Question about Hitachi 42HDM12 42 in. Plasma Television
I have vertical lines showing up for the first time on my Hitachi 55" plasma tv
5 Suggested Answers
  • 6 Answers
SOURCE: THICK BLUE LINE VERTICAL LINE ON SCREEN OF MY PLASMA PICTURE
IF THE LINE IS ABOUT 1INCH WIDE THE CHANCES ARE IT WILLBE YOUR PLASMA DISPLY THAT HAS GONE . WOULD BR CHEAPER TO BUY A NEW UNIT . HOWEVER TRY RINGING HITACHI EXPLAIN THE FAULT COMPLAIN THAT IT SHOULD OF LASTED LONGER THAN THE WARANTY AND SEE WHAT THEY WILL DO ABOUT IT
Posted on Feb 15, 2008
  • 4234 Answers
SOURCE: 42HDS69 42 in. Plasma has several thin green vertical lines in middle of screen
If the set is still in warranty, call for warranty service. If not and you feel comfortable working on the set, carefully open up the back and reseat all of hte cables and connectors. This can be caused by marginal connections inside the set.
Keep us posted on your progress and results.
Dan
Posted on Aug 29, 2008
CAYPIANAN
  • 227 Answers
SOURCE: Red vertical Line on 55" Hitachi plasma
check the MAIN -Y- SUSTAIN BOARD i believe that your problem is there
good luck
caypianan@yahoo.com
Posted on Nov 08, 2008
  • 3 Answers
SOURCE: vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Posted on Jan 13, 2009
Random 3'' vertical red line on 42'' Hitachi Plasma TV
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.////
Sep 04, 2017 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42EDT41A Turn On with white and yellow vertical lines
you have to replace the vertical sweep IC and check the voltage across its VCC. If you cant understand tech words, better visit the service center.
Jul 07, 2009 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42HDS69 Blue Vertical Lines
I think that you have dry solder joints on either the vertical scan board, the focus board, the line output stage, or the chroma panel. Hope this helps.
Sep 13, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Hitachi 42" Plasma HDTV
This happened to me with my first Hitachi 55" plasma. It ended up being the panel itself, which was very expensive to fix. Thankfully mine was under warranty and I was able to get a replacement TV.
Jun 16, 2008 | Hitachi 55HDS69 55 in. Plasma Television
Red box half way down screen
I am getting re or blue lines running vertically on my Tv. They are not there all the time just now and then. Can I fix it with my remote or do I need a tech?
good luck
caypianan@yahoo.com
Mar 16, 2008 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Vertical red line on 55 hitachi plazma
The vertical line, in my case, was due to a bad contact on the flexible printed circuit. I fixed the problem by using a piece of a rubber eraser to apply downward pressure on the flexible circuit as shown in the picture. To locate the faulty section lightly push on the flexible circuit from lef to right untill the line dissapears.
Nov 28, 2007 | Hitachi 55HDM71 55 in. HD-Ready Plasma...
Jun 14, 2007 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
My tv is hitachi 55pd plasma
have a tech check your tv the vertical module needs to be replaced.good luck
Apr 18, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Open Questions:
Hitachi 42HDM12 42 in. Plasma Television Logo
121 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
