Question about SharpVision XV-Z9000U Multimedia Projector
My sharpvison z9000u is not powering up bulb was used less than 1000 hours
  • 31 Answers
Hi There Sounds like a lamp has died. The technical lamp hour spec life is only a manufacturers "up to xxx hours" and not what you will achieve in actual life.
If you want we are able to supply lamps as we ship internationally, @ $US335 for a SharpVision Z9000u Regards Kevin Andreassend http://www.digitaldaytime.com iceavtech@gmail.com +64-9-414 2348
Posted on Sep 09, 2009
What applians can I use on a stramm 2.5 kw generator and how many
You can run 100, 25 watt bulbs, Or one washing machine, 1000 2,5 watt LED lamps, or on or two air conditioners. It is 2500 watt per hour it can give.
Jan 15, 2015 | Electrical Supplies
I have a 3VE53 heater and was wondering about how much eletricity does it use if I keep it at 65-70 degrees for 9 hrs. a day?
Okay, for example a 100 watt bulb left on for 10hrs uses 100x10 =1000. so 1000= 1kwh. so look at the watt rating on the fan motor and times that by 9hrsand then do the math, then look at your bill and see what you pay per kwh (kilowatt per hour) and times that with your answer, for example lets say the heater blower is 10watts, take 10 X 9 = 90, then 90 divided into 1000=.09 so it .09 of a kilo watt almost a tenth of a kilo watt. so if you pay 3.25 a kwh then you would say .06X3.25=.195 less than one cent, hope this helps
Feb 16, 2012 | Dayton 3VE53 Oil Filled Liquid Fuel...
I have a Sharp xv-z9000u projector. I recently replaced the lamp; however, I cannot turn the projector on. how do I reset the lamp timer?
While pressing down arrow, right arrow and ENTER on the projector, press POWER ON on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset
Jun 04, 2011 | SharpVision XV-Z9000U Multimedia Projector
I have a sharp projector xv-z9000u. I replaced the lamp and now I cannot turn on the projector. What should I do?
there may be a reset button some were on the projector you have to look real good, i do know that some projectors when you replace the light bulb you have to push the reset button than it should turn on.
Sony cineza vpl hs51 projector won't project
Something I found interesting from the internet - lamp life isn't when the bulb dies, but when a bulb has lost 10% of its brightness - so you might well be able to reset the timer and get much more use from the bulb - the image just wont be as bright.
The lamp may not have been changed - just the timer reset - How many hours has the lamp really done - 1000, 3000, 5000?
If you know that the hours are genuine, then was the quartz bulb contaminated with a touch of oil from skin contact?
This will substantially shorten lamp life, due to the quartz going milky and opaque.
The easiest way to check, is to pull the lamp and have a look at the bulb.
If need be replace the lamp and reset the lamp timer.
These instructions are for a Sony Cineza VPL HS3, but may be the same for the HS51
1st thing to check - is the cover properly/completely closed - this can stop the projector from working.
Connect the power and set the projector to standby mode.
Press these buttons on the remote control in this order, for less than 5 seconds each.
Reset - Left Arrow - Right Arrow - Enter
Dec 07, 2008 | Sony Projector Lamp for VPL-HS51
LP130 projector - no light from lamp
there are several other issue that can arise with this unit
you may want to check out fixmyprojector.com
Jun 30, 2008 | InFocus LP120 / 1000 Lumens / XGA / DLP...
Lamp life over 2000. can't turn on again after replaced
sharp xv z9000u bulb reset
Hold down Enter + down arrow + right arrow and then power on.
Mar 13, 2008 | SharpVision XV-Z9000U Multimedia Projector
PROJECTOR POWERS DOWN
This would appear to be a bulb that has reached end of life -- or the projector thinks that it is because of hours. Usually most bulbs are 1000 or 2000 hours. Depending on your projector there are different ways of checking bulb life hours -- if you Google your projector model number and "bulb life" you will usually get a post on how to check these hours. Also, if it is a new bulb and you haven't reset the hours counter, it may need to be reset (however you also don't want to wait too long before changing a bulb that has reached EOL since they can and do explode sometimes taking out the projector with it).
Jan 18, 2008 | Sanyo PLC XU50 Multimedia Projector
CINEGO
Mine does the same thing and I just replaced the bulb after waiting almost 6 months and I purchased one directly from Radio Slack. It will turn on for about 10 seconds and then goes into shut down.....At three hundred dollars I can't see putting another bulb in, when this one has less than 50 hours on it.
What do you think
Oct 29, 2007 | Radio Shack Cinego D-1000 Multimedia...
SharpVision XV-Z9000U Multimedia Projector Logo
175 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
