Question about Lexmark X73 All-In-One InkJet Printer
Printer not printing because it says that it is offline
I have a mac and a canon mx310 printer and fax. when i go to print it tells me that the printer is offline. how do i fix this
  • 527 Answers
Sir,
please click on your startmenu.
click on settings, and then printers.
do you see your printer in the listing?
Thanks Good Luck
Appreciate to rate as "Fixya"
Posted on Jun 27, 2009
Wont print anything, keeps saying printer offline, checked everything is plugged in properly
my mx310 only has fax option, no printer options. Do I have my properties wrong?
Jan 19, 2011 | Canon PIXMA MX310 All-In-One Printer
Printer says it is offline
Hi!
1. Make sure the printer is correctly connected and powered on.
2. Right click the printer icon (in Printers and faxes) and select "Use Printer Online".
Best regards,
Pelu.
Jun 04, 2010 | Canon PIXMA MX310 All-In-One Printer
Cannot receive fax. It goes into memory. LCD reccomends new B-CRT regarding my Canon PIXMA MX310 printer . No problem sending fax,copying or printing.
B-CRT is just asking for a new black cartridge, fax will not print until it's replaced so you don't get a partial fax that you can't get back after printing.
Nov 05, 2009 | Canon PIXMA MX310 All-In-One Printer
CANON PIXMA MX310: printer not responding.
If you go to Start, Printers and Faxes, if it says "Offline", right-click the printer and choose "Use Printer Online." If it says Ready, you should be good to go.
If however there is a problem yet, double-click the Printer there and see if any jobs are in the print queue. You can remove them all buy Right-Clicking and choosing "Cancel All Documents" then try printing a test page. Right-click the printer, go to properties and click "Print Test Page."
If you still have problems, follow up on your question.
Aug 29, 2009 | Canon PIXMA MX310 All-In-One Printer
Color printing
If your using windows OS go to control panel , then printer and fax icon open it you will see canon printer series listed right click on it and go to printing preference tab ,check print all documents in black and white click okay and then try to print....
Good luck...
Feb 26, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannon MX310 - Fax - Waiting for report
I had the same problem.
My INK Level was Low and I had the setting "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink OFF", and so the report would not print due to the ink level being low.
Solution:
Configure "Fax Setting -> RX Setting -> Auto Print ON -> Print when no ink to ON", and the report will be printed immediately, and the message will disappear.
Jan 20, 2009 | Canon PIXMA MX310 All-In-One Printer
Canon mx310 feeds paper w/out printing
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 09, 2009 | Canon PIXMA MX310 All-In-One Printer
Cannot print from Apple MacBook to Canon MX310
First, check your USB printer connection to your Macbook from your Pixma MX310 printer.
If the USB cable is securely seated, make sure you have installed the updated drivers for your version of Mac OS X. Here is the Link:
Canon Pixma MX 310 Drivers for Mac OS X (v10.6/10.5 and earlier).
If you have already updated your printer drivers to the most current Canon Pixma update for your version of Mac OS X, then click on the Apple menu icon, located in the upper left corner of your screen and select System Preferences.
• From System Preferences, select Print & Fax.
• Within the Print tab, make sure you can see your Canon listed in that window.
If you can, proceed to perform a test print on any document you have on your desktop or folder of choice. If this does not help, from within the Print tab, select the Canon and press the "-" Minus button and remove that printer.
• Once it is removed, now click the "+" button
and re-add your printer.
• Once it has been added, attempt to test print again.
This should help get your printer back to printing again.
Regards,
-Mactechtrainer
Dec 02, 2008 | Canon PIXMA MX310 All-In-One Printer
Can't print to mac wirelessly (could do it a few days ago)
I had the same problem until recently. You have to install the drivers FROM THE CD that came with the printer, instead of selecting the drivers from the default list. Then, when selecting which printer driver to use (you'll have two options) choose Canon IJ and NOT Canon MX310 series. This is a problem with their MX310 driver, which is solved using a default/generic Canon InkJet (hence, the IJ) driver. Hope this helps!
P.S. This only works on Mac OS X. I have yet to figure out how to print wirelessly through Vista. Will keep you posted.
Mar 28, 2008 | Canon PIXMA MX310 All-In-One Printer
Lexmark X73 All-In-One InkJet Printer Logo
262 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
