Question about Jensen Car Audio & Video
I installed my Jensen VM8013 today and it was working fine for about 3 minutes, As soon as I turned up the volume it died. I didn't hear any pops or noises. Now it don't work. All fuses have been tested good.
    Problem Solver:
  • 8 Answers
It's a jensen that preaty much says it all.It proubly blue up.
Posted on Jun 27, 2009
  • AS123 Jun 28, 2009
    Just trying to tell you how it is.Just remeber you'r the MORON that paid for a jensen.
I hooked it up but when i turn it on it flashes and turns back off, like on stand-by, do i need to something else??
if you can get video to play use the parking brake wire and put a toggle switch on it from ground on and ground off;;
Oct 01, 2015 | Jensen Vm8013 In-dash Dvd Receiver With...
I have a Jensen unit model vm8013 went camping and my battery died. After that the radio would not come back on tried everything need help.
When you disconnect your battery and then reconnect itagain, it disables the radio. This is an anti-theft protection for your carradio.
The enable your radio the activation code is in your vehicle owner's manual. Ifyou do not have this code you need to go to your vehicle manufacturer's servicecentre and get them to enter this code for you.
Jun 02, 2012 | Car Audio & Video
YESTERDAY MY VOLUME WAS WORKING FINE, TODAY I CANT HEAR ANYTHING, CAN U HELP ??
click right mouse click harddware -divece manager look sound option (speaker sign} if not stall u can see yellow sign,install sound by using ur board cd. 2/ go run type control click sound andaudio option then u can get volum/sound/audio/voice/hardwer option check if incorrect correct it .3/ look ur speaker's volum is off or not? what u keep volum on mute or not? ..... thanks
Jun 13, 2009 | Compaq Armada E500 Notebook
FM Reception with Jensen MSR3007
I have the exact same problem with the exact same stereo. I started by removing the in-line AM/FM/VHF Separator and connecting the antenna directly to the stereo. The static/popping/fade-out continued. Today I swapped to a new antenna, but it did not help. I swapped back to the original antenna and for a brief while, I had good reception. The I went to coil the excess antenna cable and the static/popping/fade-out resumed. I have narrowed it down to either the antenna connector coming out of the back of the stereo or an internal circuit. Either way, it does not look like a do-it-yourself fix.
May 31, 2009 | Jensen CD400M CD Player
Vehicle will not start
check for fuel and spark
Apr 16, 2009 | Jeep Liberty Cars & Trucks
Won't turn on
Try unplugging it for five minutes then replug and see if it will turn on. These things are funny like this sometimes.
Feb 12, 2009 | Vizio L32 32 in. LCD HDTV
Sound
By no means is this a solution, only a comment - Internal Amplifier is bad. Check your wiring before installing another unit.
Jan 12, 2008 | Jensen CD4610 CD Player
Jensen xcd 9120 car cd receiver
To set clock:
Press DISP button. Within 3 seconds press and hold BAND button and press TUNE+ (plus) to change minutes, TUNE- (minus) to change hours
Jan 05, 2008 | Jensen Car Audio & Video
Jensen vm9311 dvd indash volume is loud when i turn on car
Heres the best way to fix; Quote from manual "Programmable Turn-On Volume (Pg.12) This feature allows the user to select a turn-on colume setting regardless of the colume setting prior to turning the unit off. To program a specific volume level, push and hold the VOL/LOC/DV know (6) while the yellow volume bar is displayed on the screen. The unit will beep two times to confirm your turn-on volume setting." Ah i had the same problem. I turned to the manual and it worked for me :) Good Luck, Ern
Oct 23, 2006 | Jensen VM9410 Car DVD Player
Car Audio & Video Logo
194 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
