I have a large screen Mitsubishi TV and water spilled down the front this morning. I wiped it up but tonight learned it must have held water at the bottom lip that has wicked up behind the screen. How can I dry it out or dismantle it and will the TV remain undamaged? Thank you!
    Champion:
  • 205 Answers
Usally the screen is 3 layers if it was just water it should evap, without residue. You can remove the screen, but the inner surfaces are fragile to the touch.A big concern for contamination between the layers durning handling. You can clean each surface with a class cleaner and soft cloth. Use canned air from a distace to dust layers before re-assy. The distance is to avoid propellant from contaminating screen surface. Suggest this be left to a professional.
Posted on Jun 28, 2009
How do I clean a Samsung tv flatscreen that has had coffee spilled on it? It has been about a week.
Try equal amount of water and vinegar. Spray on clean dry lint free cloth then wipe the TV in the same direction, upand down or side by side...Don't over saturate the cloth...
Feb 11, 2015 | Samsung Televison & Video
Water damage tv
The underside of the screen has a special coating necessary for reflecting the images from the CRT tubes. If the finish is disturbed, it will no longer be viable. You may have to replace the front screen or put up with a nasty screen.
Feb 27, 2014 | Sony Televison & Video
My daughter seemed to spill some pickle juice on the front of my sanyo flat screen tv it ran into the bottom where the power and channel changing buttons are now it is wigging out and changing channels and...
Spill a small amount of warm water and let it run down to wash out the pickle juice. Of course do this without the power cord connected. Let the tv dry long enough to be sure the water has evaporated before re applying power. Just might work.
Jan 03, 2014 | Televison & Video
My room mate spilled his drink and a little went on the bottom left corner. i dried up as much as possible, but now there is a dark shadow spot on the screen in the bottom left. how do i remove the screen...
liquid is never good on those screens-
there are 3 layers to the screen, from inside out, a fresnel screen (etched circle pattern), a lenticular screen (ridge lines top to bottom), and a protective screen ( "Diamond Shield" tinted plexiglass).
the fluid will wick up btween these layers, turn black, then very very slowly recede leaving a waterline mark. It can take months for it to become un-noticeable.
cleaning is possible, but beware, any type of cleaning fluid or spray is going to simulate the exact same problem but to a larger area.
also introducing dust, lint or hair into the layers when separated is almost impossible to avoid.
these pieces, especially the lenticular screen are extremely fragile nylon plastic and is apt to split under its own weight when handling, so beware the project you are about to get involved in...considering the large size.
but it can be done.
Remove all screws around the screen frame from the back of TV and the lower sides. There will be a wiring harness that goes to front buttons- disconnect it. The whole assembly will come off the front of the TV.
Lay it on the floor face down. Remove the screws in around the inside of the screen. The screens are now ready to lift out, one at a time.
IT IS IMPORTANT to not attempt this by yourself. The screen are fragile and large and scratch so easily which appear as a white opaque area when reassembled. Have a helper. Wear cotton gloves while handling as finger prints will be noticeable after you reassemble.
ALSO IMPORTANT- these screen are oriented front and back...in other words they go together in a certain direction...on each screen layer there is a small sticker on its outer edge. Make note of its orientation and reassemble accordingly.
Clean with a cotton cloth and very very little "plastic glass gleaner" (if needed only!).
WIPE EXTREMELY GENTLY in the direction of the grooves on each screen layer- much like cleaning an old vinyl record.
The lenticular screen is the biggest worry as rubbing on the grooved side is so likely to cause damage. Perhaps rubbing should be avoided if possible.
Let them lay out and dry before reassembling. A bottle of compressed air is good to remove debris when layering them back together...a dust free environment is recommended.
Reassembly and installation is just the reverse of dis assembly- remember the wiring harness connector!
Apr 13, 2011 | Mitsubishi WD-73733 73" HDTV
Keys sticking from spill on keyboard.
Here's a little trick I have learned, from being the type of person that would cause a spill, and guessing that it was something sugary, that is the reason it is sticking, to fix this, get a clean, lint free rag and get some rubbing alcohol and dab just a little on the rag then wipe it across the keybord, pressing down on the keys so it can get down to the bottom of the keys. Do this as many times as it takes to wipe the entire area covered by keys.
Oct 01, 2010 | Microsoft Wireless Optical Desktop 1000...
How do i get the front off of my mitsubishi projection tv?
The speaker grill is a snap on part that you simply pull forward on to remove it. Behind it you will find the front board which is held on by 6 screws. The screen assembly is held by 4 screws at the bottom and sort of hooks on at the top. You swing the screen out at the bottom and up to remove it. I hope that helps. If you need further help with this TV I have the service manual in pdf form.
Dec 04, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Black spot in bottom of tv
I just had my caps replaced and after the tech put it back together there was a spot. He tok the screen off and cleaned the mirrors around the bulb and the large mirrors(they were reaaaalllllly dirty. It did brighten up the picture and it looks crisper, oh and the spot was gone.
P.S.. Like nettiser stated. If it's unde warrenty have them do it. If you drop something "you will be pissed" if you don't !
Aug 10, 2009 | Mitsubishi WD-62525 62" Rear Projection...
MARKS ON SCREEN
there are two screens..the lenticular..and the fresnal...you can try to pull them apart(very fragile!) and clean them but you must be careful not leave any water or moister between them(blowdry or wipe completely dry after cleaning with damp cloth) do not rub too hard...just spray warm water on the rag and carefully wipe clean ...then dry. Putting the screens back together isn't too tricky but let me stress..these screens cannot be bent or they will break...pull them off with two people(one on each side)..also you will have to take the front cover off because the screens are literally clamped down to the front cover.....good luck...let me know if you need futher assistance..........mike
Feb 13, 2008 | Hitachi 65S500 65" HDTV-Ready Rear...
Water stain inside of screen glass
Yes, you can check with ctechnicians.com for instructions on disassembling.
Dec 23, 2007 | Hitachi 60EX01B 60" Rear Projection...
Dark spots on tv
I have the same TV, and I was getting the black spots on my screen as well. It is dust settling on the bottom mirror. Yoiu can call Mitsubishi and spend 150-200 on getting it cleaned, or you can do like I did and take the front panel off and the 10 screws around the edge on the back of the black plastic border around the screen. Then lift up gently and have someone hold the screen for you and gently dust the bottom mirror. I did this by myself, but it would be wise to have 2 people do it.
Nov 26, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
