Question about Black & Decker Pivot Plus Cordless Drill/Screwdriver
It's stuck.... i've only used it once, and now i can't get the screwdriver bit out. i tried whatever the manual says but it doesn't work...
  • 47 Answers
I have had some cheaper bits get lodged in, try and use pliars to turn the bit opposite of the direction it was in when it was last used.....
Posted on Jun 27, 2009
Bedroom remote doesn't work
weak batterys wont hold codes on it huh?
Sep 24, 2012 | DISH Network Televison & Video
I try to connect a satelite to optical audio input for a digital radio signal. This doesn't work. Is it only possible to use a coax input cable for the radio signal?
The nature of whatever is on the upstream side of a digital signal is invisible to the device at the other end of the cable. Bits is bits, as we say. The undefined 'satelite to optical audio' device is probably at fault or not set right. PLUS, on theOnkyo you have to assign digital inputs. Read the manuals.
Aug 11, 2011 | Onkyo TX-SR501 Receiver
I have a 1970s huffy 3 speed. I've restored basically the whole, except I cannot remember how to take the crank shaft apart so I can see the condition of the spindle. Everything works smoothly;...
First you must remove the pedal on the opposite side of the sprocket it is usually reverse threaded so to remove you will turn it clockwise with an open end wrench. Then remove the jam nut (this nut locks the bearing retainer in place which is also usually reverse threaded). Once the jam nut is removed, using a large bladed screwdriver place it in one of the slots, tilt the screwdriver back and tap with a hammer (usually comes off pretty easy once the jam nut is removed). Slide the chain off the sprocket remove both the inner and outer bearing set. If the crank is hard to turn when riding the bearings are probably in dire need of grease. You can purchase a small tub of bearing grease from your auto parts store. Cover both bearing rings completly before reassembly. (Don't use oil)
Hope this helps.
Jul 11, 2011 | Huffy Cycling
Stuck flywheel, disposal will not run, humminf noise Model: GFC525F GE
something is stuck in it, the humming is letting you know that its stuck. assuming you dont have a disposal turning wrench try this. unplug the unit under the sink. using an old wooden broom handle,, place it inside the disposal , and try and turn the unit. once you free it up, use a flashlight to look inside and remove whatever is jamming it up. once this is done, plug it back in and try it again. if the humming has stopped and it doesn't turn on. at the bottom of the unit is a reset switch. push it in, and try it again ( turn off the power as you rest it)
Apr 21, 2011 | Kitchen Appliances - Others
I can't get the right rear brake caliper to compress for the new pad on a 2008 dodge grand caravan
do you know that rear pistons turn in frount ones compress in auto zone rents a tool for turning the rear pistons in
Jul 06, 2010 | 2008 Dodge Grand Caravan
Keyless chuck is stuck open
That can happen if the jaws inside the chuck, usually 3 triangular pieces get jammed together. With chuck facing down tap chuck several times to loosen jaws. If that doesn't work spray a small amount of WD-40 into chuck and try again
Feb 23, 2010 | Garden
Black & decker pivot plus bits are stuck
I had this problem too, an unfortunately, there's no manual on the black & decker site for this product.
I figured it out though! You have to push down (towards the motor) the chuck collar (cyllindrical black part which holds the bit). If you've tried this already, try harder - it can get really stuck and require a lot of force to push down.
Anyways, if you apply enough force, it will give and allow you to remove whatever bit is inside.
Hope this helps.
Dec 23, 2008 | Black & Decker Pivot Plus Cordless...
Black & Decker Pivot Plus Cordless Drill/Screwdriver Logo
792 people viewed this question
Top Black & Decker Drills Experts
JOHN LAPIER
Are you a Black & Decker Drill Expert? Answer questions, earn points and help others
