Question about Navman F20 GPS Receiver
Navman f20 navman in car charger stopped working, used a phone charger with alower output which did not breath any signs of life into it. bought a new genuine f20 in car charger and still nothing happened.
  • NBCFC Feb 20, 2008
    I used a travel adaptor to re-charge my navman F20 ans since then it wont work, I've tried to reset it, but no joy. Any suggestions?
This is because of high voltage in input AC power so u have to replace it
Posted on Nov 12, 2007
Hi I have a navman f20 which shows a batterey with a x on the display then turns off I have allowed the unit to discharge fully when on recharge it shows the same display
The battery is defective or your charger is not working. Most likely it is the battery but the charger is a possible until checked. You may want to find a gps shop and find out if they can get a battery.You can also contact Navman and talk to support about sending it in to them for repair. The battery should be about $20 plus labour to install.
http://www.navman.com/
Sep 06, 2011 | Navman F20 GPS Receiver
I have a navman F35/F37 model that I just purchased. Comes with a car charger but no home charger. Can I use my US Garmin charger instead?
Welcome to FixYa!
No, you cannot use the Garmin charger on your NavMan. Even though it is of the same voltage, the mA is most likely different. It may work, but it might also damage your NavMan's electronic board and circuits.
You can use a universal charger that is available the electronic stores but make sure that it is compatible with Navman.
Thank you for using Fixya.
Have a great day.
Jas247
Jul 22, 2011 | GPS
I havent used my navman for a while and now it will not charge up from the cigaret lighter connection although the connector does light up
Often the ni-Cad or LiFe cells get so flat they need a special charger with high current. They just will NOT charge up any other method, it may be best if you replace the battery, you need to open up the unit to do that. There is a "Pack" inside. You can get batteries fro,m manufacturer or eBay Craig's list Google etc. However now you would also have to reinstall the software again if not lucky. There are tutorial how to do what you want on the Navman web site
Mar 13, 2010 | Navman F20 GPS Receiver
Navman f20 will charge fron usb port on computer but not with in car charger
If it's not the original Navman usb loader then there's a easy solution to this : With a sharp knife carefully open the usb cable : you'll see four tiny cable's with different colours . You;ll have to cut two of those four cables ; Leave the black and red cable intact.
Use some tape to fix the cut in the usb cable. Now you can use your car charger and your navman won't go into usb mode.
Dec 08, 2009 | Navman F20 GPS Receiver
Hi i just bought the navman icn 510 how do i upgrade the uk map thanks
I go to the manufactor's website and download them from there using a usb cable.
Nov 20, 2009 | Navman ICN510 GPS Receiver
My phone is not coming back on
Re4asons for phone not coming on are: Dead battery or dead battery because of dead charger. Use the charger elsewhere to check if it is charging. If yes then use battery elsewhere to see if it has the required charge. If both are working fine then
A dead phone. Or does it show some signs of life like some LED flashing or blinking???? If yes then the phone is not dead yet. It requires reinstall of firmware. Please do that and the phone has a fair amount of chance of springing back to life.
While if there are no signs of life what so ever, then friend the phone may really be dead and can be used as a paper weight on your desk.
Nov 09, 2009 | Motorola Mobility V360 Cellular Phone
Instructions for navman F20 sat nav
I bought the same, but managed to download the manual from navman. Try again friend.
Jun 13, 2009 | Navman F20 GPS Receiver
Navman icn 720 gps will not power on
Poss that the battery is totally dead, and therfore will not power up even when on ac or 12v charger lead. Often the battery is part of the circuit, and if the battery is dead rather than just weak or discharged, then the circuit is incomplete.
I posted on here how to remove the battery, you can get a replacement quite easily. Also would be an idea to search out a correct output charger, or maybe borrow one just to determine if the problem was with the battery rather than a blown unit.
Good Luck
Feb 16, 2009 | Navman iCN 330 GPS Receiver
Will not charge, or turn on
Probably the plug on the navman has suffered what we call dry solder joints from inserting and pulling out the charger you need a tech to fix it. soldering is nesessary shouldnt be too expensive I fixed mine its about half an hours work if not too damaged inside
Feb 15, 2009 | Navman F20 GPS Receiver
Navman F20 GPS Receiver Logo
269 people viewed this question
Top Navman GPS Experts
Martin Murray
Are you a Navman GPS Expert? Answer questions, earn points and help others
