Question about Olevia LT32HVM 32 in. LCD Television
I got a universal control for me tv olevia but any of the codes work for it can you get me more codes thanks
  • 298 Answers
SOURCE: remote control code
Dish Netork does not have the code for Olevia
but you can scan for the code using the infformation
here
Remote Code Power Scan
If your brand is not listed, use the following procedure to scan through all codes.
If you start the and do not press a button within 20 seconds, the remote will end the scan automatically.
1. Turn ON the unit you want to program the remote to control.
2. Press the Mode button on the remote until the appropriate mode light is flashes
3. Press the Address button. The mode light will start flashing slowly.
4. Press the Power button. The mode light will stop flashing and stay lit.
5. Press the Up or Down arrow button to set the remote to the next code. The Down arrow button scans backward and the Up arrow button scans forward.
6. When the correct code is reached, the device (whether a TV, VCR, or other) will turn off.
7. Press the Address button to store the code in the remote control memory. If the code is valid for your remote, the mode light will blink 3 times.
8. Turn the device back ON by pressing the Power button.
9. Try some other functions to make sure you have the correct code. Occasionally the Power button may work when others do not.
10. If the other buttons work, follow the current settings procedure below to determine the current remote settings.
11. If the other buttons do not work, repeat the previous steps. The scan will resume from the last code stored.
12. The mode light will flash rapidly when the scan has returned to the starting point and all codes have been tested for that mode. The remote control may not control some device models.
Posted on Nov 23, 2007
SOURCE: Remote control codes
You need remote rc64 to control the Olevia 32 inch LCD. You can call Directv and order the remote. Use code 11610.
Posted on Dec 09, 2007
SOURCE: QUESTION ABOUT PROGRAMMING CABLE REMOTE TO T.V
the code for olevia for cox cable is 1610. Hit tv then hold setup till light blinks twice. release setup. enter 1610 and wah lah
Posted on Mar 29, 2008
SOURCE: Olevia remote control codes
Have Olevia 237T with same problem. Bought Universal URC-R6 remote control. Works for TV, cable box and audio system as well. $20 at BestBuy.
Posted on Apr 02, 2008
  • 362 Answers
SOURCE: remote code for dish network remote to control olevia tvs
Please follow the steps below to program your remote control to equipment other then your DISH receiver:
Note: If you start this procedure and at any time and do not press a button within 20 seconds, the remote will end the procedure automatically. Simply start over again. Use the TV button for your TV, the VCR button for your VCR or DVD player. These Mode buttons are located at the top of your remote control.
1. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release.
2. Press the numbers 5-0-0 on the remote control.
3. Press the Pound (#) button on the remote.
4. Press and hold the correct Mode button until all mode button backlights illuminate, then release.
5. Press and release the Power button on the remote control.
6. Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
7. Press the Pound (#) button. If the code entered is valid for the remote, the mode light flashes three times.
8. To verify the code works try several different functions for that equipment.
We cannot guarantee our remotes will work all other devices. If this does not correct the issue, unfortunately our remote will not work for that device. We apologize for any inconvenience this may cause.
Lone99star. Please rate this solution.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Feb 14, 2009
Olevia tv remote has stopped working.I have a zenith universal remote but I do not know the codes for the olevia tv
You can use the code search feature of your GE universal remote to find a code that will control some of the functions of your Olevia TV. Code search is described in the instructions for using your GE universal remote.
May 11, 2014 | General Electric Universal Remote Control
I need a remote code for a rca remote for the olevia remote control can you help
Unfortunately Olevia is one of those t.v. brands that is not compatible with many universal remote controls. They make a Universal Learning Remote specifically available from Olevia on their web site that may solve your problem if your universal remote control turns out not to be compatible with your Olevia television.
As for what codes you can try, there are many, and the codes depend on your universal remote control brand. Many times, an RCA code will work for Olevia televisions, so you should try the RCA codes that come with your universal remote first, before trying any of these other codes.
If you have a Dish Network Universal Remote you can use code 506 or 127.
Direct TV remote codes vary by model number on the remote control, but the following codes work with most Direct TV remotes: 506, 127, 11144, 11240, 11331, 11610
Cable Vision use code 506
Charter and Movie Box remotes you can use 1144 or 1178
Comcast codes are 11144, 11240, 11331, 21075, 10159, 10154, and 10088
Cox code is 1610
Brighthouse remote codes are 1610, 1144, 1240, and 1331
Time Warner remote codes are 1610, 1144, 1240, 1331, 432, and 1610
If none of these brands are what you are looking for as far as your Universal Remote Control is concerned, many universal remote controls will work with Olevia televisions if you use the codes found under the RCA, LG, Phillips, and Yamaha in the code listing included with your remote control.
Jul 25, 2009 | Televison & Video
Need Code for Olevia LCD TV
there is no code for olevia.....(olevia, vizio and dynex are really new) All universals are not yet ready for theses new flat panels.............but you can use olevias remote (rc-ltu) it controls five units (cable box, olevia tv, pioneer laser disc and toshiba dvd plus a vcr if i had one)
Dec 20, 2008 | Directv RC23 Remote Control
Go to Best Buy and buy the DirectTV Universal Remote Control ($20 and works with all cable and satellite services) Model RC64. It will control all the functions on the Olevia TV and Satellite box, except the A-B-C-D buttons for the User Guide.
The remote codes are:
RCA Satellite Box - 00392
Olevia 237-T12 - 11610
Enjoy
Nick from Ft. Myers
Feb 08, 2008 | Olevia LT37HVS 37 in. LCD HDTV
Juni,
You'll have to look it up by the remote you're using... Then by the brand of Tv you're trying to control.. try here..
http://www.remotecodelist.com/remotes/
Bill
Dec 27, 2007 | Olevia LT42HVi 42 in. LCD Television
Need a TV code for Olevia 237T model. Thanks, Carl
Olevia has added four digit codes. Here are the three I know of:
1304
1178
1144
Please post a response for the brand of remote you have if any of these codes work. Thanks.
Dec 04, 2007 | Motorola Mobility DRC800 Universal Remote...
Oct 15, 2007 | Olevia LT32HVM 32 in. LCD Television
Need code for Olevia 232V TV
Best codes would be: 11331,11144,11610 or 11240 Also depends on what universal remote you are trying to program.
Jul 25, 2007 | Philips PM435S Remote Control
Olevia LT32HVM 32 in. LCD Television Logo
105 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
