Question about Broderbund The Print Shop 21 Deluxe Full Version for PC
Cannot install print shop 21 in windows 8.1 - Broderbund The Print Shop 21 Deluxe Full Version for PC
5 Suggested Answers
SOURCE:
SOURCE: Can install Print Shop 21, but when the splash
Solution
You must reinstall Microsoft .net framework.
You can do this by:
Go to the control panel
Go to add remove program select Microsoft .netframework 1.1 and remove
Also if you have the Microsoft .netframework 1.1 Hotfix select that and click remove as well.
Once both those are removed we can reinstall Microsoft .netframework from the Print Shop Install disc
You can do this by:
Insert the Print Shop Install disc
Double Click on My computer
Right Click on the Drive that contains the Print Shop Disc
Left click the open option.
Double click on the folder called Setup
Double click on the file that’s called 1033DotNetfx
This will reinstall the net framework on your computer and it should fix the issue you are having.
Posted on Jan 26, 2010
  • 261 Answers
SOURCE: Print Shop 21 will not
When a ‘clean’ install is done of Print Shop 22, exactly as described in this FAQ
'Clean' Install on Win98/Me/XP/2000/Vista/Win7
Print Shop 22 should install on a 64-bit version of Windows 7, with two incidents.
1. If .NET Framework 1.1 is not already installed on the computer, the "Program Compatibility Assistant” in Windows 7 will display this message
this program has know compatibility issues
To continue with the installation, select "Run Program". After .NET Framework 1.1 is installed, the necessary updates will be pulled from the Microsoft Windows Update Service.
2. After .NET Framework 1.1 is installed, the "Program Compatibility Assistant” in Windows 7 will display a message which says that there are compatibility issues with Print Shop 22 on Windows 7 64-bit. To continue with the installation of .NET Framework 1.1, select "Run Program".
NOTE: Even though the Print Shop 22 Vista patch, which can be found here
Download Vista Patch For The Print Shop 22 and PrintMaster 17 Disk Versions
can be installed on a 64-bit version of Windows 7, the patch will not fix the problem with the Amyuni Document Converter, as it does on a 32-bit version of Windows 7 (see above). So, it will not be possible to use the 'Save As PDF' option with Print Shop 22 on a 64-bit version of Windows 7. Instead, it will be necessary to install an alternate PDF driver, then Print to PDF, as is described in this FAQ
Save as PDF vs File | Print to PDF
So far, the only other known incompatibility with Print Shop 22 on a 64-bit version of Windows 7 is that Print Shop 22 cannot be run from a shortcut on the Dell Dock that is provided with many Dell computers. A Print Shop 22 shortcut can be placed on the Dell Dock; but, attempts to start Print Shop 22 from that Dell Dock shortcut will cause several incompatibility messages to be displayed
Posted on Aug 04, 2010
  • 2340 Answers
SOURCE: Installing Print Shop 21 in
Print Shop version 21 Deluxe is not compatible with Windows 7. You have to use a newer version 23 which is compatible. This is due to software compatibility with Windows 7.
You can check forcompatibilites issues @ Windows 7 "software & hardware" compatibility center
Posted on Mar 14, 2011
  • 7 Answers
SOURCE: Can not install Print Shop
You can try setting it to run in compatability mode.
Right click on the program Icon
Click properties
Then click compatability tab
Check mark Run this program in compatability for
Select windows xp in the drop down list.
Click apply then OK
Try running the program
If this does not work try
Right clicking on the icon of the program and selecting run as administrator.
This program version is not supported by Windows 7 so if this does not work the you will need to upgrade to Version .23 instead of .21
Posted on Jul 05, 2011
Print shop deluxe version 6 on 64 bit windows 7
download free virtual machine then you can install xp on your windows 7 64 bit pc. then install your print shop 6.0 and you can use it just like you did on your older pc. windows 7 professional has a mode that you can also use windows xp.
Feb 11, 2013 | Broderbund The Print Shop 21 Deluxe Full...
Can not install Print Shop Pro Publisher Version 21 will not load on Windows 7
Click properties
Click apply then OK
Jul 05, 2011 | Broderbund The Print Shop 21 Deluxe Full...
Installing Print Shop 21 in Windows 7
Mar 14, 2011 | Broderbund The Print Shop 21 Deluxe Full...
Will a previous file open on The Print Shop 21 if it is being run on a new 64 bit windows
Yes, especially yes if it's Windows 7. Works well with older programs and 32 bit programs. Hope this info helps ;)
Dec 31, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Print Shop 21 will not work on Windows 7 operating system is there a fix?
Aug 04, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Install new CD for printing projects.
goto Start/programs/Accessories then to Windows explorer or my computer then goto ur CD drive then click on setup.exe
Mar 23, 2010 | Broderbund The Print Shop 21 Deluxe Full...
Solution
You can do this by:
You can do this by:
Nov 09, 2009 | Broderbund The Print Shop 21 Deluxe Full...
Broderbund The Print Shop 21 Deluxe Full Version for PC Logo
82 people viewed this question
Top Broderbund Computers & Internet Experts
Peter Dragonetti
Norman Worley
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
