Question about Husqvarna Chain Saw 20" Bar
Husqvarna 141 piston ring, what is the required gap for the ring? Also, does it matter which way the piston is positioned in the cylinder, there is no arrow or difference that I can tell by looking at it.
  • gene1338 Jun 27, 2009
    Thanks remix001 however, my question was "how much gap should the piston ring have, or are they preset from the factory? and does it matter with the 141 which direction the piston should face, there appears to be no difference on either side."no arrow either"
    Problem Solver:
  • 8 Answers
It's been a few years but I've installed piston rings in many small engines. Many rings are beveled or rounded on the top outside to prevent excessive cylinder wear or scaring the cylinder wall. The bevel should be very slight and very hard so see. Some may have a small dot or marking cast into the ring near the end/split. If that is the case the ring should be installed with the marking turned toward the cylinderhead. Hint, lube the piston, rings, and cylinderwall before installing the piston. Gene
Posted on Jun 27, 2009
Piston markings or ring pins should face the exhaust port. not sure on ring gap sorry.
Posted on Nov 04, 2009
Ring end gaps for B&S 31P777 engine
If the engine the figures are required for is a re-ring using the original pistons it is important to check the amount of wear of the bore and of the piston groove clearance.
Once the ring gap is set to the minimum at an unworn part of the cylinder bore the gap should be rechecked at the most worn part and if the gap exceeds the maximum it indicates an excessively worn cylinder bore.
While this is not immediately detrimental it does mean the piston ring grooves will wear much more quickly and the job will have a shorter life and in some cases a high oil consumption can be worsened.
The piston ring groove clearance - side clearance between the ring and the piston should be 0.0015 inch maximum. It can be expected the top groove could be considerably worn and in that case new pistons would be beneficial or a Cord ring set.
Sep 11, 2017 | Cars & Trucks
I'm replacing piston ring on husqvarna model 240 chainsaw. I would like to know if bevel edge on ring ends face up or down on piston
Most 2 cycles have a pin in the piston groove that keeps the ring from traveling. The pin location (upper groove, lower groove position) will give you the indication. Most 2 cycle rings have an L shaped cut in the very end that mates with the pin in the groove. Otherwise the piston/ring assembly will not fit into the cylinder.
Mar 26, 2017 | Husqvarna Garden
Motorcycle is losing compression and noisy
if it is a water cooled engine the ring gap at the bottom of the cylinder should be around .010"
rings have to be installed the correct way up or the compression doesn't help push the rings against the cylinder walls for effective seal
piston skirts will touch the cylinder walls as the pressure pushes the piston to one side as it pushes the piston back down the cylinder
I have to ask did you put an old piston back in the new cylinder
was the new cylinder standard size or over size
what was the ring gap before you fitted them to the piston
did you use new rings or the old ones --maximum rin gap is .025"
rings don't wear in , just wear out
why did you replace the cylinder in the first place
was it because of low compression or taper wear
as silly as all this seams it is all very relevant to your question
Mar 11, 2016 | 2011 kawasaki KLX 250
Husqvarna 36 cc chainsaw wont start replaced spark plug cleaned carb
Are you getting a spark..? - NO? check wiring loom from ignition module, check timing gap between flywheel and ignition module, check on/off switch.
Does it have compression.? - NO? then check piston/rings and cylinder
Is fuel getting to the cylinder.? - NO? Carb problem of fuel line issue
Dec 06, 2012 | Husqvarna Garden
I am replacing the cylinder, piston, and ring on my 128LDX. What is the procedure for inserting the piston into the head?
You should be able to pinch the rings in with your fingers and slide the cylinder over the top, just make sure the rings are lined up with the relative locating pins on the piston.
May 16, 2012 | Husqvarna 2-Cycle Straight-Shaft Gas...
Husqvarna 250 Brush Cutter Piston and Head Scratched
the cylinder if it has small scuff marks can be honed out using a large brake cylinder honer in an electric drill
scratches on the piston can be removed using emery paper
the ring/ s need to be replaced
remember that the rings are pinned in position when being assembled to keep the eng gap away from the port holes
your statement indicates that it was run with out the correct oil ratio so check for big end and little end bearing coloring ( blue or tan color) before assembly
May 04, 2017 | Garden
Top handle, model # 2040 jonsered. is the same as what model # husqvarna
Husqvarna never used this model in there range, they used the same cylinder,piston and crank assembly in the 41/141 but all other components were different to the Jonsered, the part no. for the Jonsered top handle is 530038327
Aug 28, 2011 | Husqvarna Garden
Rebuilding 268 husky does it matter how the piston ring gap face , toward intake or exhaust port, and should i rougg old cylinder with steel wool?
point the ring gap toward nothing! in between exhaust and intake,......it would serve your rebuild best to bring the jug to a power tool shop where they can "hone" your cylinder properly,..your on the right track with knowing the need to "scuff up" the cylinder, but it should be done with the proper honing tool which is a grinding stone, your rings will love it, you'll actually notice a gain in power with the proper cut. have fun, cracklin joe
Jan 07, 2010 | Husqvarna Chain Saw 20" Bar
Need diagram of husqvarna 141
Not sure why you would need these! This is a really simple process. Remove bar and chain brake cover. Disconnect choke and throttle lever, muffler, and 4 screws with your allen wrench, i've never even attempted it before and just took my about an hour to complete the entire process. Just make sure to note how carb goes together, you can mix a few parts up if your not careful.
You can find aftermarket kits to with cylinder, pistion, rings and all for around $60-100.
Apr 30, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Piston rings
First, be sure they actually do fit the bore. Take a ring and insert it in the bore. push the ring halfway into the bore using the piston. There should be about a 1/32" gap in the ring. Anything more than 1/16" and you need rings the next size up. If the ring won't go into the cylinder because the gap fully closes, the rings need to be a smaller size.
With the correct size rings, put them on the piston. Some pistons have an index pin in the ring groove Fit the gap to the pin. Put the piston mid-stroke and place the cylinder over the top of the piston. Squeeze the rings closed as you gently tap the cylinder downward and over the rings.
Please rate this solution. Thanks garethholleb!
Apr 04, 2009 | Gilera Runner VX 125 Motorcycles
Husqvarna Chain Saw 20" Bar Logo
642 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
