Question about Samsung LN-T4661F 46 in. LCD HDTV
When I press the power button the system tries to turn on, but just clicks. The power light comes on, and then clicks and power light goes off, then clicks and power light comes on, and so on, and so on for ever. If I unplug it, it stops. Dugh!!! Plug it back in, and it starts again wih out me pressing the button again. Thanks in advance. Jerry Mattox
  • 187 Answers
Mainboard damaged, replace it and the TV will work just fine.
Posted on Jun 27, 2009
Ps3 starts then turns off
try holding down the power button for 3 seconds
Apr 30, 2013 | Sony Playstation 3 120gb Video Game System...
My ps3 will not turn on. the light comes on then beeps and turns off
try rebuilding the database and the file system in recovery consol
to get to the recovery consol press and hold the power button when ps3 is in standby mode(red light) till you hear a double beep. sometimes the ps3 does a beep then another beep and goes back into standby thsi is fine just release the power and quikly press and hold it again till you get double beep.
like on my 80g system it goes like this
ps3 standby...press hold power.......beep .........beep........stanby again....release and hold power again.......beep .........double beep...release power now you should be in recovery menu.
Oct 28, 2009 | Sony Playstation 3 (PS3) Console
My ps3 turns on but only the theme background appears it turns on and it says ps3,that goes away and when the icons should be coming up,they dont! help please!!
Oct 24, 2009 | Sony PlayStation 3 40GB System
HP Pavillion dv9700 won't power up
Try removing the battery and using only power cord to turn the laptop on. If that fails, try turning it on without power cord, just on battery.
If none of those work, then most probable cause of your problem is motherboard. Hopefuly you are either under manufacturer warranty or you have extended warranty with your vendor where you've purchased the laptop.
If your laptop turns on on power cord, but without battery, then battery is the problem. Also, if laptop turns on when it's only on battery but it doesn't when you plug ac cord in it, then the adapter is the problem.
Jun 01, 2009 | HP Pavilion dv9700t Notebook PC
Tower problems
You may need to replace the cmos battery, its a cr2032 3v button cell
Make sure all your expansion cards and memory are reseated.
Make sure all cables are reseated.
your power supply could be bad
If that doesn't work try this
Here is my fix for the dell dimension 4400 amber light problem. It works!
replace cmos battery.
then unplug power cord form wall about 5-10 secs.
then plug it back in, wait 5 secs.
If amber light comes on, press and hold power button until it goes out.
(with light out, press and hold power button while amber light comes on and goes off again holding power button 2-3 secs after light goes out.) repeat whats in parenthesis until computer turns on
it should only take about 6, 7 tries.
After the computer boots, you may want to setup cmos or boot into windows.
After you shutdown, unplug power cord for 5-10 secs then plug it back in.
Press and hold the power button, computer should come on.
I found that's the only way to turn on the computer.
If you shutdown and don't unplug power cord the computer may not boot, mine didn't.
Strange I'd say
A+ Technician
Apr 01, 2009 | HP Computers & Internet
Dell Dimension 4400 Won't Turn On
inside the pc there should be a green light. called flea light. if its not on.. then id say motherboard or power supply are bad.
take power cord off. and hold power button down for 10 ecs. then reconnect and retry. i think its abad psu.
Oct 09, 2008 | Dell Dimension 4400 Power Supply ** FREE...
Power button/light
run a diagnostics
turn off your system
press and hold Fn key ,power on the system, leave Fn key
it will start running a diagnostic
if any error code is generated let me know and also provide me your system's service tag located at the bottom pannel of your system, turn it upside down you will find a bar coded sticker which has a 7 digit alphanumeric number
Jun 05, 2008 | Dell Latitude D600 Notebook
Snooze button on my acer keyboard
To disable the sleep button on the acer keyboard Do the following (Vista home)
Go to control panel (classic view) double click Power options.
left hand margin select Choose what the power buttons do.
This opens a systems settings page
You will see an option :
When I press the sleep button: (Don't worry that the picture of the button is different than the keyboard's Zz)
Select Do Nothing from the dropdown box.
Click the Save changes button at the bottom of the screen.
This will disable the button on the keyboard...
May 28, 2008 | Acer NSK8458AN Keyboard
Screen goes blank
Your Computer enters Stand-By mode when untouched for more than one hour. This appears to be NOT A PROBLEM but the SETTINGS need be adjusted. Follow these SIMPLE steps to resolve it: -
(1) Goto Control Panel>Power Options>Power Schemes,
(2) Set the System standby to Never.
(3) Click Apply.
(4) Click OK.
Your Problem finished.
SAHAJA YOGA IS THE ONLY GATEWAY TO THE KINGDOM OF GOD AND IS THE CULMIINATION OF ALL THE RELIGIONS AND SPIRITUAL TRADITIONS OF WORLD.
May 24, 2008 | Computers & Internet
Hard Disk Problem
bad power supply from on and off so much change that out
are u on labtop tho then u may have to redo it may gotten bug run trendmicro.com see scan for bugs do windows upidate
Jan 26, 2008 | Microsoft Windows XP Media Center Edition...
Samsung LN-T4661F 46 in. LCD HDTV Logo
338 people viewed this question
Jerry Greenberg
Jerry Greenberg
