Question about BonJour 53372 Wine Cube Refrigerator
FRIDGE FAN DOES NOT COME ON - BonJour 53372 Wine Cube Refrigerator
  • 82 Answers
What is the cooling problem? Have you checked the fan after holding in the light / fan switch. Some fans go off when the door is open. Fan is probably stuck due to lack of lubrication. Check fan to see if it spins freely. UNPLUG UNIT BEFORE EXPOSING WIRES, be sure you are clear before plugging in while doing test runs etc.
Posted on Jun 27, 2009
The fan on my Miele fridge freezer is not working, how do I rectify this issue
Check first input power supply of fan if its OK then problems can possible in the fan motor . you can check pre fuse by a tester with continuity method
Jul 21, 2016 | Miele Refrigerators
My GE fridge PSi23SGNA BS freezer defrosted.
Condenser fan should be about 1300 rpm, I believe!
Jun 13, 2012 | GE Refrigerators
Freezer too hot top shelf - fridge frozen on bottom drawer
I would replace the fan or fan switch if it has one
Apr 27, 2017 | Refrigerators
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
Kenmore side by side fridge. Green temp light flashing for fridge side, freezer side working fine. Fridge side not cooling.
possibly frosted up at the air door between the fridge and freezer, or the fan in the freezer is not pushing cold air into the fridge side, if you can not hear a fan running in the freezer when the fridge is running (compressor on) then change out the fan
Jul 18, 2011 | Kenmore Side by Side Refrigerator
Fridge not cold
you have a fan motor and blade located between the fridge and freezer. What this fan does is regulates the temp of the fridge from the coldness of the freezer. If this fan is out the fridge will be warm. The fan is losacted in the space between the fridge and freezer on the inside near you temp control switch. Look at the top of the fridge on the inside and you will see a set of vents. The fan is located behind these slotted vents. Take care in removing the plastic cover and remove the motor. Take model and serial# to an appliance parts house for proper replacement.
Hope this helped you some
Dave
Jan 22, 2010 | Hotpoint HSS25GFP Side by Side...
GE side by side fridge/freezer. Fan in fridge is not spinning.
Replace that fan that blows the cold air into the refrigiator.
Jan 06, 2009 | Refrigerators
Fridge doesn't get cold enough
 If the evaporator fan is not running. The fan itself could be faulty or the door operated light/fan switch could be faulty.
If the evaporator fan is running. The fridge is not defrosting and ice has built up on the evaporator and the air is not circulating properly into the fridge compartment. The fan circulates cold air into the fridge and back through the fridge control which is normally just an adjustable flap which allows more or less cold into the fridge depending on the setting. If the fridge is not defrosting, the defrost timer could be faulty or heater element could be blown.
Nov 03, 2007 | Roper RT12VKX Top Freezer Refrigerator
Refrigerators Logo
156 people viewed this question
Top BonJour Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a BonJour Refrigerator Expert? Answer questions, earn points and help others
