Question about IBM Office Equipment & Supplies
Need Help install IBM Laserjet 4000tn to laptop via parallel/usb
I need to get help with the installation of an IBM laserjet 4000tn to my Dell laptop (XP Pro OS)(directly no networking) via a parallel/usb cable. I started to install the printer via the printer install wizard, but it doesn't list my printer, and I don't know which other are compatible printer.
Thanks
Michael
  • ka5rej Jun 27, 2009
    Yes it is an HP!
  • Damien Pruitt Jun 04, 2013
    Please give me a call. Damien @ iPrint Technologies @ 818.700.7419. I might be able to help.
  • 146 Answers
Ibm dont make printers are you shore that its not hp
Posted on Jun 27, 2009
How to connect?
if you conect via parallel interface make sure to install the driver for the printer. if you connect via USB the computer should recognize the printer automatically and install the driver. if it stays offline try to use the other interface or a new cable. if it doesn't help your printer may be faulty and you need to replace the formatter board
Jul 22, 2014 | HP LaserJet 1200 Printer
Windows 7 driver for Laserjet 6P
you will need an actual parallel port to connect that printer. If the new system doesn't have a parallel port, then I'd either:
  1. Install a parallel Port expansion card
  2. Get a USB Printer
http://www.newegg.com/Product/Product.aspx?Item=N82E16815166007&cm_re=parallel_port_card-_-15-166-007-_-Product
http://accessories.us.dell.com/sna/products/All_Printers/productdetail.aspx?c=us&l=en&cs=19&sku=222-1681
Jan 25, 2010 | Computers & Internet
I have a HP Laserjet 4P that had been used on my company laptop and home computer. When I upgraded top a new Dell Vostro 420 running Windows Vista Business and moved the printers over to this unit the...
You don't write how exactly is your printer connected - if I remember correctly, HP LJ 4P doesn't have a USB connector, and Vostro doesn't have the parallel port available.
So how did you connect it? Is it via some USB to parallel adaptor, or via JetDirect network card in the printer? There are multiple separate issues that may be applicable in either case...
Dec 30, 2009 | Office Equipment & Supplies
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 13, 2009 | HP PhotoSmart 1215 InkJet Printer
Can i connect hp laserjet 4p via usb ??
I have a similar situation. Trying to print from a HP LaserJet 4 using a parallel cable to USB. It will not recognize the printer. What is the installation setup or what is the trick to get it to print?
Jan 13, 2009 | HP LaserJet 4 plus Printer
PRINTER WONT PRINT
If you has been connected your printer via USB be sure that the printer port is "USB Virtual Port" and NOT Lpt1
Oct 07, 2008 | HP LaserJet 4000tn Printer
HP LaserJet II p Plus will not print
I am assuming that you are using Vista. Based on your post/description:
1. the HP Compaq 6710b has no parallel port;
2. the HP LaserJet IIP Plus is only capable of either serial or parallel connection;
3. hence you're attempting a USB to Parallel interface;
4. the printer is installed in your notebook and is set to USB port;
5. from the printer a test print can be performed but not from the Printer Properties in your notebook;
6. all printing jobs initiated from the notebook results in an "Error".
With the above in mind, may I point/suggest that:
a. Windows Vista driver will only enable your HP LaserJet IIP Plus' basic functions to work. It is not 100% compatible;
b. alternately, you can try using the XP installation CD/drivers of the printer;
c. the compatibility issue may be compounded by the USB to parallel interface;
d. the USB to parallel interface may be hampered by a known Vista USB issue;
e. you can try patching/updating the Vista USB driver. Since this has been a recognized issue with Vista, Microsoft has posted a fix for this here or here.
f. verify that the printer does not display a 22 or 40 Error.
If the printing concern has not been rectified after completion of the above procedures, you may need to:
i. download and install HP Universal PostScript Print Driver; or
ii. consider using a wireless print server connected to the parallel port of the printer; or
iii.consider replacing your printer. Sorry.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 12, 2008 | HP LaserJet IIp plus Printer
130 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
