Question about Engel MT60F-U1 Commercial Refrigerator
My engel MT60F motor turns on for 1-2 seconds and then off again. The fridge temp won't get below about 15 degrees. what would the problem be?
  • 3,267 Answers
Looks either your thermostat is malfunctioning. If thermostat is OK then the problem might lie in loss of refrigerant gas, freon or CF4. Get these 2 items checked in the above sequence..sodeep
Posted on Jun 27, 2009
Fridge now constantly CYCLES ON AND OFF for 10 to 15 minutes
Perhaps calling in a refrigerator repair man so he can check the freon as that is what causes them to run alot more than normal
Jun 03, 2016 | Westinghouse Refrigerators
It runs but will not get cold
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 25, 2011 | Engel MT60F-U1 Commercial Refrigerator
My 39ltr Engel is only freezing on 1 side the other is only cool
This sounds like a water problem. Both sides should be at comparable temps. Is this a model with door instant ice/and/or icemaker?
Mar 09, 2010 | Engel Freezer 22 Qt. Fridge/Freezer
Power supply for Engel
from your battery or power socket in the wall of a house
Mar 07, 2010 | Engel MT60F-U1 Commercial Refrigerator
Freezer works great, but fridg. will not get below 50
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
Sep 17, 2009 | Maytag MZD2766GES Side by Side...
HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Aug 02, 2009 | Frigidaire Freezers
Engel mt60f compr running not getting cold
If the compresor is running and the fan motor by the compresor too, I think there's not freon(gas) in the system beacause a leak,thst could hard to find it,could be in the copper pipes joints ,in the evaporator or in the condenser,to find it you need to presurase the system with freon and look for the leak with a leak detector(electronic,ultraviolet or bubles).Also it could be that the compresor isn't pumping in that case you need to replace it.
Apr 10, 2009 | Engel MT60F-U1 Commercial Refrigerator
Motor goes on/off every few second.
You have problem with the motor compressor,it is trying to start, but cannot for one reason or another, could be siezed motor, sticking start relay.etc'
It is stopping and starting due to the motor overload device cutting in and out. it acts as a safety device.
This is usually associated with a serious malfunction..Plz rate my solution.
Thanks.
Dec 28, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Engel MT60F-U1 Commercial Refrigerator Logo
421 people viewed this question
Top Engel Refrigerators Experts
Jaime Hernandez
christian nielsen
cwradio73
Are you an Engel Refrigerator Expert? Answer questions, earn points and help others
