Question about Brother IntelliFAX 2800 Laser Fax
Detecting tel/fax Our machine is set to fax/tel and is picking up on all telephone calls. We recently went from two distinct lines to one with distinctive ring. From the jack we have a dsl filter then to the LINE port. The receive mode is set as tel/fax. When I set the receive mode as manual it will stop picking up on all phone calls but continues to ring without picking up a fax either.
    An user who is expert in 3 categories / brands.
  • Brother Master
  • 1,346 Answers
Re: detecting tel/fax
0 characters
3 Points
Hp 4620 will send faxes but won't receive. Auto answer on and tried all rings and distinctive rings but won't pick up. Tried auto detect but still won't pick up.
Check if the line is connected in the right JACK, should be connected in the LINE not in the TEL. Sometimes in commercial area TEL SERVICE MAN BRAKES ONE OF THE WIRES IN THE BLOCK CONNECTION.
Oct 20, 2013 | HEWLETT-PACKARD HP 2140 Fax
Our HP 2140 fax under distinctive ring setting DRPD was answering under our Master ring (double Ring) until yesterday it switched inside somehow where it now answers regular phone ring instead of...
Was the fax plugged into another telephone line? Maybe a power surge?
My solution would be to reconfigure the fax from scratch to learn the ring pattern.
From the Manual:
Step 1-Teach the HP Fax the ring pattern
The HP Fax will learn the ring pattern when you call it from another telephone or fax
1. Be ready to call the fax machine.
2. Press Menu repeatedly until BASIC FAX displays and press OK.
3. Use LEFT ARROW - RIGHT ARROW BUTTONS to scroll through the options until DRPD Mode displays and press OK.
Call this fax from another fax machine... Waiting Ring...
will display.
4. Call the HP Fax.
DRPD OK will display when the pattern has been learned and the HP Fax will return
to Ready mode.
Step 2-Set up distinctive ring (DRPD) answer mode
Once you have activated distinctive ring, it becomes one of the answering modes you
can select by pressing the Mode/Contrast button.
Press Mode/Contrast repeatedly until DRPD Mode appears in the display.
• In Ready mode, DRPD appears in the right hand corner of the display.
• Now, the HP Fax will manage calls and faxes as if it were set to AUTO mode
(AUTO mode on page 28)
TIP: Distinctive ring must be set up again if you reassign your fax number
or connect the machine to another telephone line. Once set up again (that
is, the fax machine has learned the ring pattern and the answering mode is
correctly set), you should test the fax machine by calling the fax number
and another number on the same line. The machine should respond
appropriately to a call placed to the fax number with fax tones, and to a
normal telephone call with the expected ring pattern.
Mar 04, 2011 | HEWLETT-PACKARD HP 2140 Fax
How do I set it up as a fax along with my using my telephone on the same phone number
somewhere in the user settings it will have a tel/fax setting wich will allow you to hit "start" to manually receive a fax, also some phone companies can set you up with a distinctive ring for faxing, so you won't need to do a manual receive. when you pick up the phone in the tel/fax mode and hear the fax screech then hit the start button to begin receiving. hope this helps.
Jan 10, 2010 | Brother IntelliFAX 2800 Laser Fax
Receiving Faxes
You will have to ask yourself the question "What has changed?" If you changed nothing, then something else has that is beyond your control. Now, you have to decide whether you are using a single telephone line for faxes and telephone, or whether you have "distinctive ring" also called "smart ring" by some companies. It is not a smart thing to use both. You can print a list of settings to see what the machine is set to do. Now if you want to use distinctive ring, set the ring pattern to the one you have chosen with the tel company. If you have chosen a double ring, and you have set your panasonic telephone to receive on 4 rings, then it will count all the rings and pick up after only 2 sequences. To see if this is the problem just remove the telephone base station from the system and then try to receive a fax.
