so and was sitting at my desktop and heard things happening with the laptop.
When I checked I found it still with a black screen, but the fan was now running constantly. I took out the startup disk and tried doing a keyboard reboot. NO DICE!
I then held the power switch until the laptop shut down. I waited a respectable 3 to 4 seconds and powered it up. Lo and behold there was the BIOS setup screen. I hit F1 to proceed and was sent to the SAFE MODE select screen. I chose Normal Startup and the laptop booted up and worked.
I chose to go into the control panel and disable sleep mode for both battery and powered modes. Naturally I will never select sleep or hibernate when I shut down either.
The trouble with this situation is for all intents and purposes, you would consider trashing the computer.
Hope this helps. JOHNNYBOY
Posted on Dec 01, 2009
I've got the same laptop, with the same experience and so have numerous others on the web. I've resigned that the only possible solution is to replace the motherboard, and I've waited about five months hoping that HP will offer extended warranty on this product.
Hasn't happened yet to my knowledge, and ordering a MB from Hong Kong will cost me about $200. Which may not even be a long term solution, if there is something about the laptop causing the problem that will fry the new MB. So my only recourse may be to boycott HP and steer anyone I can away from them.
Posted on Jul 14, 2009
  • 428 Answers
Mmm then the most possible problems would be either the system is unable to load data from cmos or a power problem. Did u check the heat of the CPU. Does it get enough power? did u check the power device? That has to be done first. As I feel its related to non other than the power unit or the switch circuite. And there may be a leakage. Check the switch whether it gets clicked twice. Or some thing similar to that signal.
Check the speed of the fan (when its started).
Check it and comment again.
Let's solve this sonner.
Posted on Jun 27, 2009
  • 4 more comments
  • Tharinda
    Tharinda Jun 27, 2009
    It might be a problem with *********** board CMOS chip which is unable to load the hardware settings.
    Check whether there is any jumper shorts.
    Connect a device by device and check when the system fails.
    You can tell ur IM, we are not allowed to provide any info :)
  • Tharinda
    Seems u hv to check the mother board. bus and cmos.
  • Tharinda
    Yes a difficult question to answer. U have to have tools to check cmos and bios. We can not check busses. One thing I forgot to mention. Did u also check ur vga? Sometimes on-board vgas also gives a similar trouble. I think U have to go to a hardware service provider to check ur cmos. Did u check the battery also. Boot without the cmos battery. Make sure that YOU HAVE NO JUMPER SHORT AT THE STARTING SWITCH CONNECTORS (which will be connected to the start button). What u have to do is remove the wire connecters to it and start the machine by shorting the circuite. Most of the time there will be three pairs or fourre pairs of connectors to connetc start switch and reset switch together with the indicators.
    Try to boot like that.
  • Tharinda
    :( I feel so sad for u Sir. But what to do. Those are machines. Try to go to a hardware service provider and check ur motherboard.
    Its a pleasure to help u. Wish U luck.
    TC :)
  • Tharinda
    Ur most welcome Sir
  • jangdavis Sep 14, 2010
    •LASITHA-VEGA : Connect a device by device and check when the system fails
    --can you tell me what kind of devices ? and any orderly sequences ?
My HP Presario F700 recently started showing a recource conflict on motherboard while starting up. In addition the DVD-drive is not recognized even it does a self test. Any idea?
there might be 2 problems that come first in mind
1: due to long time pc explotation bios battery died
2: bios reseted and all divices become masters
firs test battery voltage ir its good try to change bios boot up log
Jul 29, 2014 | HP Compaq Presario F500 F700 and G6000...
Presario F700 Laptop.. Wont boot up, turns on and then off... that's it
clean the lint and, hair out of the laptop fan: got cats/dogs?
Feb 04, 2013 | HP Compaq Presario F730US Notebook
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Dec 29, 2012 | ASUS K52n-a1 Notebook
F700 it turns on and off in continuos loop nothing except a black screen. any ideas?
look into bios check if the hd or cd is booting........not a network boot.......o network no boot
Dec 02, 2009 | Compaq Presario Notebook
Presario wont turn on. its an f500, i turn it on and it immediately turns off, screen wont come on...im assuming i need a new battery? want advice before i purchase the battery!!
Remove the battery, plug the wall adapter in and try to boot. If it works, the battery is the problem. If not; is the green indicator on the power brick on? If not, replace the power supply brick. If all the above is ok, the problem is internal and I would be guessing without testing.
Jul 25, 2009 | HP Compaq Presario F500 F700 and G6000...
Compaq Presario F700 wont boot. Powers up then turns off again a
that means you might have a hardware failure. possible powersupply. check with local shop.
Jun 17, 2009 | HP Compaq Presario F730US Notebook
My compaq presario F700 won't boot up.It keeps
seems that same System Files have been damaged. Try starting in Safe Mode or use the Recovery Console from the windows disk to repair the OS.
Jun 05, 2009 | HP Compaq Presario F730US Notebook
HP Compaq Presario F730US Notebook Logo
5,869 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
