Question about Maytag M7X05F2B Air Conditioner
I have a Maytag window air conditioner that is leaking out front
I have a Maytag window air conditioner that was given to me. Model number M7X05F2B-D and the water that should drain out the back of the air conditioner is coming out the fronT. Is it the drain hose and if how do I fix it.
    Scholar:
  • 190 Answers
The unit has to lean backward to let the water run out. It sounds like it is too level or leaning forward too much. There should be an adjusting screw in back that you can lower and it should work fine.
Posted on Jun 27, 2009
AC puts itself on fanmode? why?
I would check to make sure there's no nests or anything blocking the coils.
May 22, 2014 | Maytag M7X05F2B Air Conditioner
How to refill home a/c in window with freon? Can I find a store to refill it in philadelphia?
If you dont know refrigeration better leave it to an expert. Lot of people dont like dealing with window ac because of the high cost of labor. Some tips. If you can remove it from the window to the outside and remove the case and panels on it. this will save you money. If you can clean the evaporator and condensor this will save you money. All he has to do is maybe add a tap valve and leak check and refill the ac, this will save you money. Look in the phone book for someone that does service. Hope this helps.
Aug 10, 2011 | Maytag M7X05F2B Air Conditioner
Water running inside the a/c and down the wall. I do not see any drain holes on the bottom of this unit to let the water drain outside. Model M7X05F2B-D Alex
In the drain pan under the unit (the part that is outside the window), there is a drain hole, that drains the accumulated moisture/water. It's clogged and that's why you can't see it. Or it may be a small gap in the rear of the drain pan, that' s supposed to do the same thing. If the unit is sitting perfectly level (front to back), the water does not drain well. A slight slope helps.
Hope this helped you to troubleshoot and solve the problem.
May 31, 2011 | Maytag M7X05F2B Air Conditioner
Need on/off switch where can i grt it
mcdevito75 here, You can try Maytag.com from search in your home page for a new on/off switch.
Aug 20, 2010 | Maytag M7X05F2B Air Conditioner
Leaking water from front
you need to slope it outward farther its leaning inward at a slope toward the inside,make it lean slightly toward the outside,but not too far as the water is used to cool the compressor in some units with the slinger fan,use a level to correct this or a pencil or marble,when the pencil or marble starts to roll away from the window outside your angle is correct,if it rolls toward the house it still needs adjusting
Aug 01, 2010 | Maytag M7X05F2B Air Conditioner
Carpet wet under window air con.
The air conditioner needs to be "tilted" or "pitched" to the rear. By this I mean the back (outside) should be slightly lower than the front (inside). This will allow the water to run toward the back of the unit, and drip on the ground instead of inside the house - on the floor. The A/C unit must not be level or tilted into the room (front even with or lower than the rear).
This water is the result of condensation that is created when the warm room air is drawn through the much cooler coil & fins inside the unit and is completely normal. The more humid the air inside is, the more condensation will form, and drain away.
Jul 15, 2010 | Maytag M7X05F2B Air Conditioner
Can't find btu ratingfor serial#m7x05f2a-b.thanks
5400 btu's
Note: should be a metal/paper tag somewhere on unit to indicate voltage, amps, and btu's.
Jun 08, 2010 | Maytag M7X05F2B Air Conditioner
How do you clean mold/dirt on the inside of the unit? does the front or back come off?
If the machine is really nasty then the best way is to take them out of the window and remove the outer metal covering which is usually held on by screws. I've stripped them down to wash them out a couple times but its no easy task.
Jun 03, 2010 | Maytag M7X05F2B Air Conditioner
There are drain holes in the bottom. its best to get some one to pull it out of the wall and wash it out with a hose. And i want you to make sure the rear of the a/c os lower than the inside. so the water won't run in your house, Hope this is helpfull to you. Sawdust46
Aug 16, 2009 | Maytag M7X05F2B Air Conditioner
Maytag M7X05F2B Air Conditioner Logo
684 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
