SOURCE: Chaning right wheel bearing on 1999 Chevy Malibu
It is much easier, and cheaper to find a steering knuckle or "hub assembly" in a salvage yard.
To begin, jack up the car and remove the wheel. Be certain the car is stable and will not roll off jack(s)!
Remove the spindle nut. Remove the brake caliper (hang on a wire).
Remove the bolt for lower ball join. Remove the bolt that goes thru
strut. Now, pull assembly off while prying to ease pressure from the
lower control arm.
Depending on how many miles you have on the car, you might want
to head-off some future trouble by replacing the half-axle while you
have the front end disassembled.
SOURCE: 1999 chevy malibu
That engine does not have a timing belt, it has a timing chain and therefore much easier to work with as it can only go on a certain way, the primary focus being getting the dots on the timing chain sprockets lined up properly.
I believe, with the engine at Top Dead Center on cylinder #1, the dots will be facing each other. That is to say, the do on the cam sprocket will be facing the dot on the crank sprocket.
SOURCE: 1999 Chevy Malibu how many quarts of transmission fluid does it
12.9 Quarts of DEXRON®-VI Automatic Transmission Fluid
SOURCE: how to replace headlight bulbs 1999 chevy malibu
Thanks Pierre!
Merci beaucoup!
Everything worked as mentionned. Be carefull with the plastic in the winter. Make sure to use a flat screw driver and get it close to the slider and not on the edge. I cracked one of the tongues. Those L shaped slots are under the plastic cover with the two big plastic plugs that you also remove with the flat screw driver
Pierre Godin, Boissevain Manitoba.
SOURCE: 1993 chevy suburban 1500 4x4 transmission enterchange list
cheaper ,faster and eaiser too just replace it,200.00-400.00 at a bone yard 1200.00-2300.00 too rebuild
a lot of years interchange with it best too pull it and match it up
