The top is not working the bottom freezer works very little
SOURCE: Fridge side of American Fridge/ freezer not cooling down.
does the fridge have 2 motors or 1 if it have only 1 motor the gas level in the system are low. if it have 2 motors check if the fridge side motor runs
SOURCE: samsung fridge rs52530bwp the fridge side will not work
Check the compressor fan and make sure it is working.
SOURCE: refridgerator beeps and upper section not working
First, the Samsung Refrigerator is the only fridge that has one compressor, but two different evaporators to operate the freezer and the refrigerator separately. Thus, you can have the bottom freezer working fine, while the fridge part will not.
The reason your fridge is not working is probably a faulty door switch in the refrigerator. The switch is malfunctioning, telling the computer that the door is open. Therefore you hear the door alarm go off in intervals, even though the door is actually closed. If the computer registers an open door, it will not pump cool air into the refrigerator, as that would be a waste of energy. All you need to do is replace the door switch. Until you get a new one, you can temporarily fix your fridge by simply removing the old switch altogether. You will not have any light in the fridge, however, it will cool again just fine until you are able to install the new switch (a simple plug-in contraption, by the way).
Hope this helps.
SOURCE: water gathering at bottom of fridge.
Your evaporator coils frost up in normal use
and every eight hours or so the entire unit shuts down and the defrost heater
comes on to melt the frost. This cycle last about 20 minutes. The melted frost
drips into a drain pan and through a drain tube to the drain tray under the
freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end
because it drains too slow because it's stopped up at the lower end in the
evaporator pan under the unit at the floor. It can get dust and mold in it.
Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing
it out with hot water and clorox may help.
Make sure it drains quick enough to prevent
refreezing. . The drain should be located below the evaporator coils on the
lower back of the freezer.
SOURCE: I Have a side by side fridge freezer approx 3/1/2
Check to ensure that the freezer fan motor is operable (you may need to open the freezer door and activate a button inside the freezer door frame in order to make the fan operate). If the fan works, then you may have an issue with the damper assembly (located in the fresh food compartment at the top left side). It will either be a "manual" or "electronic" concept. Adjust the temperature settings for both the freezer and fresh food compartments at the "half-way mark". You should also have a vent or two at the bottom left side of the fresh food compartment (check to see how far they are openend or closed and adjust accordingly). If the aforementioned doesn't help, contact an appliance service company.
