Question about Toshiba 51H84 51" Rear Projection HDTV-Ready Television
No picture, just went off while watching tv
We were watching the tv one day and the picture collapsed to the middle and went black. The red power light was blinking and the tv itself was making a clicking noise. The 1st repair guy said it needed a new transistor..he ordered one from Toshiba, it worked for 2 weeks leaving a pink line in the middle of the picture (repair man said it was because the bulbs burned that line there when the picture collapsed). I called them back out when it went out again and they put in another transistor thinking the 1st one was defective. (these took 4 weeks to get by the way). Again, worked for 2 weeks then went black again. Called Sperry TV out and they said another part needed to be fixed. They ordered it, when he put it in, something blew and he said, "I think the other repair main sabotaged your tv." Sperry ordered 3 parts thinking this would solve the problem and it didn't. He now says they need to take the tv into their shop, do a probe (which will cost me $159 even if they can't fix it), and then go from there. Metro, the 1st repair place, said I needed to replace all the bulbs for it to be fixed...the 3 big bulbs in the tv which are about $250 each. I don't know who to believe, I think one of them ruined my tv when it could have been a simple fix, and now I don't know what I should do. When I bought the tv it was almost $4000.00 so I kinda feel like I should pay to have it fixed instead of buying a new one...what can I do?
  • 3,130 Answers
The pink lines in the set happened when the first time it blew out. It is called a burn in on the inside surface of the picture tubes. Not the fault of the TV repair guy. This is the fault of Toshiba. This set has known to have this happen and you should contact toshiba and request that they replace all three tubes for you at no cost. You should also stop using these repair guys who cannot fix a simple vertical problem. Find out who is authorized for Toshiba in your area and call them. They will know, or should know the problems that happens with this model number and take care of them once and for all. Good Luck
Posted on Nov 07, 2007
  • Larry  Dillon
    Larry Dillon Nov 27, 2007
    Did you expect me to reach through the internet and fix the TV set. Thanks for the great rating.
Toshiba tv no powere no light
Could be an open internal fuse or abrupt power supply failure
May 05, 2017 | Toshiba Televison & Video
RCA Model# LED32B30RQD Tv has sound no picture. Picture went black while i was watching it. Can see image in dark room with flash light. TV has power supply board, video board. Start with video board?
That board right in the middle is the power board and it powers the LED backlights. This is a common failure on this model and the board is not in stock in most places.
Mar 17, 2016 | RCA Televison & Video
How do I fix the problem with my TV? Details are below.
Normally on the Panasonic tv this will call for a service call. The key to getting it repaired correctly is to check for a certified Samsung repair shop because most of the parts come from Samsung. Now if you want to do your own research call to 800 number for Panasonic Tv see if there are any problems with that model that the manufacturer has extended but does not post. I had one repaired that the red light on also so I understand and it went out approximately 4 3/4 years. If your in the Atlanta area use Norman electronics they have repaired hundreds on tvs for me due to my work.
Mar 05, 2016 | Panasonic VIERA TC-P55ST30 55-Inch 1080p...
Picture looks dark
I have same model. First set went out of convergence, and I was able to adjust it. A few days later I had same problem and fixed it again. Then I was no longer able to adjust it. I watched TV the way it was. The picture got darker.Then I was watching TV, and there was a flash from the middle of the picture, and TV powered itself off. I unplugged TV and plugged it in 30 seconds later. I powered TV on, and red LED on front panel blinked a few times, and stopped. TV powered itself off.
From what I learned, the LAMP has to be replaced, and so do the convergence chips and convergence resistors. The TV shop charges around $300 and up just for the convergence chips. The TV is selling on craigs list for $150 to $200 in good working condition.
You have to decide if the repairs are worth your while. Probably not in mmost cases.
Sep 24, 2012 | Hitachi 50GX30B 50". Rear Projection...
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
My tv is 2 years old and in the last month or so in the middle of a show the screen will go black and a red line runs down the middle and it lasts for about 5 min and a little pop sound and the picture...
It appears you may have had a line collapse caused by a poor connection in the line output stage, it would be a matter of resoldering around this area. Now that you say it will come on could indicate that a component has now failed as a result of the line collapsing, more than likely the line output transistor has now also failed & would need replacing.
Jul 01, 2009 | Jensen Q2749J 27" TV
Sony Trinitron 20" TV (KV-2093R) Suddenly Shut Off
2 things that will cause that vertical IC or Yoke! Listen to this one went on service call 2wks ago Customer had a 50 INCH1988 pioneer big screen replaced 3 capacitors resolder poor connections TV is now working like New ?
Jun 23, 2009 | Sony KP-51HW40 51" Rear Projection...
No picture no sound
Did you mean the picture is collapsed only in the middle horizontally(white line appears on the middle part of the screen)?
If that is the case, maybe vertical IC failed or loose connection.
Apr 05, 2009 | Toshiba CF32H40 32" TV
Problem with tv
Its known as 'screen collapse' and yes it can be fixed but it may not be economical you should get some quotes from your local tv repairers.
Nov 14, 2007 | Televison & Video
Toshiba 51H84 51" Rear Projection HDTV-Ready Television Logo
157 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
