Question about HP Compaq nx5000 Notebook
How to repair the monitor of the compaqnx5000 model
  • Ghulam Rasool Sep 01, 2009
    For nx5000 laptop basicallly it was not loading the either net driver I updated its bios now its showing that its hard drive is locked. Now i am helpless and cant do anything please help in this regard if any body having good idea about it
  • 3 Answers
The nx5000 has a notorious problem for the monitor going out, sometimes it flickers and sometimes it just doesn't show anything at all. the problem is often easily fixable in less then 20 minutes.
the cable that connects the computer to the monitor comes unplugged on the back of the monitor.
you will need to disassemble the monitor to do this fix, don't worry it is easy.
get a Phillips screw driver and a small flat screwdriver and use the flat to pry off the 5 round rubber plugs on the front of the monitor.
next use the Phillips to remove the 5 screws.
next use the Phillips to remove the 4 screws on the edge of the screen.
next using caution pry pull or rip the inside bezel off from around the screen, there is double sided tape holding it to the screen. careful not to break or disfigure it.
once you get this off there is 4 screws into each hinge at the bottom of the screen. remove those.
now the outside cover will be completely lose and dangling by the wi-fi antenna cable.
now the connector on the back of the monitor is exposed and in many cases it looks like its is only half plugged in, plug it in all the way until it is even and turn the computer on, see if this fixes your problem.
you may put a piece of tape to help hold it in but i doubt it would really help.
reassemble in reverse order, be careful to route the wi-fi cables through the little opening or they will be pinched and your wi-fi will no longer work.
it may not happen again for years or ever, it is possible that some joker working at hp was lazy and left hundreds of these only half plugged in, or did it intentionally.
Hope this helps.
Alan
Posted on Jul 18, 2009
  • 527 Answers
What kind of repair?
Posted on Jun 27, 2009
I have a Samsung Sync Master 920 NW model number 920nw, model code LS19HANKBM/XAA. The Monitor will not turn on but the power button blinks. I have tried to bring it out of standby but nothing works.What...
This type of problem is caused by a failure of the filter capacitors on the power supply board. The board is easily repairable, you just need to replace the defective capacitors. It will require a little soldering but anyone can do it. Here is a link to a repair guide showing how to repair the board and what parts and tools will be needed to complete the repair. I hope this helps you out.
http://www.ccl-la.com/blog/index.php/repairing-the-samsung-920n-920nw-monitors/
Apr 12, 2013 | Samsung SyncMaster 920NW Monitor
Dell model no E198FPf LCD Monitor has agreen light but wont turn on
Your problem is caused by a failure of the filter capacitors in the power supply board, this is a common issue on LCD monitors. Here is a link to repair information for this model. You can repair the monitor by replacing the filter capacitors.
http://www.ccl-la.com/catalog/product_info.php?products_id=195
Jan 04, 2013 | Dell E172FP 17" LCD Flat Panel Monitor
E173fp screen black
The most common problems with these units are caused by bad capacitors in the power supply board. Here is a link to several repair guides that cover the different E173FP models. You can determine which model you have by looking at the last letter of the model name it should either be c, f, or b
http://www.ccl-la.com/blog/index.php/category/monitor-repair/dell-monitor-repair/
May 29, 2012 | Dell E173FP 17" LCD Flat Panel Monitor
Looking for information on repairing a dell monitor model #L17BNS. It simply died. I cannot find any info on that model on the internet anywhere.
I would recommend replacing the monitor, because it is usually cheaper to than repairing one. If for some reason you need to repair this particular monitor you can look up guides on general monitor repair. Most monitors run on the same preciples with just varying shapes and sizes of parts.
May 18, 2011 | Dell 17" Monitor
How do i dismantle L192WS LG monitor ? please help
We have a full disassembly and repair guide for this model monitor posted on our site at:
http://www.ccl-la.com/blog/index.php/lg-l196wtq-bf-lcd-monitor-repair/
I hope this helps, if so please rate our solution.
BuddyMc
Jan 01, 2011 | LG L196WTQ-BF 19" Monitor
Our samsung 214t will not display a decent image until it has been turned on and off a few times. Any thoughts?
You have a power supply in the monitor that is failing. This is a known issue with these great monitors. It is a simple 20 minute repair. We have a step by step repair guide for ts model posted on our site at: http://www.ccl-la.com/blog/index.php/samsung-214t-repair/ The repair involves replacing 5 small parts called capacitors. If you don't want to do the repair yourself we do offer a repair service for this model, the repair service runs $32 plus shipping.
I hope this helps if so please rate our solution.
CCL Tech
Corporate Computer
www.ccl-la.com
Oct 07, 2010 | Samsung SyncMaster 214T 21.3" LCD Monitor
No power for IBM monitor model 6332-4CE
Your monitor power section has been faulty. so pls repaired it from service center.
Mar 24, 2010 | IBM E74 17" CRT Monitor
The Power button on my monitor keeps blinking...and I can't see what's on the screen..one moment is white..one moment is black..what should i do?
The Dell E173 series have several different versions specified with a third letter the end of the model such as e173FPb, E173FPc and E173FPf. The different monitors have different repair procedures but you should be able to do the repair yourself. Go to our web site at:
www.ccl-la.com/badcaps.htm We have free step by step repair guides for several of the Dell monitors. Check the label on the back of your unit and check the corresponding repair guide for the instructions. If you don't see your model let me know at the email address below.
I hope this helps, If so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
tech@ccl-la.com
Nov 05, 2009 | Dell E173FP 17" LCD Monitor
LG Monitor L196WTQ when computer shuts or turns off
You have a power supply in the monitor that is about to fail. Check out his article on our web site about repairing this model - www.ccl-la.com If you can solder then you should be able to do the repair yourself. It involves replacing 6 small parts. If you don't want to do the repair yourself we do offer a repair service for $30 plus shipping. Let us know if you have any questions about the repair or the repair guide.
CCL_Tech
Corporate Computer
www.ccl-la.com
Nov 01, 2009 | LG L196WTQ Monitor
HP Compaq nx5000 Notebook Logo
141 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
