If you use an HP printer, you might sometimes encounter offline error issues. If you want to know why HP Printer offline, how to fix it? Then follow this post. The offline error can be due to outdated drivers, connection issues, or a settings error. To solve this issue, first, ensure that you have downloaded and installed all of the updates for the Windows OS and check you have set your printer as a default printer, and check whether the device connection is made properly.
https://connectmyprinter.com/how-to-fix-hp-printer-offline-error/
To change the printer status from offline to online, follow these steps: Go to Printers & scanners in settings. Then select your printer and make sure to uncheck the "use of Printer Offline."
http://www.hp-online-care.com/hp-deskjet-printer-offline.html error may be annoying but it has the simplest solution. The error may occur due to network conditions or some other technical problems.
Once done with care, you will never bump into these sorts of issues. Try restarting your HP Envy printer and computer,
even router (if you have connected) to get a clear view of what causes your printer to go offline. You never know what it is until you sort it out. http://www.hp-online-care.com/hp-deskjet-printer-offline.html
Press Start
Devices and printers
Find the printer you wish to bring online
If you are using windows xp- double click on the printer
If you are using Windows 7 or vista- right click on the printer and select "see what's printing"
Hit "printer" in the menu bar
Toggle the "use printer offline selection"
The users who are experiencing offline errors while using the brother printers are suggested to check the connections, settings and printer hardware before proceeding any further. The connection to and from the printer shall be verified thoroughly by the users and any anomalies if found shall be fixed then and there. As these errors can also be caused by printer hardware issues, the users are suggested to check with different key components of the printer like the cartridges, feed tray and more and fix any issues if found. Restarting the printer and the computer after following the above mentioned procedure will help in solving and preventing the offline errors with your brother printer.
Hello there:
for the document you want to print click on print and your printer should show up now just click on the printer and look down where it says use printer offline and click on it again and than it will say use printer online and just print from there ok please dont forget to rate this solution for me
best regards mike
For my MFC, my PC says its ready and working properly. It really only works when I'm not connected to my cable modem. All PCs use it then. It's offline otherwise.
perform the steps below if the Operating System is XP
Step 1: ===== Determine if the printer is paused or offline : =============================
1.Open the printers folder, if necessary. a.Click the Start icon. b.Click Control Panel. c.Click Hardware & Sounds. NOTE: This step is not required when using Classic view in Windows Vista. d.Click Printers.
2.Right-click the name of the printer and then click Open.
3.Click Printer.
4.Verify that Pause Printing and Use Printer Offline are not selected.
5.Press Esc to close the window without making any changes.
Step 2: ===== Check for the default printer and USe printer Online in the printers and faxes folder. =========================================================
Click Start -->> Control panel -->> Hardware and sound-->> Printers-->>Change default printer. ---> Please Right Click on the printer icon which has tick mark and Select the options Use printer Online and Set as Default and also Select the option Resume printing.
