Question about Asko 1385 Dishwasher
Dishwasher not filling
The nachine does not fill when put on any of the wash cycles, but it does on the rinse cycle. I think the drain pump is kicking in and deactivating tha circulation pump, as if it thinks it is about to overflow. Does anyone know if there iss a trip switch or float mechanism anywhere that may be stuck or can be re-set?
    Scholar:
  • 59 Answers
There is a new part that replaces the Overfill Pressure Switch part number 8058474. It is now part number 8071024 available from ASKO part sellers. The hose inlet on the new part has what looks like a blockage. It actually "dampens" the effect of the pressure sent through the small hose attached. The old part does not have this "damper" This pressure switch works in conjunction with the flood protection switch in the bottom pan of the dishwasher.
See my rant at
http://www.fixya.com/support/t216284-asko_dishwasher_1475_indicates_high
Posted on Feb 18, 2008
Gets stock in rinse cycle
Rinse cycles are usually with cold water. If it cant fill with cold water, it wont go through the rinse cycle. Make sure it fills with cold on a normal wash. You may find its filling with hot only. Alternatively, the machine may not be pumping out properly, this will cause a similar fault. Check to see the machine is draining at the end of the wash. check the pump and the filters for blockages or lint etc clogging the hoses or pump.
Feb 18, 2015 | Washing Machines
Why is my countertop dishwasher stuck in drain mode(s), and won't initiate or complete any wash cycle?
normally if a dishwasher fills then pauses it is trying to read the water level if it fills again it is trying get a reading from the pressure switch when it cant determine the water level it will drain to prevent it leaking, however you should get a error code for this kind of fault which makes me think it is the control board which is at fault by not being able to read the sensor rather than the sensor itself not working
Oct 08, 2014 | Dishwashers
GE Dishwasher leaking
HI,
If you're just looking at the machine the problem is not going to be fixed..
and now the question: in witch cycle is leaking?
fill, wash or rinse?
can be...for fill...one hose from filling is broken.
for wash...mechanical seal from wash motor, the plastic manifold,one gasket.
rinse..manifold or hose for the rinse...rinse pump..
for drain..solenoid for drain, the hose for drain..
Anyway you must open the machine first of all and see.
Good luck
Jun 30, 2013 | Dishwashers
I noticed dishwashing detergent residue on my dishes and then I discovered the dishes were not being rinsed. I've discovered it will not fill in the normal or rinse modes. It only fills in the auto clean...
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101';;;;;;;;;;;;
Apr 22, 2011 | Maytag MDB7100AWB Dishwasher
I have a GE GSD 5130 Dishwasher that leaks about 12 oz of water when it is pumping out the wash water and the rinse water. Its fine during the wash and filling cycle. Is it a seal problem?
This is more likely the hose connection at the drain pump or the pump housing is leaking. You will need to remove the toe kick, place unit into a drain cycle and inspect for a leak. Here is a couple links that should help.
http://appliancehelponline.com/dishdraincircpumpvideo.html
http://appliancehelponline.com/dishwasherdrainpump.html
Jul 15, 2010 | GE GSD5130 Dishwasher
NOT DRAINING AFTER RINSE CYCLE
Dishwasher is not filling in first cycle. only in rinse cyle then it won't drain it
Jul 31, 2009 | GE Nautilus 24" Built-in Dishwasher
Fills, doesn't pump to sprayer, drains on drain only cycle
Sounds like there is still something in the pump. I am 99% certain this unit has a reversable motor.
Jan 26, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
Kitchen Aid KUDI230BAL0 - no fill on rinse
i would check for apossible drain issue, perhaps siphoning water out after 2nd fill. make sure you have prper high loop insatlled in drain hose, could also be a bad water fill valve, solenoid overheating and not opening properly after 3 fills
Feb 21, 2008 | Dishwashers
Asko 1385 Dishwasher Logo
414 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
