Question about Boating
Have 2hp evinrude junior. Shear pin broke today. Have taken prop off but am not sure how to refit another. ?! Where does it slide in???? Was it one long pin to begin with? Does the inside of the prop screw out? Sore and sorry after a long paddle! More than a little confused. D
  • 5,687 Answers
You can use a nail to drive out what remains in the shaft. The pin is one long pin and sticks out of both sides of the shaft. The prop rides the T the pin makes. You should see a slot on the rear of the prop. I usually keep 4 pins in my fishing box all the time.
Posted on Jun 27, 2009
Minnkota endura c-50 shear pin size
You can get the appropriate pins in the prop not kits sold by minn Kota or thru major retailers.
Trolling Motor Replacement Props Minn Kota Motors
You will find prop nut kits here just follow the link.
Sep 28, 2014 | Minn Kota MinnKota MK110P Marine Portable...
Outboard motor shaft disconnected from prop
Need more information. Does your prop have a shear pin or a rubber bushing. Did you hit bottom with the prop, or the skew?
Jun 05, 2013 | Boating
1992 Evinrude Motor will start but when put in forward or reverse the propeller will not move
If it runs OK leave the carbs alone- You need to start with the final drive and prop condition. Put it in gear and step on the prop blade to try and turn it. (sometimes you need to try and force it backward from the gear its in due to the engineering of the clutch dogs.
The results of this can tell you a lot. First if the prop spins freely- you have a broken shear pin in the propeller (older units),
if it spins smoothly but with drag- you may have damaged the rubber hub of the prop. Mark the inside part of the prop (the hub) and the blade section and try again- check the marks to see if the prop is wrecked (if they don't move from one another your OK.
Next drain the lower oil and look for metal, and water contamination (looks like mayonnaise) If full of metal, the gears and clutch dog are trashed,
Last and worst of the catastrophic is if the splines in the crank and drive shaft are broke. The water pump will not work if this is the problem.
The easier stuff is a stretched or broken control system. Easy test is -if on a cable/ release the cable and manually shift it. If it shifts you work on the control box and cables if it is not shifting check the connector to the lower unit. If early style evinrude, it is hiding behind one or 2 covers on the stb side mid way down the intermediate housing. In side will be a brass duble bolted connector. Shift again and watch the connector. If it isn't moving. the problem is under the power hed, if it is moving the problem is in the clutch yoke or arm that moves it. (Common mistake when the pivot pin/phillips screw ahead of the drain screw is mistakenly removed as a drain vent.)
Jul 29, 2012 | Boating
1978 johnson 25 hp
Hi, make sure you are using a genuine pin and if so check the back of the prop where the pin sits for wear, regards Phil.
Jun 11, 2012 | Boating
1973 chrysler outboard 12.9. does it have a shear pin?
If you can't see a shear pin,it most likely will have a rubber bush in the prop hub that superceded shear pins.I am not 100% sure on your motor but that is what all motors have today.The bush is inside the hub of the prop and with the prop off,you cant see it.If the motor revs up when in gear,and you are getting no drive,this is the problem.Hope this helps
Jun 18, 2010 | Boating
Boat motor while in water revs extremely high after about half throttle with no additional thrust
It sounds like the prop bushing is bad. There are 2 systems for preventing gear damage,shear pins and rubber prop bushings.
The rubber bushing can be molded to the prop or there is a type that has a sleeve the prop fits over. If the prop has no sleeve you need to take the prop off and have it relined. It will fail soon, its just a matter of time. If you have the removeable sleeve, you replace the sleeve and just slide the prop over it and you are done.
The diminished thrust is due to the rubber slipping from its bond and it will get looser and looser.
May 04, 2010 | Light Outboard Motor Boat Bass Fishing...
Trolls at low speed but no high speed thrust, I was told it may be the sheer pin however I have no idea where that is or how to fix it
The manufacturers make several safety devices to keep the gears from breaking. A shear pin is an older idea and usually its either broken or not.
What you probably have is a Rubber coupler in the prop hub. This part looks like a rubber bushing and lines the prop. It crumbles when it breaks and will jam enough to let you limp in at low speed. But it will eventually fail at low speeds if you run it too long that way.
Some manufacturers bond the Rubber to the prop and you have to get the prop serviced. Others have an inset that you just pull off the output shaft and replace. Then you slide your prop over the insert and you're done.
Apr 18, 2010 | Boating
The prop will turn on my minn kota endura 44 but it has no power is there a shear pin on this motor
Odds are you have sheared the pin (slides through the prop shaft) holding the prop, or you have damaged the slot on the prop that the pin sits in.
Prop is secured to the shaft with a metal nut, or flat plastic wing nut. Remove the nut to remove the prop. You may have to pry, slightly, the prop from the motor housing. Removed, you will see a whole in the shaft where a pin should be located. If the pin broke, it probably hit the floor when the prop was loosened. If the pin is intact, examine the rear side of the prop and look for damage to the plastic slot where the pin would sit making contact.
If you've snapped the pin, you can make a replacement with a nail using a hacksaw. Replacement pins can also be ordered from Minn Kota. If the back side of the prop is damaged (recess for the pin to sit), the prop is toast. Replacement props are often carried by Walmart, and include a new pin.
If neither part is broken, perhaps the prop was just not seated on the pin correctly allowing the prop to freewheel.
May 04, 2009 | Minn Kota Endura 30 Freshwater Transom...
Boating Logo
355 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
