Question about Acer Aspire T310 PC Desktop
Upgraded RAM, added USB port card at rear panel ... now no worko
I upgraded the RAM, rebooted with no probs then added a rear-panel USB card using the second connector on the mother board now the machine doesn't reboot ... no signal coming from video card to monitor even just a non-responsive screen. Have removed the USB connector, cleared the BIOS with no change. Any suggestions?
  • 27 Answers
Try reseating the RAM. If the computer won't even post it's probably a RAM problem. I worked on a machine about a year ago that took almost two days to get the RAM to seat properly. It was doing the same thing worked when it wanted to. I finally used the end of my BIC lighter to beat it in. You can try to reinstall the old RAM to see if the RAM is the problem or try installing it one stick at a time.
Posted on Jul 01, 2009
    Sergeant:
  • 199 Answers
You ma have fried the on board video kind of common did you have the comp. unplugged when you put in the card and have a ground ******** if not it may be fried. get a cheap video card and try it. you can always take it back.
Posted on Jun 27, 2009
Upgraded ram 1gb wont boot hp 510 mobo 30C4
If you added another 512Mb RAM to increase the RAM to 1Gb then the new 512Mb memory stick could be incompatible with the original 512Mb or it could be faulty.
Use RAM that is same make and speed as the original RAM.
Remove both RAM and just insert the new 512Mb into your laptop and see if the laptop boots up, if not then the RAM could be faulty.
Mar 02, 2013 | HP 510 Notebook
Upgraded memory on mini 10v, wireless adapter not detected. Had mouse plugged in usb port, rebotted without mouse and windows detected new inknown device, "net". tried to download driver for my...
Please make sure that after installing the ram all the wires were properly installed to their respective places.
Usually the wireless adapter is mounted close to ram slots, so while installing the ram you might have jumped the wire.
Hope this will help.
With regards
Kartikey
Apr 14, 2011 | Computers & Internet
I have an acer aspire e380 4400, i upgraded my video card to a msi 240gt 1gb. I have had nothing but problems trying to get my computer to run properly. Vista 64, 4 gb ram, 850 watt psu are the other...
You don't say what kind of monitor you have, but that's probably where the problem is. Most likely you have the new video card set for a higher resolution than the monitor can handle. When Windows starts up and switches to your settings, the monitor shuts down. Some monitors will display a message like "input signal out of range" before shutting off, but not all brands or models do.
Look up your model of monitor and find its maximum resolution, and don't set your card greater than that. Press the F8 key when your computer starts up after turning on the power, and choose the "start in VGA" option from the startup menu. This will allow Windows to come up with a resolution setting all monitors can handle. Then you can change your settings.
If you upgraded your video card because you have applications that require high resolutions that the monitor doesn't offer, you'll need to upgrade your monitor as well.
Thanks for using Fixya!
Oct 06, 2010 | Computers & Internet
Can't drive av/c;multimedia hardwares;tvcard
Sounds like the card reader cables, USB cables, and Firewire, (1394) cables have been disconnected from the motherboard. I'm guessing granted, but it could have been when the TV card was removed, or perhaps when you were installing upgrades.
You've had the computer open, judging from the statement that you've upgraded it.
1.Computer off, and unplugged from the surge protector. Open the computer case. TOUCH the metal frame of the computer case, to relieve your body of static electricity.
2.You may have to use a flashlight. Look for the cables coming from the card reader. From the Front Panel. You may have to remove the Front Panel a bit, to peer in, and see which cables go to the card reader.
Finding these cables, follow them back to the motherboard. See if they're plugged in, plugged in tight, and if they are the right way around.
Do the same for the firewire ports, and the USB ports. Follow their cables.
Apr 29, 2009 | E-Machines C6423 AMDAthlon 64 3400+ 2.2GHz...
Ram upgaded 1G to 1.5G
That is all you have to do if it recognizes the ram you are done. Enjoy! Please take a moment to accept and rate my solution.
Thanks,
Lee
Feb 26, 2009 | Acer Aspire One Netbook 8.9" Notebook
Power to everything but CPU fan and case fan - won't boot
Hi this is tech crazy
The solution to the problem is as follows
The main reason for CPU fan overworking or not working is due to the load we put on the syatem while operating.So,the first reason for fan not working may be due to the SMPS malfunctionality.Better check out for it.The reason if fan is working but Overworking is due to viruses is system.So go in for format
Hope this solution helps you
Please do rate me on the above said solution
Feb 04, 2009 | Intel Motherboard
Upgrading two USB ports on front panel
Hi..
there is no such converter..
those pins should connected to ur mother board only...
once check ur bios settings..
or
use external usb hub..so u can get multiple usb ports that u need...
Jan 01, 2009 | HP Pavilion 761n PC Desktop
Constantly rebooting
call me craxy, but you may need to replace your power supply, and if its not that, it is a stuck or broken fan on your graphix card or your cpu.
Dec 29, 2008 | E-Machines (T2958) PC Desktop
NO USB WORKING
Hi there what OS do you have loaded?
Im assuming you have XP loaded.....
have you tried to unistall and reinstall the USB ports?
reboot and restart,
should auto recognise the device and self install,
reboot and restart,Test usb
dont for get SP2 updates for functionality of the devices
Let me know the outcome thanks
Jul 21, 2008 | ASUS P4P800-MX Motherboard
Can some 1 help me with my fta
Loading Viewsat Ultra Via USB Flash Drive
1. Load File(s) to your USB Flash Drive. (eg.. PFTAUSW-070911U.PGM)
2. Take USB Flash Drive and insert it into Viewsat Ultra USB Port (behind right
side door flap)
3. Using remote Hit Menu. Then Go to System Information -> Receiver Upgrade
and Hit OK
4. Go to USB and Hit OK.
5. You will now see a list of all the files located on your USB Flash Drive. Find the
file you need to load. (eg. PFTAUSW-070911U.PGM) and select it and hit OK.
6. Your Receiver is now being upgraded.
7. It will come up showing you not to power off the unit.
8. Once it has finished the receiver will reboot and you have upgraded your Viewsat
Ultra.
Dec 28, 2007 | Computers & Internet
Acer Aspire T310 PC Desktop Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
