Lilg4mdalbc why are rating badly for your bad answer?
Lilg4mdalbc, Why are you giving bad advice then rating me poorly because the advice you give is bad. Look at the pictures I posted and tell me how the top power supply will replace the bottom one???
Thread:
http://www.fixya.com/support/t2467008-acer_aspire_x1700_power_supply_burnt
  • 3 more comments
  • Kevin Shafer
    Kevin Shafer Jun 27, 2009
    How will the power supplies you suggest fit into her computer:
    Yes, the connections must fit, the wattage must be sufficient but the ones you suggested are not the same in width or height. Look at it.
  • Kevin Shafer
    Here is what you suggested:
    Here is what she has:
    See her computer:
    How can what you suggest possibly fit?
  • Kevin Shafer
    Except, this isn't even a micro ATX; it's even smaller than that. Sometimes they go by FlexATX, but I think even this one is different than Flex, though similar.
  • Kevin Shafer
    juy, checked the link and skimming through all the products there are only ATX sized power supplies there, nothing the size of the picture that I posted.
  • Jorge Majano May 11, 2010
    what matters is that the connections fit, the wattage is sufficient, and that the power supply is same size in width and height, depth does not matter, and i also looked up the specs of the power supply on cnet.com and it says that it needs a multi-core capable power supply with SATA connectors. the picture that you pulled up is the picture of an OLD atx power supply
    President:
  • 2,678 Answers
I've posted an answer on your original question although I didn't see the pictures.
You have a micro ATX system and while the above poster is correct regards H & W dimentiond they are less than the normal ATX ones.
Check the example link I left on your previous post.
Posted on Jun 27, 2009
  • 1 more comment
  • Alun Cox Jun 27, 2009
    Try this link then
    http://www.evercase.co.uk/PowerSupplyUni...
    Just as a matter of interest do you not think it may be easier to do a case swap?
    You may find this link interesting reading regards your problem
    http://www.hardwareanalysis.com/content/...
    Also Delta Electronic make the PSU's for Sony so it may be worth contacting them to see if they can supply you with a replacement.
  • 721 Answers
Dude are you high? Wtf? You could never fit those into a case for one. For 2 you can't hook 2 power supplies up in on case,not possible. He gave good advice,except he shoulda said, don't touch that pc!!!
Is this free information?
Only thing it cost is peoples time, just bare in mind that most people advise is only that "advice", So if you was to ask why your washing machine for example was making a knocking noise, and somebody said it needed a new motor, costing megabucks, but someone else said "look in the filter" costing nothing. It would be up to you what advice you thought was more helpful. And all that cost me was two minuets of my time. Good luck
Feb 19, 2015 | Washing Machines
Can a fuel pressure regulator give your engine to much gas if it's bad
Fuel pressure reading will give you the answer.but O2 sensor,engine temp,trottle position sensor,poor combustion like cylinder compression spark plugs, valve timing
As you can see there a lot of things that can change the rich and poor fuel metering.
hope it helps
Mar 25, 2014 | GMC K1500 Cars & Trucks
Turntable not turn, light on, no heating
It would have helped if you mentioned your brand and model, but it's probably a bad door switch or door switch mount.
If it's a Sharp or Dacor brand, it's probably the bottom door switch.
My door switch text file gives you help and links for such problems. It's here.
Oct 17, 2011 | Dacor DCM24 Convection/Microwave Oven
Will a bad oxygen sensor give me bad gas mileage in my 07 pacifica with the 4.0L engine. Will hhoking it up to a computer give me any indication that it is bad.
Bad 02 sensor will give bad mileage, as car is starving for air, sometimes computers will not detect if it is bad, slot of simple performance problems results from 02 sensors, fuel filters, dirty injectors, poor fuel, dirty air filters. Those are some the main things to look at for best fuel mileage and performance. Hope this helped, please let me know. Thanks, mike from fixya
Jun 12, 2011 | Chrysler Pacifica Cars & Trucks
Turn oven on to 350. It clicks and goes to 100. Stays at 100 and never heats up.
Assuming a digital oven with a thermometer: The 100 degree reading is probably the lowest reading the thermometer will register.
Don't give me a poor rating because I said your question was poor. Include as much information as possible including basic description of appliance and model number. Try different things and state what works as well as what does not work.
In this way, you can get better answers. As is, I know nothing about your oven except that it does not work. My keyboard will not fix your oven. It would be helpful if you convince me that you are not afraid to physically enter your oven and touch things.
:o)
Jun 03, 2011 | Maytag Ovens
Rating on the solution I gave you
I'm perplexed that the only solution involves a remote. There has to be another solution!!! Sorry if it hurts your feelings
Nov 19, 2008 | Car Audio & Video
Threads
That's good for you, but giving me a bad rating doesn't really make me want to help you with your problem that somebody else got the credit for. A "Thanks for trying" rating pulls down my overall rating, it is a bad rating. I would appreciate it more if you just did not rate me. Maybe then I can keep my high ratings for giving people free help.
By the way, it is possible that you still have many more bad solder connections. Some bad solder connections may not look bad to somebody with little or no experience detecting them. I have been repairing equipment like yours for over 18 years and I always reflow all the solder connections on a board that has only a few visible bad connections.
Please do not give me another bad rating for trying to help you. If I get another bad rating I will no longer offer help, it would not be worth getting my rating lowered for trying to help.
Oct 26, 2008 | Audio Players & Recorders
2003 GMC Safari will not start.
does your starter turn the engine at all?
Aug 23, 2008 | 2003 GMC Safari
SANYO MR929 one chanel does not work - it's a reel to reel - thanks Ian
This could be anything from bad heads to a bad pre-amp section. It is unlikely that this can be diagnosed remotely. You need to find a local repair shop that works on reel-to-reel units.
Dan
Jun 03, 2008 | Audio Players & Recorders
Computers & Internet Logo
108 people viewed this question
David Payne
David Payne
