The jackshaft must be installed back onto the starter shaft prior to installing the jackshaft with the shallow side of the coupling going/facing towards the jackshaft and also facingthe jackshaft splines. Remember to reinstall the coupling retaining ring if it was removed. ALSO, be sure to install the coupling on the starter output shaft with the counter bore facing the jackshaft. THEN put the spring inside the coupling and install the pinion gear on the shaft put the lockplate and the thrust washer on the bolt and put the bolt in place in the jackshaft. If you removed the retaining ring put it back on shaft and then slide the jackshaft assembly back into position in the inner primary. In order to hold the lockplate and thrust washer in place be certain that the lockplate tab is properly in the keyway. THEN, having aligned the lockplate tab and thrust washer properly in the slot with the jackshaft keyway screw the jackshaft bolt into the starter shaft and while holding the pinion gear in position tighten the bolt to 84-108 in-lbs (9.5-12.2 Nm) and bend the locking tab against bolt head.
