Question about Sony STR-DG820 Receiver
Brand new sony str-dg820 7.1 sub woofer problem
Brand new sony str-dg820 7.1 and i have absolutley no sound out of my subwoofer. it is so frustrating. does anyone have the secret? please contact me.
    Problem Solver:
  • 8 Answers
Did you turn on the sub out put?
Posted on Jun 27, 2009
How to change the connector on subwoofer of coby 5.1 cs-p92 so that it can play with Sony str dh750 receiver
Before you cut any wires, make sure the sub woofer can handle the power from the Sony. Is the sub powered? What are speaker specs on the Sony . Is the output jack on the Sony meant for an unamplified sub? You have to know the answers to all this so you won't blow up the Sony and/or the sub woofer
Aug 21, 2016 | Sony Audio Players & Recorders
Can I and how do I hook a subwoofer to my Sony str-de705 receiver
It depends. You can connect an active (self-powered) sub-woofer to the STR-DE705. You can't connect a passive sub-woofer that needs power from the receiver. If the sub-woofer has its own power cord, then it's an active unit. See https://us.en.kb.sony.com/app/answers/detail/a_id/37001 for more information. You'll also need a RCA subwoofer cable. This is like a RCA audio cable but only has one plug on each end. (Using a regular audio cable may risk a short when the extra plugs hit something.) Many subwoofers will come with the audio cable. If you do need one, they are available at most places that sell cables, including Amazon.com .
Here is an example of an active subwoofer: https://us.en.kb.sony.com/app/answers/detail/a_id/37001 . This is the Yamaha YST-SW012.
I hope this helps.
Mar 15, 2016 | Sony Audio Players & Recorders
New sony receiver str-dh740 has 2 RCA plugs for sub woofer. How do I connect to psw350
only use one of the outputs from the rear of the str-dh740. and use a rca "y" adapter where you plug it into the subwoofer so that both of the inputs on the sub are getting a signal.
May 11, 2014 | Polk Audio PSW350 Subwoofer
HELLO HOW TO CONNECT SUBWOOFER TO SONY
It would depend a lot on what type of subwoofer you have and it wouldn't be pretty.
According to the manual I found it doesn't have a Woofer Output so it isn't designed to route Low Frequencies anywhere.
Even if you rigged an Active Subwoofer to it using the Tape Output you wouldn't have central volume control for it unless the (unnamed) Sub was driven by speaker-level outputs from the Front A or B Speaker posts on the receiver.
Your question would be better framed and answered if we knew the details of the Sub and referred to ITS manual.
Apr 10, 2010 | Sony STR-DE315 Receiver
Connecting a Sony Subwoofer SA-W2500 to a STR DE 598
It is based on your sub-woofer type..whether powered or passive sub woofer..
Assume that you have powered one..RCA sub woofer jack is the best to feed it ..you should use RCA sub woofer output on your receiver as well..good luck
Jan 08, 2010 | Sony STR-DE598 Receiver
No subwoofer
Make sure you have sub pluged into the sub pre out and not the six channel input.
CABLE GUY.
May 09, 2009 | Sony STR-DE475 Receiver
RCA Sub-Woofer
Did you try making sure the subwoofer is turned on under the set up menu on the Sony Receiver?
Press Set Up, Press the left or right button above the scroll wheel until you get to SW. It should say SW: ON or SW: OFF. If it says SW: OFF, use the Scroll wheel to scroll right until it says SW: ON. Also, make sure you aren't in 2CH mode, try A.F.D or surround sound.
Jul 26, 2008 | Sony STR-DE445 Receiver
Open Questions:
See all Sony STR-DG820 Receiver Questions
Sony STR-DG820 Receiver Logo
403 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
