Question about Dell Dimension 1100 PC Desktop
I crashed my dell and need to re-intall windows
I crashed my dell and need to re-install windows xp, where do i get the back up cd wn? Is it possible to download it from a separate computer on a usb or cd then insert it into my dell. The only thing that comes up on the screen of my dell is white print saying re-install windows 32
  • Dell Master
  • 2,404 Answers
There should be a hidden partition on the hard drive with the recovery data information on it. When you first turn on the computer hold down the Ctrl and keep pressing the F11 key. It should take you into the factory restore.
If it doesn't then that means that the factory restore partition is gone and you'll have to restore the computer with the windows xp opeating system cd and a drivers and utiities cd to get the drivers installed for the hardware.
Posted on Jun 29, 2009
    Sergeant:
  • 199 Answers
There is a particiam on your dell that has all the restore data on it do you have the restore disk insert it and go. you will loose all the data that is on the comp when you do it. if you need that data pull the drive and put on another comp and copy it off. the reinstall it and then restore it. if you dont have the disk contact dell for a replacement.
Posted on Jun 27, 2009
Dell xps wont boot from dvd just cd
Sounds like you have only a CD drive. To boot DVDs you need to have a DVD drive installed. The computer probably came with a CD drive because Win XP came on a CD.
Oct 13, 2012 | Dell Dimension XPS 400 PC Desktop
We need reinstall xp dell optiflex 210 l
You will either need the dell restore CD or Windows XP CD.
To perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
Jun 24, 2011 | Dell Computers & Internet
Adrenaline 650i driver for windows vista
Vista (except 64 bit versions) should automatically install the hardware. If you are also using Kofax Capture 8, you may need to download VRS 4.2 from the Kofax website.
Note that your scanner must also have Vista compatible drivers.
Apr 06, 2009 | Canon Office Equipment & Supplies
Dell 2350 Won't boot up without cd
Check the jumper on the back of your drive. Chances are that the jumper is either on "slave" or "cable select". Change the jumper to master, and try rebooting.
Mar 11, 2009 | Dell Dimension 2350 PC Desktop
Windows xp
Do you have a Restore or Repair partition on you PC (Usually the case with Dell or MSI and a whole lot of other brands). If this partition does not exist you will need the CD to install with it.
Mar 03, 2009 | Microsoft Windows XP Professional
Install Win XP SP 2
Yes you can, Do I recomend it, no, Why?
Windows easily uses up to 756MB of RAM to run the O/S alone but can run at a minimum of 512MB.
I have personally seen it run on as low as a 900Mhz processor, 256MB of RAM and on a 10 gig hard drive.
If you decide to install windows XP on the specs you describe above please note the following.
1. System will be very slow and have lengthy start up times.
2. Applications may crash or take a long time to open.
3. With all the updates for WinXP you will easily use 8 gigs for installing XP and its updates. Not to mention whatever software you will use/install.
4. On a system with those low specs, you probably have a low end video card whcih may result in: A. chooppy windows, screen freezing, system crashes and lock ups, low video graphics all around.
I would probably go with windows 2000 instead. If your bent on having XP, at least upgrade the RAM to as much as possible. Then install windows and only install the programs you really need, remove any other junk.
Hope this is of some help to you, good luck
Feb 17, 2009 | Dell Inspiron 4000 Notebook
BAD_POOL_CALLER
Try a Repair Install with your WinXP Bootable CD. If Repair option fails you will have to do a Clean Reinstall of WinXP as a last resort.
Some details:
1. Boot with your WinXP CD
2.At the "Welcome To Setup" screen, Choose the option:
To setup Windows XP now, press ENTER. DO NOT choose !!!! To repair a Windows XP installation using Recovery Console, press R. IGNORE
To quit Setup without installing Windows XP, press F3
3. Accept the License Agreement and Windows will search for existing Windows installations. 4.Select the XP installation you want to repair from the list and press R to start the repair. If Repair is not one of the options, under the Circumstances you are in the next option will be Clean install
5. I this does not work it might be your memory --download and burn to cd memtest (http://www.memtest86.com/) and test your memory for errors.
Jan 07, 2009 | Dell Dimension 2400 PC Desktop
WIndows xp on dell
hello
you have to delete vista for intalling xp,after xp you can can install vista,format vista first with linux
Nov 07, 2008 | Microsoft Windows XP Professional for PC
How to intall xp sp3
u need cd key and genuine copy of xp call it in say u redid it
Jan 16, 2008 | Microsoft Windows XP Professional With...
Dell Dimension 1100 PC Desktop Logo
193 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
