Question about Samsung SC-D103 Mini DV Digital Camcorder
Screen flashes protection; can't record
The screen flashes protection and I cant record. I cannot find how to turn off protection in the settings.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
Check the protection tab on the memory card of your camcorder. move the protection tab to no.
Posted on Jun 30, 2009
I have briught a panasonic dvd-ram like it say's in the manual to record tv programs when i am out and it comes up disc protection on go to page 11 in manual to turn off and i cant figue it out please help...
Easy fix
On your remote press "Functions"
A menu will appear on your screen. Use the up / down keys on your remote to select "Disc Management" You should see a tab marked "Disc Protection" Use the up / down keys on your remote again to select this tab. You should now be able to turn the protection off. When you gave finished, press Enter and then Return on your remote.
Please note, the Disc Protection function is used when you have made a recording and you do not want to record over it or erase it by mistake.
Hope this helps
Jul 07, 2010 | Panasonic DMR-E50 DVD Recorder
When i put a tape in it ejects it..then a tape with a slash appears on the screen
you are prohibited from recording on thips tape. This is because the red tab on the side of the tape that faces you when you are inserting the tape inside the camera has been put in 'SAVE' position . to be able to record o the tape you need to use your fingernail to slide the red tab to the 'REC' position.
Ive extracted the following article for you from wilkepedia to help you understand this issue:
Tape and recording protection
250px-8mm_cassette_erase_tab.jpg magnify-clip.pngThe write-protect switch (right) prevents accidental erasure. .
To prevent the recording on the tape from being erased, there is a small write-protect tab that can be moved to one of two positions, labeled "REC" and "SAVE". Comparing the sliding tab to a door, the tape is in the "REC" position is when the "door" is open and the "SAVE" position when it is closed. (Not all tape cases have markings for this information!) The tape can only be recorded on (or recorded over) when this tab is in the "REC" position. This is an improved version of the VHS write-protect tab, which prevents erasure after it has been (permanently) broken off.
Dec 02, 2009 | Sony Handycam CCD-TRV318 Camcorder
Cant record new video
check the memory card that you've inserted on your camcorder. tilt the protection tab of the memory card to unprotect it.
Jun 29, 2009 | Samsung SC-D372 Camcorder
New TV 9 mos old, Won't stay on after power up? Remote or manual turn on, set keeps turning off after 1-2 second green on and brief screen flash.
I would try leaving the TV unplugged for 30mins so the TV can reset itself.
If that doesn't work, your TV should still be under warranty. I know 95% of come with a 1 year warranty.
The most common problem with Sylvania TVs made by FUNAI, the Backlight Inverter board fails to early in life. ( That's the part that powers the screen)
The Tv can't power up the screen and it turns off automatically. Basically called "Protection Mode" so it protects the other parts inside the TV.
Jun 01, 2009 | Sylvania LC320SS8 32 in. LCD Television
Can't record due to screen flashing "Protection"
i would have thought that the setting might have been change on a accident you should take it to a shop and ask them!
Apr 13, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
PROTECTION flashing on lcd screen
there should be a little tab on the tape that can be moved (the one on my tape is red) if it is closed it stops the tape from being able to record anything and if it is open you should not see the protection on the screen
Apr 08, 2009 | Samsung SC-L810 Camcorder
Wont let me record! Flashes "Protection!"
My Samsung camcorder one day displays protection. Used or new tape no difference. Used the menu options to remove protection and it gives me a play mode alert. Regardless I can not record in protection mode. Help!
Feb 08, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Screen says cant record copy protected movie
Is this a new problem or has it always been like this? The unit will throw that error message if there's a copy protection flag on the broadcast source.
To make matters worse, there are three flags a broadcaster can set. Copy Always, Copy Once, and Copy Never.
Copy Always and Copy Never are pretty self-explanatory but the Copy Once flag with this unit only works with certain media, namely DVD-RAM and DVD-RW in VR mode with CPRM (Content Protection for Recordable Media.
Copy Always flag should work with all media. I don't know of any easy way to figure out which broadcasts have which flag but try changing your media and recording mode first.
P.S. You may also want to reset to factory default settings by pressing FF and RW together on the player. Also make sure you're running the latest firmware.
Good Luck!
Feb 02, 2009 | Samsung DVD-VR357
Samsung Mini DV camcorder (Protection-Problem)
SOUNDS LIKE THE TAPE TRANSPORT IS BAD. IT WILL EAT YOUR TAPE SOON. YOU WILL NEED A NEW TRANSPORT OR A NEW CAMCORDER ...SORRY
Dec 14, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Protection! Flashes on screen
This camera has a history of the flexible harness located on the cassette housing tearing when it rubs against the frame as the housing moves in and out. The harness tears and opens the circuit that detects the tapes record lockout tab, the camera is preventing you from recording on the tape in error. This repair requires replacemnent of the cassette housing, not for the faint of heart. I wish you luck. Joe Weibel customelectronics.org
Feb 04, 2007 | Samsung SC-D103 Mini DV Digital Camcorder
Samsung SC-D103 Mini DV Digital Camcorder Logo
587 people viewed this question
Top Samsung Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
