Question about Vivitar PZ 3070 35mm Point and Shoot Camera
My camera will not keep battery charge
I just got this camera and have went thru 6 batteries.it says low battery and shuts off.
  • 39 Answers
Ther is probably a shortcircuit in the battery box, try to clean it with a q tpi dipped in alcohol and make shure there is no contact between the plates.
Posted on Jul 09, 2009
New battery keeps going dead no low voltage light
Have the vehicle taken to one of many places that will test the Alternator output etc--narrow it down first without replacing that.
Voltage may drop enough to prevent starting without triggering the low voltage issue.
Jun 14, 2012 | 1997 Ford Escort
Camer keeps shutting off...it's burry and powers
Digital cameras require lots of power. Bad electrical contacts can cause lots of problems so battery and camera contacts must be cleaned properly. Batteries may be fully charged, but will be viewed as low if contacts are not really good. The LCD screen is a low steady load, but when lens extension, optical zoom, focus, and flash charging are added in the capture mode; the load is very heavy. Bad contacts make cameras do strange things like making bad pictures or shutting off with the lens out.
Do not overcharge.
Reset by removing power up to one month is the ultimate non-physical repair for DVD recorders and other software using digital devices. Digital cameras reset to original settings if batteries are removed. Time required varies with function and camera, but try one minute. Check display and setup menu for non-auto functions and date/time. Remove extra memory to eliminate this as a possible problem. Insert fully charged batteries and restart the camera.
Jul 31, 2009 | Kodak EasyShare M1033 Digital Camera
I put in new batteries and I keep getting a low battery and the camera shuts off.
Usually when that happens there should be a small hole somewhere on the camera that resets the camera, if not make sure the battery is good, even if your charger states fully charged if the battery is shot it still will not work...thx steve
Jun 20, 2009 | Samsung Digimax S730 Digital Camera
Red flashing light on battery indicator on the loading dock.
My Z760 does the same thing. When that happens I run the battery completely down by taking pictures until it shuts down. Then when I put it on the dock it charges properly. Don't leave your camera on the dock all the time and don't try to always keep the battery fully charged--instead it will develop memory and think it needs to be fully charged to run and will give you a low battery signal earlier than it should. Wait until you actually get a low battery signal before charging and it should help, but mine will still give me the red light sometimes. Then I run the battery out like I said before. I hope this information helps. :-)
Mar 14, 2009 | Kodak EasyShare Z760 Digital Camera
Low battery display
go to your local walmart and but a set of nimh rechargeable batteries and let them charg when done charging install them in to you camra then hit the menu button go to the setup display and scrool down to the battery type and choose Ni-MH this will save you battery life from 5-15 min to 5-6 hrs of life.
May 06, 2008 | Samsung Digimax D53 Digital Camera
Flashing Low Battery
Let me know if you have a solution...Mine just started doing the same thing
Dec 11, 2007 | Nikon D200 Digital Camera with 18-200mm...
Immediate Battery Draining
I had the same problem with my A345, it got worse and worse until now, everytime I try to take a photo the camera turns off. My brother has the same camera, his also does this.
Dec 02, 2007 | Fuji FinePix A345 Digital Camera
Is my camera broke?
sounds like your battery or charger might be defective. I have this camera an when the battery is to low it flashes the screen.
I still use the original charger that came with it to charge the batteries,been thru 4 of those. It seems if they set a while without being charged the go bad.
Nov 04, 2007 | Video Cameras
How do u charge battery
well u can't "charge your battery", you have to put new ones in
Sep 09, 2007 | Vivitar ViviCam 3785 Digital Camera
Charging/power problems on EX-Z55
The problem might be your charger. I would call repairs and tell them you have a defective charger and they can check it for you. You can reach them at 800-706-2534 and then keep choosing option 1 and that will take you into Casio's repair department.
Dec 08, 2006 | Casio Exilim EX-Z55 Digital Camera
Vivitar PZ 3070 35mm Point and Shoot Camera Logo
57 people viewed this question
Top Vivitar Cameras Experts
SHARCNET-USA
SHARCNET-USA
James Woodgreaves
James Woodgreaves
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
