Question about Vizio L32 32 in. LCD HDTV
Channel Button does not work on the remote or the tv
Every button works on the remote and the tv but the channel buttons. What can I do about this?
  • 57 Answers
Micro buttons of chanel defctive on tv,check
Posted on Jun 27, 2009
My Channel Up button is stuck changing the channel. How do I fix it
Is this on the remote? On the TV?
If it is the remote, replace it.
Mar 30, 2014 | Westinghouse Televison & Video
Sony TV channel stuck on 56 I need it on channel 3
Doesn't Channel + & - button work?
Let me know to guide you more.
Oct 27, 2008 | Televison & Video
How do i get the tv on av without using the remote?
push channel down button through the channels, then it will go into av mode(video) by just keeping to press channel down. it will be channel below channel 02. just keep pushing channel down button
Nov 21, 2009 | Beko 324250WN 28" TV
Remote code for Sabre TV on Cox Universal Remote
I had the same problem and I found out that the philips universal remote works! What you will do is follow the instructions in the book and your channel will change to the same channel. The instructions are: Hold the select button for about three seconds and click the TV button. After this you will hit the channel button until the channel on the TV appears in the upper right hand corner. After this you will hold the mute button for about 3 seconds and the release. This should work! Hope this helps you out!!!
Mar 31, 2009 | Televison & Video
Channel button on tv and remote control dosent work
The channel buttons on the tv and remote only navigate through the channels programed into the tv. You will need to go into set up and scan for channels or manually add channels you wish to receive.
clarkco
Mar 07, 2009 | Vizio GV42L 42 in. LCD Television
Thanks but i need more help
Don't be panic.
Check the batteries of your remotes control. FIRST
Be sure to aim the control to the sensor of your tv.
Usually you have one remote for your tv and the other to control the cable box or digital box.
You have to set the RMC10 again using the code of your tv Silvania (like the first time)
Then set your tv on channel 3
Another thing, be sure that you are hitting the right buttons.
The control doesn't work if you hit on the top any key instead of cable
What i mean?
The remote has on the top 4 key usually (tv, cable, vcr, aux, etc).
You must hit first cable to set the control to cable
1, Manually turn on the device(TV, VCR, etc.) to be controlled.
2. Press and hold the code search button until the red indicator stays on, then release the code search button.
3. Press and quickly release the desired mode button (TV, VCR, ect.). The red indicator blinks off once.
4. Press the Channel up button repeatedly(up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press channel down button to backtrack through the library until device changes channel. Pressing Channel up changes direction forward again.
5. Press and release Mute to install code.
Don't forget to rate my help!
Thank you for using FIXYA!
Have a great day!
Pablo :-)
Let me know how it is going!
Oct 18, 2008 | Electronics - Others
Remote not working on TV
Try programming with Code Search:
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 13, 2008 | Philips Televison & Video
How to set codes on my px-rc1 remote
Hey finally I found myself how to set the code... I have a PX-RC1 kind a noname remote at XScargo anyway...
Press SET BUTTON and at the same time, the appliance you want to set( TV, VCR,Aux...etc). The LED shoould stay on.. then press on the SET BUTTON again ... the led will blink fast... then press ( in front of TV, of else).. the POWER BUTTON to see what happens, if nothing happens, then press the +CHANNEL BUTTON once, and press power again. Repeat this until it turn off. THen press the appliance button (VCR,TV,AUX, etc...), this will stop the LED to blink and your appliance will be set.. I guess if it doesn't work good, go further onto the code with the +CHANNEL BUTTON (better count it in case you go too far, for myself I went too far and tried to use the -BUTTON and didn't work)
GOOD LUCK GUYS,
May 18, 2008 | Universal Remote Control MX-500 LCD Remote...
Polaroid remote channel button does not work
This looks to be a good hint. After reading the solution "I had the same problem. The fix is actually very easy. Just re-tune your channels in and your remote/channel buttons should work again.", I checked my remote and saw that there was a sliding button "TV/Cable" and it was on "Cable"
I moved it to TV and it started working.
This could be a dumb solution but just wanted to suggest...
Dec 06, 2007 | Televison & Video
Front controls mixed up & remote doesn't work
the channel down button is stuck on, you need to replace this switch internaly to the set.
Nov 14, 2006 | Sony KV-36FS100 36" TV
Vizio L32 32 in. LCD HDTV Logo
204 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
