Question about Maytag Washing Machines
Matag maf6512aaw door wont open - Maytag Washing Machines
  • Anonymous Mar 29, 2014
    how do I remove the front metal panel to fix rust
  • Maytag Master
  • 4,655 Answers
Could you please check the model number again. I am having trouble finding that model number. Is this a top loader? With possible lid lock problem.
Posted on Jun 27, 2009
Fixing a matag washer that leaks how to open front of washer
you will need to take to top off and push the drum to the back and take a stubby screwdriver to remove the door lock, do not try to prise the door open, you may need to replace the door lock as it may be faulty as it should be
open in the rest position
Dec 23, 2017 | Washing Machines
My matag neptune dryer MDE5500AYW has error code of DO, and the dryer doesn't function. Is there a error code list? Is there a part that I can replace? Is there a repair manual I can get?
The DO error code means DOOR OPEN and what ya would need to check is the door switch because it seems as if even though the door is closed it thinks its open
also here is the link to the service manual for that dryer.
http://www.appliance411.com/PDFdocs/16023110.pdf
GENE
Sep 24, 2011 | Maytag Dryers
My matag atlantis just stopped working. It will
no reset, check the receptical you could have tripped you house circuit or fuse
Feb 06, 2010 | Maytag Atlantis MAV6000 Top Load Washer
I have a matag performa model PYE2300AWY dryer that wont start. Jumped out the thermal fuse, and door switch still nothing. Whats next? Timmer?? HELP
Could be a burned lead, timer might be bad, or the water level switch could be bad. (Water level switch enables motor operation when the level is high enough.) Hope this gives you a good lead to check... Good luck.
Nov 28, 2009 | Dryers
How to install a hancle on the oven door of a matag range?
Ok open the door to about 1/3 of the way the door will rest there when you let go. Now pull straght up on the door. The door will slide right off. Pull the screws out that hold the door together. look at the bottom of the door then look on both sides for screws. remove them all. Pull the door apart and you can get to the screws that hold the handle on.
Good Day Hope this helps.
Sawdust46
Aug 26, 2009 | Kitchen Ranges
Matag alantis no cold water
check to see if you have power to the fill valve when the cold water should be going in;(reverse the connectors on the fill valve) i.e. hot now will not go in... replace the fill valve: (buy it at an appliance parts store) (inexpensive) it's an easy replacement job
Jun 12, 2009 | Maytag Atlantis MAV6000 Top Load Washer
My matag has a moldy smell is there some way that water is not draining properly?
Leave your door always open after washes so the rubber can dry
Jun 11, 2009 | Washing Machines
MATAG NEPTUNE WAHER LEAKS FROM FRONT DOOR
hi there,
base on your problem, and other like what you say they changed the seal gasket of the door to avoid the water from spilling or leaking on the front door.
Hope this initial info helps.
Jun 04, 2009 | Maytag Neptune MAH7500A Front Load Washer
No water coming out of matag model MFO 25 60hes--
Yuo may have a bad microswitch on the dispensor arm you may want to cheak that out.it would be normaly open or normaly closed on the switch may need a ohm meter.
May 11, 2009 | Maytag Refrigerators
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
