SOURCE: how do I change belt on dyson dc 07 animal
You can't change the belt. There is a factory tool that is needed to do it.
SOURCE: Dyson DC 24 blockage between brush bar and
You can remove that short length of pipe very easily. Just pull it away from the fitting at the vacuum end and unscrew it from the brush bar end. While you've got it off, check it for splits (which are common) and replace it with a new one if it is damaged.
Testimonial: "Solved problem first time,also one we thought was a manufacturing fault,that side hose uremovable,were doing it wrong and this told us the right way."
SOURCE: how do you change the belt on a dyson DC 27
Hi its Darran at Dyson.
The belt on this machine is part of the clutch mechanism and as such we only recommend that a suitably qualified engineer carries out any repairs to this.
If you would like to talk through the options with one of our advisors, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
SOURCE: how to change the belt
With a small torx driver (not the folding kind, the screw driver kind) and some patience, the belts can be replaced pretty easily. They run about 10 bux for both (you may as well change both). Dyson, like most manufacturers, makes it seem difficult in the hopes that you'll send it back to them for repair, where they will most likely sell you the whole clutch assembly because its easier to replace than fiddling with belts.