Jun 08, 2008 | Brother IntelliFAX 2800 Laser Fax
Setting personalized ring
Its called distintive Ring. This is the instructions from the manual -
If you have Voice Mail or a TAD (Telephone Answering Device) and want to keep
one of your phone numbers dedicated only to fax calls, you must leave the fax machine
in MANUAL mode at all times while using the distinctive ring feature. Here’s why:
Manual mode will never pick up a call by itself, since it is «Neutral ». When the fax
machine is in this « neutral » mode, the Distinctive Ring Feature can be activated. The
distinctive ring feature is actually an answering mode. So, do not activate FAX ONLY
mode or FAX /TEL mode while using distinctive ring; otherwise, the fax machine will
answer calls for all the numbers.
Registering the Distinctive Ring Pattern
Set the fax machine to MANUAL mode.
2 Press Menu/Set, 0, 1.
3 Press to select DISTINCTIVE:SET?, and then press Menu/Set.
4 Press to select the prestored ring pattern you want to assign, and then press
Menu/Set. (You will hear each pattern as you scroll through the four patterns.)
Be sure to choose the pattern assigned by the Telephone Company.
5 Press Stop/Exit.
and a link to the manual if you need it -
Feb 21, 2008 | Brother IntelliFAX 775 Plain Paper Thermal...
To recieve fax on brother
Press the 'RECEIVE MODE' button on the right side of the control panel, its next to the large 'FAX START' button. Here are your options :
Select Receive Mode
—You must answer all calls yourself. If you hear fax tones, press
Fax Start
to begin receiving the fax, then hang up. You can use this mode with
Distinctive Ringing. (See
Distinctive Ring
, page 8-1.)
—The fax machine automatically answers every call as a fax call. You
cannot receive a voice call, but you can dial out and make a voice call.
—The fax machine automatically answers every call. If the call is a fax, it
prints the fax. If the call is not a fax, it signals you with a double-ring (ring-ring),
different from the phone company ringing, to alert you to pick up the call. If you select
this setting, you’ll need to set the Ring Delay and F/T Ring Time features (on the
following pages). If you have extension phones on the same line as the fax machine,
set Ring Delay to 4. (See
For FAX/TEL Mode Only
, page 5-5.)
—This is the only setting in which you can use an external
answering machine. Your telephone answering device is connected to your fax
machine, and answers every call. Once the TAD answers, the fax machine listens for
fax tones. If it detects fax tones, it prints the fax.
The TAD setting works
with an external telephone answering device (TAD); it
does not work with telephone company Voice Mail. Ring Delay and F/T Ring Time
work in this setting.
Nov 27, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
Hooking up a fax machine on home telephone line
Well... the problem is that you are running two machines on one line. ONE of them has to take predominance. Both machines should have settings for "number of rings to answer at". It sounds like you currently have the fax set to less than the answering machine, so the fax picks up after two rings, while your answering machine might be set to more, which it never gets to, because the fax answered the call already(It doesn't matter if you answer the phone, or the fax picks up, once the line is open, the answering machine is taken out of the equation). Even if you set the answering machine to answer first, you're then taking the fax service out of the loop. I'm not sure how you're going to juggle that, since both types of machines each need control over the line to work properly. That's why we (business machine folk) always recommend a dedicated line for fax service.
Jan 23, 2007 | Canon FAXPHONE L170 Plain Paper Laser
Can I use this fax on a telephone line together with a GE 2.4 GHz Cordless Telephone (Model 27992B)? Will it be possible to recive messages and faxes when no one is at home? Remark: The answering machine...
sure u can: Installation with an answering machine and/or extension telephone: 1. Remove the seal covering the TEL. SET jack on the rear of the fax. Connect an extension telephone or answering machine to the TEL. SET jack. 2. If desired, connect an extension phone to the answering machine. from the user Fax guide: If desired,you can also connect an answering machine or an extension telephone to your fax. ¨ Connecting an answering machine to the fax will allow you to receive both voice and fax messages on the same line while you are out. For details on using this feature, see Chapter 7. (Note: Do not connect an answering machine to your fax if you will be using the distinctive ring feature described in Chapter 2.) ¨ You can connect an extension phone to the fax to make and receive calls like any other extension phone on your line.
Oct 09, 2005 | Sharp UX 510 Plain Paper Thermal transfer...
Brother IntelliFAX 2800 Laser Fax Logo
123 people viewed this question
Top Brother Fax Machines Experts
Paul King
Paul King
john archer
Are you a Brother Fax Machine Expert? Answer questions, earn points and help others
