I have a intertherm model 9007590 AC unit. The condensing unit was changed to a unit that has a common wire and a y terminal and the old condenser unit had three wires at condensing unit. I can't get it to run and I think some of the wiring has been changed. I need to know how the low voltage wiring is suppose to be and if I need a four wire or five wire stat due to the condenser being changed. What stat do you recommend for this unit. Thank you.
  • thetim May 11, 2010
    ok red wire is 24volts goes to R,Yellow wire is the call for a/c goes to y, Blue is common that powers the t-stat. That is most of the time once in a while people change it up. How many and what color wires are at the a/c unit that are connected to the t-stat wire? Is it only a/c not a heat pump? was the disconnect ever pluged back in?
  • 52 Answers
The unit with3 wires was set up as a dual transformer the new unit is single transformer system. it needs to be rewired at thermostat,furnace,and ac
Posted on Aug 25, 2009
The condenser unit will not kick on...it is a concord unit,10=12 years old,13 seer,3 ton. The air handler works fine. I thought it was the capacitor. The old one was bad,I verified that with multimeter....
It could be a low refrigerant cut-out (switch), grounded or shorted motor windings, open internal winding overload protector (check at the common winding), a broken conductor, or no power at condensing unit from blown fuses or open/tripped breaker.
Aug 22, 2013 | Intertherm Heating & Cooling
My condenser fan runs and blows cool air but isnt cooling down the house. Any help.
Check the outdoor unit (condensing unit). Keep in mind, because the condenser fan is running it's not an indication that the compressor is working. On a split system,there's a dual capacitor that serves the fan and the compressor. The capacitor has three terminals.
1. common
2. fan = fan
3. Herm = compressor
This is a common problem; The outdoor fan (condenser fan) runs, but not the compressor (you have to know the sound of a running compressor or you'll mistake it for the sound of the fan) doesn't, because the compressor side of the capacitor is too weak to give it that needed phase angle that it requires to start. If you're referring to the outdoor fan spinning, but no cooling, I can bet the compressor isn't working and needs a new capacitor. Very common problem, I see it all the time. Before you change the capacitor, make sure that you cut the power to the unit, and then use an insulated tool such as a screwdriver and short the terminals together first. A capacitor holds a charge even after being de -energized.Buy the new one with the same exact rating written on it as the old one. Do not mix up the wires when replacing. Write it down or take a picture with your phone
Aug 20, 2013 | Heating & Cooling
Condenser fan motor
It would be easier to get the data from the condenser fan motor than attempt to match AC unit model numbers. If unreadable then remove the fan motor and take to someone to match with the one you have. That is what I do, Thanks Sea Breeze
Make sure you mark your wiring before removal.
Jun 14, 2013 | Intertherm Heating & Cooling
From the Isolator panel, how do I connect the condenser, and the blower?
MOST UNITS NOT HEAT PUMPS  WIRE UP WITH 2 WIRES TO CONDENSER RED WIRE AND WHITE . WHITE GOES TO COMMON C ON FURNACE AND RED TO Y TERMINAL OF FURNACE Y ALSO GOES TO Y ON TSTAT. BOTH YELLOW WIRES MUST MEET AT Y OF FURNACE.  WHITE FROM STAT TO W   GREEN FROM TSTAT TO G AT FURNACE IF YOU HAVE C ON TSTAT HOOK UP BROWN WIRE OR BLUE FROM COMMON TERMINAL WHERE YOU HOOKED UP CONDENSER WHITE WIRE AT FURNACE TO TSTAT , MOST THERMOSTATS DONT NEED C RUN FROM FURNACE. THE TWO WIRES GOING TO CONDENSER IS -  AND + TO ACTAVATE CONTACTOR IN OUTSIDE UNIT
Apr 19, 2010 | Ruud Central System Air Conditioner
Problems with low voltage control wiring turning on cond. unit
Only 2 wires going outside.
Yellow from the thermostat and the common wire from the lv side of the transformer.
Apr 28, 2009 | Heating & Cooling
Intertherm 3 ton ac unit I took the capasitor off to get a new one and forgot how to wire it it is not on the cover three wire fan and compressor three prong 55-5 capasitor help
The 55 terminal is marked "herm" it goes to the start winding of the compressor. The 5 terminal is marked "fan" it goes to a wire from the fan motor. The common terminal goes to one side of the power line...The side that is NOT going directly to the compressor.
Jul 27, 2008 | Intertherm Heating & Cooling
No y connection on furnace module to connect a.c. This is on a goodman model gmp075-3 furnace. I bought the b18099-13 replacement module and still no y terminal. I dont know were to land the t-stat...
"Y" terminal at the stat feeds condensing unit outside, common from the condensing unit to common on the furnace transformer.
"G" terminal on the stat brings the fan on for air circulation. In cooling mode "Y" terminal also brings the fan on. If this furnace was not A/C ready check the VA capacity of the transformer. Should be about 40VA. Make sure there is a fan relay to bring the fan on in the cooling mode.
May 01, 2008 | Heating & Cooling
Heating & Cooling Logo
208 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
