I have simson washing machine it works but not
I have simson washing machine it works but not dring cloths .
  • 15,935 Answers
It appears your timer/main controller/CCU or heating element has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
My simson encore 703 when it starts to agetate whenit turns to the right it turns quickly and the clothes get tangled around the agitator
result from a simple broken pin, which causes the tub to spin whenever the motor runs, even while agitating. Call to find out how to fix this common problem – it’s very inexpensive.
Jun 23, 2008 | Washing Machines
I have a simson enduro 501 washing machine and on spin cycle it leaks water over the top of the tub. the wife uses it in bare feet on a tile floor and I am worried about her being electrocuted
If you get into the inside of this machine you will find a repair or codes sheet that will lead you through steps of your problem you are having. Hope this helps.
Feb 29, 2016 | Washing Machines
Simson top loader washing machine drum does not spin
Your motor coupling must be worn off. Replace it. It is centered with motor and transmation 2 small plastic pieces
don't wash bed blankets. Or carpets or alike. This is the major problem
Feb 16, 2015 | Washing Machines
SIMSON SHOTGUN SERIAL NUMBERS
if you find it e-mail me--I have one #150569
Feb 28, 2010 | Sport & Outdoor - Others
I put a small load of washing in the dryer and it doesn't dry and takes 2 or 3 drying cycles.
A restricted vent is the most common cause for long dry times. You can run a load of clothes with the vent hose disconnected from the back of the dryer. If you don't get any heat dring a cylce, and you verified an "air fluff" cycle has not been selected, I suggest having a professional service tech give you a diagnosis. The problem could be in one of a few thermostats, the heating element, main control (timer or control board), sensor, motor switch or even supply voltage.
Nov 04, 2009 | LG Dryers
Ge prolife
Motor bad? Bad fuse?
May 24, 2009 | Washing Machines
Not dring
The air is not getting out of the dryer. Your vent hose is crimped or cloged or the flapper outside the house is stuck.. Air is not getting out of the dryer thru the vent for what ever reason.
Oct 15, 2008 | Roper REX4634KQ Electric Dryer
Washer won't stop filling and go to next cycle automatically
if not running over ck to be sure drain is proper height and end of washer drain hose is not too tight in standpipe sound like siphoning after 1st wash and not filling to advance to rinse also be sure washer dring hose is not more than 6-8 in into standpipe
Aug 15, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Marvin
Marvin
