Question about Polaroid i634 Digital Camera
Batteries died while turning on camera, now it ceases to work.
I have a poloroid i634. A long time back the batteries died while i was turning on the camera (when the lens was moving out specifically). When I changed the batteries and ever since then, the camera will turn on try to do something with the lens, make 3 beeping sounds and immediately turn off. (the process takes about 6 seconds). Is there any way to fix this?
I have a polaroid i634 that has an issue with power. Initially I put in alkaline batteries and it worked for awhile (or at least as long as my daughter used it). Then it stopped working. I was told to use...
Hello ..
I hope that really problem with charging.
However, it look like cause from battery. Whatever type of new battery that you used, that no meet the requirement as original battery that included with camera. During testing the camera, they also don't use other battery except that original battery. Maybe it seem like have same power, But it chemistry is different. However, you can try using same battery from polaroid also.
TRy look this..click here
I don't want to scare you, but is good to have new battery same like original and also from same company. As long you are using other type battery, It maybe will effect components in camera. So beware and careful.
If you think that charging is problem. THen try recharge back around 8hours. However if u are using external charger. and not using camera to charge battery.If you only can charge through camera, try recharge around 2-3 hours. Pull out battery from camera. place safely and avoid any magnectic environment . Around 2-1 hours, charge again 2-3 hours. After charge, around 10-15 minutes, try used it. It still have problem? If still face same problem. I advice to find suitable battery.
Jul 06, 2011 | Polaroid i634 Digital Camera
How to change the battery
These types of Poloroid cameras do not have batteries. The batteries are actually included in the film packs. Whenever you replace the film, you will replace the batteries.
Thanks for using Fixya.
Here is a picture of the battery in the film pack:
May 27, 2010 | Polaroid 600 Business Edition Instant...
I have a poloroid i835 digital camera which tunrs on and imidiately turns off. The zoom lens comes out and then ater few seconds it goes back and turn off the camera.
The batteries are defective please recharge the battery fully then check the issue if the problem persist then replace the batteries.
Feb 19, 2010 | Polaroid Cameras
Camera won't turn on
Your problem is likely battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Polaroid I533P Digital Camera
Batteries die within 1/2 hour & zoom does not work
Are your batteries good? There are special Lithium batteries that are designed for cameras.
Aug 14, 2009 | Canon PowerShot A590 IS Digital Camera
I have a polaroid i634 can you help?
how do I empty a full memory on a polaroid i634
Dec 12, 2008 | Polaroid i634 Digital Camera
Lens won't go back in
some times if the batteries get wet it will short the system and it won't turn back on... if you dropped it something may have shifted inside blocking the messaging systems inside the camera. i would take it to a local camera shop.
Jul 08, 2008 | Kodak EasyShare C663 Digital Camera
Installing camera
run software again reattach camera after you restart computer
Feb 21, 2008 | Cameras
Polaroid i634 Digital Camera Logo
107 people viewed this question
Top Polaroid Cameras Experts
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
