Question about Rheem 36" Water Heater Thermocouple Kit
Heater fires up and shuts down after 5 minutes
  • timothykenle Jun 27, 2009
    gas and its a Whirlpool...I replaced the thermal coupler and it fires up but shuts down after about 5 minutes
  • 146 Answers
Is it gas or electric
Posted on Jun 27, 2009
My gas was turned off for 4 days. after being turned back on the pilot will light and the burner fires up but shuts of in 10 minutes
If heater has a sealed front door the air intake filter is probably clogged. Remove the door and vacuum out all the dust and debris in the inside. Then use an air compressor to blow down thru the filter and force out any dust caught in the underside of the filter. Reinstall assemble heater and relite. If problem continues replace the gas control. If unit does not have sealed door just replace the gas control
Jan 01, 2014 | Rheem 40 Gallon FVR NATGAS Low WATER...
Richmond LP PowerVent water heater stops heating. LED's A&B, indicating it has cycled three times without ignition. Watching it go through its cycle, the heat plate glows, hear a click, no flame,...
just an educated guess but id say you have one of two possible problems , gas valve bad or flame proof device is bad
the second cause is very common !! so common in fact theres a spare hanging on the side of mine !!!
May 27, 2017 | Rheem Water Heaters
Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Aug 13, 2009 | Water Heaters
HEATER FIRES UP AND SHUTS DOWN AFTER 5 MINUTES
try turning up temp control if that doesnt help, your thermo coupling is probably bad replace that first. also check gas line the shut off valve may have gotten partilaly closed the stem on the valve should be in a line with pipe not perpendicular
Jun 23, 2009 | Water Heaters
Home heating, boiler shutting down
Is this appliance a gas fired or oil fired. Steam or hot water
Jan 09, 2009 | Water Heaters
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Rheem 36" Water Heater Thermocouple Kit Logo
242 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
Jim Goldsmith
Jim Goldsmith
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
