Question about Gateway 500XL PC Desktop
STORM HIT COMP AND WON'T BOOT
The fans do come on with the test switch but it won't boot. I have MFATXPNT MDW 500XL PH4 WITH 512 OF RAM WITH 4 SLOTS. sERIAL IS 00316 63110. i CAN'T FIND INFO FOR EXACT MEMORY UPGRADE OR WHAT POWER SUPPLY IF NEEDED.
  • 107 Answers
In all likelyness your motherboard at a minimum is dead. Take it to a technician to check and submit a claim through your house insurance
Posted on Jun 27, 2009
PC won;t boot after memory upgrade
your comp can only handle so much ram,you also need to use the same ram,check how much ram it recognizes with only two,then 3,then 4,64 bit comps only recognize 4 gb,32 bit recognizes any gb ram.
May 22, 2015 | Computers & Internet
My comp won't boot
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Oct 03, 2012 | Compaq Presario S6300NX PC Desktop
Alienware Area-51 Desktop won't boot up long beep
The fan to the left of your RAM slots needs to spin, it may be the reason for your problem. If this is the CPU fan then you may have a dead CPU.
Contact a computer technician for repair or claim warranty support.
Take care!
damnor01
Sep 21, 2012 | Alienware PC Systems Alienware Area-51®...
Computer wont boot all the way up
There are several reason why a computer won't boot up. First you need to figure out if your Power Supply is working, if your not a computer expert, you can try another PSU to test. Or you can use a PSU tester to test if your PSU is still working. If not, clean and reseat your RAM, if you have 2 RAMs, remove each RAM then try 1 RAM at a time, and try to seat the RAM to different slot. If not luck, clean and reseat your graphics card. If you have a built-in video port, remove your graphics card. Still won't boot? try resetting the CMOS. This might fix the problem.
Sep 07, 2012 | Acer Aspire X3200 PC Desktop
Hello my del inspiron 540 will not boot up when i hit the power button the cpu fan runs on high and the comp will not boot
your problems is most likely ram, hard disk, power supply or motherboard problems.
Do a test one by one of your computer hardware list above.
I suggest u test ur ram first and see what result,take out ram from slot and place it to
other slot then start your pc..(unplug power cord before you do this). if problems still
same, put it back from to its first slot.
now move to your next hardware if problem still occur.
ask assist from technician if you don't have knowledge about harddisk and motherboard
u will find what is make your problems occour.
Goodluck!!!
Feb 19, 2011 | Dell Inspiron 530 Desktop Computer
Start up Beep Beeps ton wy is that? whenn i start
if it is a continuos repeated beep beep sound your hdd cable is loose and if it comes at boot time only it is the sound for ram testing which says ram isok
if a continuos long sound comes and pc doesnot start it is the case of ram fault try cleaning contacts of ram and ram slot with alcohol methyl or spirit or Absolute vodka works best.
Dec 25, 2010 | Intel ASUS P4BGL-VM 845GL Chipset Ultra...
I have a AURORA 3500-R4 and im tryin to add 2 more mem-ddr2512pc53aw91 from a exact same AURORA 3500-R4 cus we had 2 and 1 crashed so im usein it to boost up ram on my other comp now and i...
One or more of your memory modules are bad. You need to find out which one by removing all but one. Insert it into the #1 slot and then boot. If it boots up ok, it is good. If it beeps, it is bad. Do this for all modules. replace the Bad Module(s) with new one(s).
Dec 14, 2010 | Computers & Internet
I am working on a Gateway MFATXPNT MDW 500XL....the motherboard has four slots color coded like it uses dual channel memory...all documentation I have found show that it is supposed to have 2 slots....I...
Hmm since your documentation is conflicting i would suggest that you use this little app www.sisoftware.net
Theres a free version and it will tell you everything you need to know about your computer and even suggest improvements and upgrades. You should easily find out how much ram it can take.
Oct 22, 2009 | Gateway 500XL PC Desktop
How do i remove the cover of a Gateway MFATXPNT NMZ 500SE
I found this:
"Facing front of computer you need to remove the left side cover. cover release is on top of the computer in center of side panel. Press in on button and p[ull top of side cover away."
Don't know if it's useful. If not let me know and I'll keep looking.
Mar 16, 2009 | Gateway Computers & Internet
Gateway 500XL PC Desktop Logo
378 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
